undefined reference to task functions in separate components
florent92
Postby florent92 » Sun Jan 03, 2021 11:40 pm
I'm porting an open source project from ESP3.x to to the last ESP-IDF 4.3-dev version.
The full repository is available at:
https://github.com/fc92/ESP32_MP3_Decod ... f-v4.3-dev
(git submodule update --init --recursive is also required to get the full code)
Compilation works but I still have some linker issue :
idf.py build
Executing action: all (aliases: build)
Running ninja in directory /home/f/esp/ESP32_MP3_Decoder/build
Executing "ninja all"...
[1/5] Performing build step for 'bootloader'
ninja: no work to do.
[2/3] Linking CXX executable esp32_mp3_decoder.elf
FAILED: esp32_mp3_decoder.elf
: && /home/f/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++  -mlongcalls -Wno-frame-address   CMakeFiles/esp32_mp3_decoder.elf.dir/project_elf_src.c.obj  -o esp32_mp3_decoder.elf  esp-idf/xtensa/libxtensa.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/esp_system/libesp_system.a  esp-idf/soc/libsoc.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/pthread/libpthread.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/perfmon/libperfmon.a  esp-idf/esp32/libesp32.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/asio/libasio.a  esp-idf/bt/libbt.a  esp-idf/cbor/libcbor.a  esp-idf/coap/libcoap.a  esp-idf/console/libconsole.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/esp_adc_cal/libesp_adc_cal.a  esp-idf/esp_gdbstub/libesp_gdbstub.a  esp-idf/esp_hid/libesp_hid.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/esp_https_ota/libesp_https_ota.a  esp-idf/protobuf-c/libprotobuf-c.a  esp-idf/protocomm/libprotocomm.a  esp-idf/mdns/libmdns.a  esp-idf/esp_local_ctrl/libesp_local_ctrl.a  esp-idf/sdmmc/libsdmmc.a  esp-idf/esp_serial_slave_link/libesp_serial_slave_link.a  esp-idf/esp_websocket_client/libesp_websocket_client.a  esp-idf/expat/libexpat.a  esp-idf/wear_levelling/libwear_levelling.a  esp-idf/fatfs/libfatfs.a  esp-idf/freemodbus/libfreemodbus.a  esp-idf/jsmn/libjsmn.a  esp-idf/json/libjson.a  esp-idf/libsodium/liblibsodium.a  esp-idf/mqtt/libmqtt.a  esp-idf/openssl/libopenssl.a  esp-idf/spiffs/libspiffs.a  esp-idf/ulp/libulp.a  esp-idf/unity/libunity.a  esp-idf/wifi_provisioning/libwifi_provisioning.a  esp-idf/main/libmain.a  esp-idf/MerusAudio/libMerusAudio.a  esp-idf/url_parser/liburl_parser.a  esp-idf/http/libhttp.a  esp-idf/fifo/libfifo.a  esp-idf/common/libcommon.a  esp-idf/controls/libcontrols.a  esp-idf/libfaad/liblibfaad.a  esp-idf/libm4a/liblibm4a.a  esp-idf/audio_renderer/libaudio_renderer.a  esp-idf/libfaad_decoder/liblibfaad_decoder.a  esp-idf/fdk-aac/libfdk-aac.a  esp-idf/fdk-aac_decoder/libfdk-aac_decoder.a  esp-idf/mad/libmad.a  esp-idf/mp3_decoder/libmp3_decoder.a  esp-idf/audio_player/libaudio_player.a  esp-idf/inih_port/libinih_port.a  esp-idf/vector/libvector.a  esp-idf/playlist/libplaylist.a  esp-idf/user_driver/libuser_driver.a  esp-idf/ui/libui.a  esp-idf/web_radio/libweb_radio.a  -Wl,--cref -Wl,--Map=/home/f/esp/ESP32_MP3_Decoder/build/esp32_mp3_decoder.map  -fno-rtti  -fno-lto  esp-idf/main/libmain.a  esp-idf/fifo/libfifo.a  esp-idf/common/libcommon.a  esp-idf/libm4a/liblibm4a.a  esp-idf/audio_renderer/libaudio_renderer.a  esp-idf/libfaad_decoder/liblibfaad_decoder.a  esp-idf/fdk-aac_decoder/libfdk-aac_decoder.a  esp-idf/mp3_decoder/libmp3_decoder.a  esp-idf/audio_player/libaudio_player.a  esp-idf/playlist/libplaylist.a  esp-idf/web_radio/libweb_radio.a  esp-idf/asio/libasio.a  esp-idf/cbor/libcbor.a  esp-idf/coap/libcoap.a  esp-idf/esp_adc_cal/libesp_adc_cal.a  esp-idf/esp_gdbstub/libesp_gdbstub.a  esp-idf/esp_hid/libesp_hid.a  esp-idf/esp_https_ota/libesp_https_ota.a  esp-idf/esp_local_ctrl/libesp_local_ctrl.a  esp-idf/esp_serial_slave_link/libesp_serial_slave_link.a  