I am using the sample code, slightly modified to also include a client certificate and client private key.
#define WEB_SERVER "[iothub_address_removed].azure-devices.net"
#define WEB_PORT "443"
#define WEB_URL "https://[iothub_address_removed].azure-devices.net/devices/[devie_removed]/files/[file_removed]?api-version=2019-03-30"
static const char *TAG = "example";
static const char *AZURE_REQUEST = "GET " WEB_URL " HTTP/1.1\r\n"
"Host: "WEB_SERVER"\r\n"
"User-Agent: esp-idf/1.0 esp32\r\n"
"Connection: keep-alive\r\n"
"Content-Type: application/json\r\n"
"Accept: */*\r\n"
"\r\n";
extern const uint8_t server_root_cert_pem_start[] asm("_binary_server_root_cert_pem_start");
extern const uint8_t server_root_cert_pem_end[] asm("_binary_server_root_cert_pem_end");
extern const uint8_t myuplink_cert_pem_start[] asm("_binary_myuplink_cert_pem_start");
extern const uint8_t myuplink_cert_pem_end[] asm("_binary_myuplink_cert_pem_end");
extern const uint8_t client_cert_pem_start[] asm("_binary_client_cert_pem_start");
extern const uint8_t client_cert_pem_end[] asm("_binary_client_cert_pem_end");
extern const uint8_t client_key_pem_start[] asm("_binary_client_key_pem_start");
extern const uint8_t client_key_pem_end[] asm("_binary_client_key_pem_end");
static void https_get_task(void *pvParameters)
char buf[512];
int ret, flags, len;
mbedtls_entropy_context entropy;
mbedtls_ctr_drbg_context ctr_drbg;
mbedtls_ssl_context ssl;
mbedtls_x509_crt cacert;
mbedtls_x509_crt publiccert;
mbedtls_pk_context privkey;
mbedtls_ssl_config conf;
mbedtls_net_context server_fd;
mbedtls_ssl_init(&ssl);
mbedtls_x509_crt_init(&cacert);
mbedtls_x509_crt_init(&publiccert);
mbedtls_pk_init(&privkey);
mbedtls_ctr_drbg_init(&ctr_drbg);
ESP_LOGI(TAG, "Seeding the random number generator");
mbedtls_ssl_config_init(&conf);
mbedtls_entropy_init(&entropy);
if((ret = mbedtls_ctr_drbg_seed(&ctr_drbg, mbedtls_entropy_func, &entropy,
NULL, 0)) != 0)
ESP_LOGE(TAG, "mbedtls_ctr_drbg_seed returned %d", ret);
abort();
ESP_LOGI(TAG, "Loading the CA root certificate...");
ret = mbedtls_x509_crt_parse(&cacert, myuplink_cert_pem_start,
myuplink_cert_pem_end-myuplink_cert_pem_start);
if(ret < 0)
ESP_LOGE(TAG, "mbedtls_x509_crt_parse returned -0x%x\n\n", -ret);
abort();
ESP_LOGI(TAG, "Loading the Public certificate...");
ret = mbedtls_x509_crt_parse(&publiccert, client_cert_pem_start,
client_cert_pem_end-client_cert_pem_start);
if(ret < 0)
abort();
ESP_LOGI(TAG, "Loading the Private key...");
ret = mbedtls_pk_parse_key(&privkey, client_key_pem_start,
client_key_pem_end-client_key_pem_start, NULL, 0);
if(ret < 0)
ESP_LOGE(TAG, "mbedtls_pk_parse returned -0x%x\n\n", -ret);
abort();
ESP_LOGI(TAG, "Setting hostname for TLS session...");
/* Hostname set here should match CN in server certificate */
if((ret = mbedtls_ssl_set_hostname(&ssl, WEB_SERVER)) != 0)
ESP_LOGE(TAG, "mbedtls_ssl_set_hostname returned -0x%x", -ret);
abort();
ESP_LOGI(TAG, "Setting up the SSL/TLS structure...");
if((ret = mbedtls_ssl_config_defaults(&conf,
MBEDTLS_SSL_IS_CLIENT,
MBEDTLS_SSL_TRANSPORT_STREAM,
MBEDTLS_SSL_PRESET_DEFAULT)) != 0)
ESP_LOGE(TAG, "mbedtls_ssl_config_defaults returned %d", ret);
goto exit;
/* MBEDTLS_SSL_VERIFY_OPTIONAL is bad for security, in this example it will print
a warning if CA verification fails but it will continue to connect.
You should consider using MBEDTLS_SSL_VERIFY_REQUIRED in your own code.
