Hello all,
I have a quite unorthodox screen that requires that the SPI CS line comes back to 1 after each Byte.
I have a bit-banged solution that work well but I would prefer to be able to use DMA and hardware SPI.
When I tried I haven't found a suitable solution in the SDK.
Does Anyone have an idea?
Thank you in advance.
Best regards
Em
SPI CS toggling after each byte
Re: SPI CS toggling after each byte
That is a strange requirement indeed... to be honest, I'm not sure if our hardware can do this. What display is this, if I may ask?
If you really need this as you describe, I can see two options:
- Use the I2S peripheral. You'll probably have to write your own driver, but I *think* it can be configured to do single transfers and then stop. You can use the WC signal as your toggling CS in this case; configure it so the left channel is your output byte and the right channel (when ws is high) is a constant.
- Use an external binary counter IC, connect the clk to the SPI clock output on the ESP32 and the divide-by-eight output to the CS input of the LCD.
Sure, I'm using e-Paper screen used for electronic shelf label. the driver is made by a company named ultrachip from Taiwan.ESP_Sprite wrote:That is a strange requirement indeed... to be honest, I'm not sure if our hardware can do this. What display is this, if I may ask?
The timing is like that. From my point of view I don't really understand the use of a hardware CS implementation if the CS signal is so slow and can be easily made using a GPIO.
I like the I2C idea I will see if it can be implemented likewise. For the moment the bit-bang implementation can go up to 2Mb/s but take 100% of a processor during the image transfers.ESP_Sprite wrote: If you really need this as you describe, I can see two options:
Thank you for your time and best regards
Em
The thing is that you can get the SPI hardware to set specific CS timings, depending on your type of transfer. GPIO-based CS timings can be fairly random, depending on what the CPU is doing.
The CS signal indeed is pretty weird... are you 100% sure you *must* make the CS line high between every byte? Most 9-bit SPI slave implementations will just start on a next byte after the 9th bit has come in.
Users browsing this forum: Ethapus and 267 guests
