Hi there!
I wanted to know if I'm missing something in my CMAKE instructions since from componentA (CalEPD) I cannot include componentB (Adafruit_GFX)
Source codes are here:
https://github.com/martinberlin/cale-id ... t_adafruit
Basically I would like to include the fonts in a class I'm starting to control epaper displays. When I do the idf.py build I see that the components are there:
-- Components: Adafruit-GFX CalEPD
But if I try to include "Adafruit_GFX.h" header file to extent it from my main class then the compiler can't find it:
In file included from ../components/CalEPD/epd.cpp:2:
../components/CalEPD/include/epd.h:18:10: fatal error: Adafruit_GFX.h: No such file or directory
#include <Adafruit_GFX.h>
For sure I'm missing something since I see examples of this being done all the time. Could you please enlighten me?
Help with components visibility
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
Re: Help with components visibility
Hi Fasani,
You need to add the line "REQUIRES Adafruit-GFX" or "PRIV_REQUIRES Adafruit-GFX" here:
https://github.com/martinberlin/cale-id ... ts.txt#L13
Can find a full explanation here:
https://docs.espressif.com/projects/esp ... quirements
Angus
Angus
Awesome. Very important part to read that I missed.
Thanks for enlightening me. Much appreciated.
I will try to build on next weeks a component to drive E-paper displays purely on IDF without using Arduino framework components. Since I tried to refactor GxEPD to work in IDF but is built on a way that depends on many Arduino things...
So if it works, after a lot of transpiration and learning, we could have a epaper driver that can be linked as a "component" in IDF projects.
UPDATE: First version of the component is out. It's called CalEPD. For those interested in Epaper:
https://github.com/martinberlin/cale-idf
Users browsing this forum: jgrossholtz and 148 guests