esp-idf/esp_websocket_client/libesp_websocket_client.a  esp-idf/expat/libexpat.a  esp-idf/fatfs/libfatfs.a  esp-idf/sdmmc/libsdmmc.a  esp-idf/wear_levelling/libwear_levelling.a  esp-idf/freemodbus/libfreemodbus.a  esp-idf/jsmn/libjsmn.a  esp-idf/libsodium/liblibsodium.a  esp-idf/mqtt/libmqtt.a  esp-idf/openssl/libopenssl.a  esp-idf/spiffs/libspiffs.a  esp-idf/unity/libunity.a  esp-idf/wifi_provisioning/libwifi_provisioning.a  esp-idf/protocomm/libprotocomm.a  esp-idf/bt/libbt.a  -L/home/f/esp/esp-idf/components/bt/controller/lib  -lbtdm_app  esp-idf/protobuf-c/libprotobuf-c.a  esp-idf/mdns/libmdns.a  esp-idf/console/libconsole.a  esp-idf/json/libjson.a  esp-idf/ui/libui.a  esp-idf/user_driver/libuser_driver.a  esp-idf/MerusAudio/libMerusAudio.a  esp-idf/libfaad/liblibfaad.a  esp-idf/fdk-aac/libfdk-aac.a  esp-idf/mad/libmad.a  esp-idf/inih_port/libinih_port.a  esp-idf/url_parser/liburl_parser.a  esp-idf/http/libhttp.a  esp-idf/url_parser/liburl_parser.a  esp-idf/http/libhttp.a  esp-idf/controls/libcontrols.a  esp-idf/vector/libvector.a  esp-idf/xtensa/libxtensa.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/esp_system/libesp_system.a  esp-idf/soc/libsoc.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/pthread/libpthread.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/perfmon/libperfmon.a  esp-idf/esp32/libesp32.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/ulp/libulp.a  esp-idf/mbedtls/mbedtls/library/libmbedtls.a  esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a  esp-idf/mbedtls/mbedtls/library/libmbedx509.a  esp-idf/soc/soc/esp32/libsoc_esp32.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcore.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libespnow.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libmesh.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libpp.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/librtc.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libphy.a  esp-idf/xtensa/libxtensa.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/esp_system/libesp_system.a  esp-idf/soc/libsoc.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/pthread/libpthread.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/perfmon/libperfmon.a  esp-idf/esp32/libesp32.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/ulp/libulp.a  esp-idf/mbedtls/mbedtls/library/libmbedtls.a  esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a  esp-idf/mbedtls/mbedtls/library/libmbedx509.a  esp-idf/soc/soc/esp32/libsoc_esp32.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcore.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libespnow.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libmesh.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libpp.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/librtc.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libphy.a  esp-idf/xtensa/libxtensa.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/esp_system/libesp_system.a  esp-idf/soc/libsoc.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/pthread/libpthread.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/perfmon/libperfmon.a  esp-idf/esp32/libesp32.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/ulp/libulp.a  esp-idf/mbedtls/mbedtls/library/libmbedtls.a  esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a  esp-idf/mbedtls/mbedtls/library/libmbedx509.a  esp-idf/soc/soc/esp32/libsoc_esp32.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcore.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libespnow.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libmesh.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libpp.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/librtc.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libphy.a  esp-idf/xtensa/libxtensa.