RMT output the same signal on multiple pins
djokba
Postby djokba » Tue Sep 15, 2020 12:13 pm
I am using RMT peripheral to generate an IR signal for various types of remote control protocols.
Currently, i am only using a single IR LED and i want to add an external IR transmitter on another pin for a wider signal coverage.
I want both of LEDs to produce the same signal simultaneosly, so the device will only receive the signal once. My code looks like this.
int item_num = 0;
size_t size = sizeof(rmt_item32_t) * 300;
rmt_item32_t *item = (rmt_item32_t *)malloc(size);
memset((void *)item, 0, size);
item_num = rmt_build_items(item);
rmt_write_items(RMT_CHANNEL, item, item_num, true);
rmt_wait_tx_done(RMT_CHANNEL, portMAX_DELAY);
rmt_set_pin(RMT_CHANNEL, RMT_MODE_TX, EXT_LED_IO_NUM);
free(item);
The output is two identical signal where the second one is sent right after the first one is finished, and i think that makes sense. However this will make the device receive the same signal twice.
What is the best way to solve this issue? Or is there some other way to produce the signal on both pins at once?
Any help would be appreciated.
Thanks!
Re: RMT output the same signal on multiple pins
Postby ESP_Sprite » Wed Sep 16, 2020 8:14 am
The simple and stupid way would be to connect both transmitters to the same GPIO... the more elegant way to be simple and stupid would be to tweak the GPIO matrix so both transceiver GPIOs are connected to the same RMT output channel.
djokba
Postby djokba » Mon Sep 21, 2020 6:56 am
Hi, thank you for your suggestions. So far i haven't found any documentation that explains how to tweak the GPIO matrix, except for gpio_matrix_out which i found in other related questions, but i'm not sure what it does and how to use it.
Could you show me an example how to use this API?
Thanks!
Postby ESP_Sprite » Tue Sep 22, 2020 9:29 am
You probably want to read the GPIO-related sections of the Technical Reference Manual for that.
Users browsing this forum: No registered users and 41 guests
