ESP32 can't boot (partition table error)
sousuke
Postby sousuke » Fri Jul 31, 2020 4:13 pm
Hi!
I have a ESP-WROOM-32 w/ 4MB SPI flash and wanted to compile & flash the simple hello-world application.
I've set up ESP-IDF v4.0.2 on my debian system and everything seems to be working fine. (compilation + flashing)
But for some reason, my ESP32 can't get past the 2nd stage bootloader and bootloops. Here's what the console log is outputting:
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:7008
ho 0 tail 12 room 4
load:0x40078000,len:14080
load:0x40080400,len:4356
0x40080400: _init at ??:?
entry 0x400806f0
I (74) boot: Chip Revision: 1
I (34) boot: ESP-IDF v4.0.1 2nd stage bootloader
I (34) boot: compile time 11:47:10
I (34) boot: Enabling RNG early entropy source...
I (39) boot: SPI Speed      : 40MHz
I (43) boot: SPI Mode       : DIO
I (47) boot: SPI Flash Size : 4MB
E (51) flash_parts: partition 0 invalid magic number 0x0
E (57) boot: Failed to verify partition table
E (62) boot: load partition table error!
With esptool I've dumped the partition table (double checked menuconfig/sdkconfig and if the flashing via idf.py did deploy the partition table at the right flash location) and compared it w/ build/partition_table/partition_table.bin. It looks good - no differences.
Any hints the ESP gurus can give me? Anything I might have missed? ;)
sousuke
huntik
Re: ESP32 can't boot (partition table error)
Postby huntik » Sat Aug 01, 2020 7:50 pm
Can you share your partition table?
sousuke
Postby sousuke » Mon Aug 03, 2020 8:12 am
Sure! Here you go...
# Extracted the partition table from the ESP device to be on the safe side
$ esptool.py read_flash 0x8000 3072 out_00008000-pt.bin
# Here's the partition table in CSV format:
$ gen_esp32part.py out_00008000-pt.bin
Parsing binary partition input...
Verifying table...
# Espressif ESP32 Partition Table
nvs,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,1M,
# And one more time in raw format:
$ hexdump -C out_00008000-pt.bin
00000000  aa 50 01 02 00 90 00 00  00 60 00 00 6e 76 73 00  |.P.......`..nvs.|
00000010  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000020  aa 50 01 01 00 f0 00 00  00 10 00 00 70 68 79 5f  |.P..........phy_|
00000030  69 6e 69 74 00 00 00 00  00 00 00 00 00 00 00 00  |init............|
00000040  aa 50 00 00 00 00 01 00  00 00 10 00 66 61 63 74  |.P..........fact|
00000050  6f 72 79 00 00 00 00 00  00 00 00 00 00 00 00 00  |ory.............|
00000060  eb eb ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
00000070  f4 ad 4f 45 38 56 4b 5d  74 35 b6 2c 75 b6 95 24  |..OE8VK]t5.,u..$|
00000080  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
00000c00
Any possibility that I can (enable and) read in the bootloader logs, where it gets the partition table from? Could the bootloader be using an incorrect offset for the partition table?
sousuke
Postby sousuke » Mon Aug 03, 2020 9:00 am
Ok forget my question above. I've enabled verbose logging in the bootloader and for that I had to shift the partition table to another location (just took 0x10000) and here's the new boot log:
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
load:0x3fff001c,len:9528
load:0x40078000,len:15096
load:0x40080400,len:4740
entry 0x4008072c
D (110) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff)
I (146) boot: Chip Revision: 1
I (77) boot: ESP-IDF v4.0.1 2nd stage bootloader
I (78) boot: compile time 10:35:42
D (78) boot: Enabling RTCWDT(9000 ms)
I (81) boot: Enabling RNG early entropy source...
D (87) boot: magic e9
D (89) boot: segments 04
D (91) boot: spi_mode 02
D (94) boot: spi_speed 00
D (97) boot: spi_size 02
I (99) boot: SPI Speed      : 40MHz
I (104) boot: SPI Mode       : DIO
I (108) boot: SPI Flash Size : 4MB
D (112) bootloader_flash: mmu set paddr=00010000 count=1 size=c00 src_addr=10000 src_addr_aligned=10000
D (121) boot: mapped partition table 0x10000 at 0x3f400000
E (127) flash_parts: partition 0 invalid magic number 0x0
E (133) boot: Failed to verify partition table
E (138) boot: load partition table error!
Apparently the SPI flash memory was mapped correctly to RAM. So I don't see any issues there...
But I must be missing an important piece here. :(
sousuke
Postby sousuke » Mon Aug 03, 2020 11:45 am
Had some spare time during lunch break...
I've reverted to INFO log + moved part-table back to 0x8000 + added some INFO logs for bootloader_mmap and doing a raw dump of the mmapped partition table:
load:0x3fff0020,len:4
load:0x3fff0024,len:7052
load:0x40078000,len:14344
load:0x40080400,len:4304
entry 0x400806e8
I (71) boot: Chip Revision: 1
I (72) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (39) boot: ESP-IDF v4.0.1-dirty 2nd stage bootloader
I (39) boot: compile time 13:36:24
I (39) boot: Enabling RNG early entropy source...
I (44) boot: SPI Speed      : 40MHz
I (48) boot: SPI Mode       : DIO
I (52) boot: SPI Flash Size : 4MB
I (56) boot: Mapping flash to memory offset=0x8000, length=0xc00...
E (63) flash_parts: partition 0 invalid magic number 0x0
E (69) flash_parts: RAW DUMP
E (73) flash_parts: [00000000] 00 00 AA FF FF FF FF FF   FF FF FF FF FF FF FF FF
E (81) flash_parts: [00000010] FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
E (89) flash_parts: [00000020] 00 00 AA FF FF FF FF FF   FF FF FF FF FF FF FF FF
E (97) flash_parts: [00000030] FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
E (1646) flash_parts: [00000be0] 00 00 AA FF FF FF FF FF   FF FF FF FF FF FF FF FF
E (1654) flash_parts: [00000bf0] FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
E (1663) boot: Failed to verify partition table
E (1668) boot: load partition table error!
Looks like the mmap is failing? Or is it some configuration issue on my side?
sousuke
Postby sousuke » Mon Aug 10, 2020 4:52 pm
FWIW:
I've unpacked another ESP32 board and first checked if board is firing up with some "default application" which was already burned on the chip. And it did. I made a backup of the image and flashed my "hello world" (the same binaries as I used before) on the new board ... and voila, it worked.
Apparently the first ESP32 is broken?
I even reverted to IDF 2.1 (because the demo application was compiled with IDF 2.1) because I was already desperately analyzing the boot problem. Hell I even flashed the test-application to the ESP32 and no success...
Could it be that the first ESP32 board I've received was already dead when I received it?
ESP_Sprite
Postby ESP_Sprite » Tue Aug 11, 2020 10:59 am
Feels like a wonky flash chip on the broken module, indeed.
Users browsing this forum: No registered users and 279 guests