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/esp_system/libesp_system.a  esp-idf/soc/libsoc.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/pthread/libpthread.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/perfmon/libperfmon.a  esp-idf/esp32/libesp32.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/ulp/libulp.a  esp-idf/mbedtls/mbedtls/library/libmbedtls.a  esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a  esp-idf/mbedtls/mbedtls/library/libmbedx509.a  esp-idf/soc/soc/esp32/libsoc_esp32.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcore.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libespnow.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libmesh.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libpp.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/librtc.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a  /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libphy.a  /home/f/esp/esp-idf/components/xtensa/esp32/libhal.a  -u esp_app_desc  -L /home/f/esp/esp-idf/components/esp_rom/esp32/ld  -T esp32.rom.newlib-time.ld  -T esp32.rom.ld  -T esp32.rom.libgcc.ld  -T esp32.rom.newlib-data.ld  -T esp32.rom.syscalls.ld  -T esp32.rom.newlib-funcs.ld  -u vfs_include_syscalls_impl  -L /home/f/esp/esp-idf/components/esp_wifi/lib/esp32  -u pthread_include_pthread_impl  -u pthread_include_pthread_cond_impl  -u pthread_include_pthread_local_storage_impl  -L /home/f/esp/ESP32_MP3_Decoder/build/esp-idf/esp32  -T esp32_out.ld  -u app_main  -L /home/f/esp/ESP32_MP3_Decoder/build/esp-idf/esp32/ld  -T esp32.project.ld  -L /home/f/esp/esp-idf/components/esp32/ld  -T esp32.peripherals.ld  -u call_user_start_cpu0  -u ld_include_panic_highint_hdl  -Wl,--gc-sections  -Wl,--undefined=uxTopUsedPriority  -lm  esp-idf/newlib/libnewlib.a  -u newlib_include_locks_impl  -u newlib_include_heap_impl  -u newlib_include_syscalls_impl  -u newlib_include_pthread_impl  -lgcc  -u __cxa_guard_dummy  -lstdc++  esp-idf/pthread/libpthread.a  -u __cxx_fatal_exception  esp-idf/app_trace/libapp_trace.a  -lgcov  esp-idf/app_trace/libapp_trace.a  -lgcov  -lc && :
/home/f/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/audio_player/libaudio_player.a(audio_player.c.obj):(.literal.start_decoder_task+0x8): undefined reference to `fdkaac_decoder_task'
/home/f/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/audio_player/libaudio_player.a(audio_player.c.obj):(.literal.start_decoder_task+0x14): undefined reference to `libfaac_decoder_task'
/home/f/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/audio_player/libaudio_player.a(audio_player.c.obj):(.literal.start_decoder_task+0x20): undefined reference to `mp3_decoder_task'
collect2: error: ld returned 1 exit status
ninja failed with exit code 1
The 3 references correspond to task functions implemented in separate components.
I removed cyclic dependencies, checked that the components are listed in PRIV_REQUIRES using the default components directory tree, checked that the functions are not defined or implemented static. Also I found the compiled static libraries like esp-idf/mp3_decoder/libmp3_decoder.a with references required.
Any help to solve this issue would be appreciated.
florent92
Re: undefined reference to task functions in separate components
Postby florent92 » Fri Jan 15, 2021 10:13 pm
I managed to get rid of this linker issue by removing some dependencies. Still not very clear how to avoid this kind of issue.
The project now compiles and work with ESP-IDF v4.3-dev : https://github.com/fc92/ESP32_MP3_Decoder
funkydunky
Postby funkydunky » Tue Mar 01, 2022 9:45 pm
better late than never.
i did exactly the same as you and had the same troubles. i got rid of this linker problem with
set_property(TARGET ${COMPONENT_LIB} APPEND PROPERTY LINK_INTERFACE_MULTIPLICITY 4)
in the decoder components
