Problem configuring Waveshare E-Paper ESP32 Driver Board
OldSchool73
Postby OldSchool73 » Tue May 12, 2020 12:23 pm
Hi
I bought a Waveshare E-Paper ESP32 Driver Board (https://www.waveshare.com/wiki/E-Paper_ ... iver_Board) together with a Waveshare 2.13 inch display. The board works nicely with the example Arduino code from Waveshare.
However I wanted to use esp-idf with the epaper.h library, but I can't get it to work.
I can compile and flash my program, but it seems that BUSY_PIN is always low => busy. Therefore the program loops in an endless loop.
I'm not sure if the GPIOs I got from the Arduino config and from the manual are correct.
Here is my Config:
#define MOSI_PIN 14
#define MISO_PIN 19 // guess not used
#define SCK_PIN 13
#define BUSY_PIN 25
#define DC_PIN 27
#define RST_PIN 26
#define CS_PIN 15
Does anyone have the board running? If so, what library do you use and how have you configured the SPI PINs?
Thanks in advance
Tobias
Users browsing this forum: usulrasolas and 20 guests