mbedtls_ssl_conf_authmode(&conf, MBEDTLS_SSL_VERIFY_NONE);
mbedtls_ssl_conf_ca_chain(&conf, &cacert, NULL);
mbedtls_ssl_conf_own_cert(&conf, &publiccert, &privkey);
mbedtls_ssl_conf_rng(&conf, mbedtls_ctr_drbg_random, &ctr_drbg);
#ifdef CONFIG_MBEDTLS_DEBUG
mbedtls_esp_enable_debug_log(&conf, CONFIG_MBEDTLS_DEBUG_LEVEL);
#endif
if ((ret = mbedtls_ssl_setup(&ssl, &conf)) != 0)
ESP_LOGE(TAG, "mbedtls_ssl_setup returned -0x%x\n\n", -ret);
goto exit;
while(1) {
mbedtls_net_init(&server_fd);
ESP_LOGI(TAG, "Connecting to %s:%s...", WEB_SERVER, WEB_PORT);
if ((ret = mbedtls_net_connect(&server_fd, WEB_SERVER,
WEB_PORT, MBEDTLS_NET_PROTO_TCP)) != 0)
ESP_LOGE(TAG, "mbedtls_net_connect returned -%x", -ret);
goto exit;
ESP_LOGI(TAG, "Connected.");
mbedtls_ssl_set_bio(&ssl, &server_fd, mbedtls_net_send, mbedtls_net_recv, NULL);
ESP_LOGI(TAG, "Performing the SSL/TLS handshake...");
while ((ret = mbedtls_ssl_handshake(&ssl)) != 0)
if (ret != MBEDTLS_ERR_SSL_WANT_READ && ret != MBEDTLS_ERR_SSL_WANT_WRITE)
ESP_LOGE(TAG, "mbedtls_ssl_handshake returned -0x%x", -ret);
goto exit;
ESP_LOGI(TAG, "Verifying peer X.509 certificate...");
if ((flags = mbedtls_ssl_get_verify_result(&ssl)) != 0)
/* In real life, we probably want to close connection if ret != 0 */
ESP_LOGW(TAG, "Failed to verify peer certificate!");
bzero(buf, sizeof(buf));
mbedtls_x509_crt_verify_info(buf, sizeof(buf), " ! ", flags);
ESP_LOGW(TAG, "verification info: %s", buf);
else {
ESP_LOGI(TAG, "Certificate verified.");
ESP_LOGI(TAG, "Cipher suite is %s", mbedtls_ssl_get_ciphersuite(&ssl));
ESP_LOGI(TAG, "Writing HTTP request...");
size_t written_bytes = 0;
do {
ret = mbedtls_ssl_write(&ssl,
(const unsigned char *)AZURE_REQUEST + written_bytes,
strlen(AZURE_REQUEST) - written_bytes);
if (ret >= 0) {
ESP_LOGI(TAG, "%d bytes written", ret);
written_bytes += ret;
} else if (ret != MBEDTLS_ERR_SSL_WANT_WRITE && ret != MBEDTLS_ERR_SSL_WANT_READ) {
ESP_LOGE(TAG, "mbedtls_ssl_write returned -0x%x", -ret);
goto exit;
} while(written_bytes < strlen(AZURE_REQUEST));
ESP_LOGI(TAG, "Reading HTTP response...");
do
len = sizeof(buf) - 1;
ret = mbedtls_ssl_read(&ssl, (unsigned char *)buf, len);
if(ret == MBEDTLS_ERR_SSL_WANT_READ || ret == MBEDTLS_ERR_SSL_WANT_WRITE)
continue;
if(ret == MBEDTLS_ERR_SSL_PEER_CLOSE_NOTIFY) {
ret = 0;
if(ret < 0)
ESP_LOGE(TAG, "mbedtls_ssl_read returned -0x%x", -ret);
if(ret == 0)
ESP_LOGI(TAG, "connection closed");
len = ret;
ESP_LOGD(TAG, "%d bytes read", len);
/* Print response directly to stdout as it is read */
for(int i = 0; i < len; i++) {
putchar(buf[i]);
} while(1);
mbedtls_ssl_close_notify(&ssl);
exit:
mbedtls_ssl_session_reset(&ssl);
mbedtls_net_free(&server_fd);
if(ret != 0)
mbedtls_strerror(ret, buf, 100);
ESP_LOGE(TAG, "Last error was: -0x%x - %s", -ret, buf);
putchar('\n'); // JSON output doesn't have a newline at end
static int request_count;
ESP_LOGI(TAG, "Completed %d requests", ++request_count);
for(int countdown = 10; countdown >= 0; countdown--) {
ESP_LOGI(TAG, "%d...", countdown);
ESP_LOGI(TAG, "Starting again!");
I (16398) mbedtls: ssl_tls.c:2722 ssl->f_recv(_timeout)() returned -80 (-0x0050)
W (16398) mbedtls: ssl_tls.c:4973 mbedtls_ssl_fetch_input() returned -80 (-0x0050)
W (16408) mbedtls: ssl_tls.c:4344 ssl_get_next_record() returned -80 (-0x0050)
W (16408) mbedtls: ssl_tls.c:8335 mbedtls_ssl_read_record() returned -80 (-0x0050)
E (16418) example: mbedtls_ssl_read returned -0x50
I (16428) mbedtls: ssl_tls.c:8725 => write close notify
I (16428) mbedtls: ssl_tls.c:5250 => send alert message
I (16438) mbedtls: ssl_tls.c:3343 => write record
I (16448) mbedtls: ssl_tls.c:1445 => encrypt buf
I (16448) mbedtls: ssl_tls.c:1781 <= encrypt buf
I (16458) mbedtls: ssl_tls.c:2755 => flush output
I (16458) mbedtls: ssl_tls.c:2774 message length: 69, out_left: 69
I (16468) mbedtls: ssl_tls.c:2779 ssl->f_send() returned -80 (-0x0050)
W (16478) mbedtls: ssl_tls.c:3472 mbedtls_ssl_flush_output() returned -80 (-0x0050)
W (16488) mbedtls: ssl_tls.c:5260 mbedtls_ssl_write_record() returned -80 (-0x0050)
W (16488) mbedtls: ssl_tls.c:8736 mbedtls_ssl_send_alert_message() returned -80 (-0x0050)
E (16508) example: Last error was: -0x50 - UNKNOWN ERROR CODE (0050)
