Hi all -
Recently, my app (running release/v4.1 on a WROVER) began experiencing a significant lag on socket input. I perform a socket recvfrom with MSG_PEEK in a relatively tight loop. When I send a message from my PC to the ESP32 (via a multicast group), WireShark shows the message immediately, but my app doesn't see it for several (between 6 and ~60) seconds.
I'm not blocking; I put a telltale in the peek that indicates no data, over and over and over, until finally, it sees the message.
Any ideas? This is a showstopper for us.
Thanks...
(solved - sort of) odd socket behavior
Re: odd socket behavior
Strange, especially with such a long delay. Does disabling wifi power saving perhaps help?
Hi Sprite - I doubt that would help, but I can't do that anyway. I need WiFi running.
EDIT: I have a little trouble understanding git history...are there any WiFi-related patches or updates I should be using?
Hi Sprite - I misread your reply above. I would certainly like to disable power saving when running on line power. In my sdkconfig file, CONFIG_PM_ENABLE is not set. Is there anything else I need to do?
Thanks...
Thanks...
Another couple of data points:
This only seems to occur on my home network (a Google Nest mesh).
While the delay varies greatly, all the delayed units seem to receive their packet at (nearly) the same time. All the units experiencing the delay respond simultaneously.
I don't know what caused this, but recently I had a sustained power outage, which (presumably) caused a reset in my home network. Since then, everything's been back to normal. Marking this as solved.
Users browsing this forum: No registered users and 155 guests
