1. Open a command prompt with administrator privileges.
2. Clone the latest version of esp-idf from Github into c:\projects\esp-idf-latest.
3. Run c:\projects\esp-idf-latest\install.bat in the command window and let it do its stuff.
4. Run c:\projects\esp-idf-latest\export.bat in the command window and let it do its stuff.
5. CD to my ESP32 build and run c:\projects\esp-idf-latest\tools\idf.py.
idf.py then reports:
The following Python requirements are not satisfied:
gdbgui>=0.13.2.0
pygdbmi<=0.9.0.2
reedsolo==1.5.3
bitstring>=3.1.6
esp-windows-curses; sys_platform == 'win32'
To install the missing packages, please run "C:\projects\esp-idf-latest\install.bat"
Diagnostic information:
IDF_PYTHON_ENV_PATH: C:\Users\rob\.espressif\python_env\idf4.2_py2.7_env
Python interpreter used: C:\Python27\python.exe
Warning: python interpreter not running from IDF_PYTHON_ENV_PATH
Now I do have Python 2.7 elsewhere in my path, as it indicates, but this comes AFTER the ones that were just installed, here is the start of the path according to the command prompt:
PATH=C:\Users\rob\.espressif\tools\xtensa-esp32-elf\esp-2020r1-8.2.0\xtensa-esp32-elf\bin;C:\Users\rob\.espressif\tools\xtensa-esp32s2-elf\esp-2020r1-8.2.0\xtensa-esp32s2-elf\bin;C:\Users\rob\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin;C:\Users\rob\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin;C:\Users\rob\.espressif\tools\cmake\3.16.4\bin;C:\Users\rob\.espressif\tools\openocd-esp32\v0.10.0-esp32-20200420\openocd-esp32\bin;C:\Users\rob\.espressif\tools\ninja\1.10.0\;C:\Users\rob\.espressif\tools\idf-exe\1.0.1\;C:\Users\rob\.espressif\tools\ccache\3.7\;C:\Users\rob\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64;C:\Users\rob\.espressif\python_env\idf4.2_py2.7_env\Scripts;C:\projects\esp-idf-latest\tools;
C:\Users\rob\.espressif\python_env\idf4.2_py2.7_env\Scripts\python.exe
C:\Users\rob\AppData\Local\Microsoft\WindowsApps\python.exe
