ESP32 would reboot after running for ~3 days
wwll123
Postby wwll123 » Mon Jan 25, 2021 7:36 am
I am running burn-in test for ESP32 with output log. All 4 modules would be rebooted after running for ~3 days with the same assertion error in log.c. Does anyone have any clue about this error?
Module: esp32-wrover-b
ESP-IDF: ESP-IDF v4.1
Error log:
(292721597) AWS: Delta callback end
assertion "i == 0 || s_log_cache[(i - 1) / 2].generation < s_log_cache[i].generation" failed: file "/home/PC1/esp/esp-idf/components/log/log.c", line 209, function: get_cached_log_level
abort() was called at PC 0x400d7d3c on core 1
ELF file SHA256: 013e27b677f0aa2c
Backtrace: 0x400922e9:0x3ffdf7e0 0x40092685:0x3ffdf800 0x400d7d3c:0x3ffdf820 0x401d60d1:0x3ffdf850 0x40097edb:0x3ffdf880 0x401c7aed:0x3ffdf8d0 0x401c6a81:0x3ffdf900 0x401c6aca:0x3ffdf920 0x401c6d1b:0x3ffdf950 0x40094591:0x3ffdf990
Rebooting...
Thanks.
ESP_Minatel
Re: ESP32 would reboot after running for ~3 days
Postby ESP_Minatel » Mon Jan 25, 2021 11:50 am
It looks something related to log cache. Are you using which log level?
wwll123
Postby wwll123 » Tue Jan 26, 2021 1:54 am
In menuconfig:
Bootloader log verbosity: Info
Default baud rate: 921600 bps
'idf.py' monitor baud rate: 921600 bps
UART console baud rate: 921600
In code:
All components are set to ERROR level.
One component is set to INFO level and others are DEBUG level.
AWS is DEBUG level. (most log is from AWS component)
I just don't know why all the devices would be rebooted after ~3 days with the same log.c error.
ESP_Minatel
Postby ESP_Minatel » Tue Jan 26, 2021 9:13 am
No clue about this issue.
I suggest you to open an issue on our GitHub: https://github.com/espressif/esp-idf/issues
Can you do that?
ESP_Minatel
Postby ESP_Minatel » Fri Jan 29, 2021 12:30 pm
Any update on that?
Senseless1972
Postby Senseless1972 » Thu Sep 21, 2023 6:58 am
Got the same isse. Did you find a solution?
Users browsing this forum: No registered users and 257 guests
