[Solved] EXTRA_COMPONENT_DIRS not working for me
RobMeades
Postby RobMeades » Sat May 30, 2020 12:25 pm
I have arranged my builds such that I have a common CMakeLists.txt in one directory and below it, in sub-directories, I have builds that make use of this common CMakeLists.txt, e.g. "thing1", which will in turn have the usual "main" sub-directory inside them. The common CMakeLists.txt pulls in generic source code, "thing1" will bring in its own main.c and anything else it needs.
In the CMakeLists.txt file in each of the "thingx" directories I set EXTRA_COMPONENT_DIRS to ".." in the hope of referring to the common CMakeLists.txt in the directory above. However, this doesn't work, the contents of my common CMakeLists.txt never make it into the build, it is never listed in the list of components. What might I be doing wrong?
This is the CMakeLists.txt in the "thingx" directory:
cmake_minimum_required(VERSION 3.5)
set(EXTRA_COMPONENT_DIRS "..")
# Empty the component list, main will bring in just what it needs
set(COMPONENTS "")
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
project(example)
...and this is the kind of thing I have in the common CMakeLists.txt in the directory above:
set(COMPONENT_ADD_INCLUDEDIRS "../../api" "../../cfg")
set(COMPONENT_SRCS "../../src/blah.c")
register_component()
...and, for completeness, this is the CMakeLists.txt from the "main" directory of "thingx":
set(COMPONENT_SRCS "main.c")
set(COMPONENT_REQUIRES "esp32" "esptool_py")
This is with ESP-IDF version 4.1 and I am in the "thing1" directory when I execute "idf.py flash".
Thanks in advance for your help.
ESP_renz
Re: EXTRA_COMPONENT_DIRS not working for me
Postby ESP_renz » Tue Jun 02, 2020 2:00 am
Hi, it seems that the component in the directory above 'thingx' is rightfully not pulled in, since `main` in your snippet does not seem to do so?
RobMeades
Postby RobMeades » Tue Jun 02, 2020 7:07 am
Ah, yes, of course, EXTRA_COMPONENT_DIRS makes the component directory available to the CMake system but it doesn't actually _include_ the component in my case, main has to pull it in by naming it explicitly. That must be it.
Thank you for pointing out my "deliberate" mistake :-).
Users browsing this forum: oshmykov-dev and 243 guests
