Hi!
How am I supposed to import an external CMake library (specifically https://github.com/nlohmann/json) into an ESP-IDF project?
The ESP-IDF does not seem to comply with CMake's usual procedure for pulling in external stuff - adding "add_subdirectory(components/nlohmann_json)" will fail with a nasty error which appears a conflicting definition of "project" function.
Section "Using Third-Party CMake Projects with Components" in the build system documentation enthusiastically promises to "import these third-party projects, sometimes even without modification!" but is starved of all relevant detail. E.g. how do you interface with the external library's CMakeLists? The 9-line snippet of CMake code there I have no idea what to do with - do I put it into my top-level CMakeLists.txt (tried, fails), into main/CMakeLists.txt (tried, fails), the external's CMakeLists.txt, ...?
As an alternative (since https://github.com/nlohmann/json is implemented as header files) I'll gladly take any hack or workaround anybody has found for pulling in this specific JSON library.
Integrating an external CMake library (github.com/nlohmann/json)
Users browsing this forum: maurizio.scian and 138 guests
