idf.py is failing when I checkout ESP-IDF v4.1
Posted: Sat May 23, 2020 6:08 am
Hi there,
I'm in Ubuntu Linux, Python version 3.6.9.
Today I wanted to compile something in the esp32s2beta since I'm waiting that some S2 arrive, so I switched to:
https://github.com/espressif/esp-idf/tree/release/v4.1
update submodules and run pip install requirements again. But I got an error with idf.py that I could not solve:
So I switched back to the tagged version v4.0.1 and everything works again including idf.py
Maybe someone can enlighten me on how to test 4.1 version? Thanks in advance!
martin@martin-L:~/esp$ idf.py
File "/home/martin/esp/esp-idf/tools/idf.py", line 775, in <module>
main()
File "/home/martin/esp/esp-idf/tools/idf.py", line 692, in main
cli = init_cli(verbose_output=checks_output)
File "/home/martin/esp/esp-idf/tools/idf.py", line 650, in init_cli
extensions[name] = import_module(name)
File "/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 674, in exec_module
File "<frozen importlib._bootstrap_external>", line 888, in get_code
File "<frozen importlib._bootstrap_external>", line 455, in _validate_bytecode_header
ImportError: bad magic number in 'debug_ext': b'\x03\xf3\r\n'
