Here is my code:
#include <string.h>
#include <stdio.h>
#include "freertos/task.h"
#include "freertos/ringbuf.h"
#include "esp_log.h"
#include "sdkconfig.h"
#include "driver/gpio.h"
#include "mdf_common.h"
#include "mwifi.h"
//#include <FastLED.h>
#include "led_strip.h"
#include "rom/gpio.h"
#define BLINK_GPIO 2
int LedStatus = 0;
int layer = 0;
//Led Setup
#define LED_TYPE LED_STRIP_WS2812
#define LED_GPIO 5
#define LED_CHANNEL RMT_CHANNEL_0
#define LED_STRIP_LEN 4
//Array of colors in Hex form.
static const rgb_t colors[] = {
{ .raw = { 0xff, 0xff, 0xff } },//0 White
{ .raw = { 0x00, 0x00, 0xff } },//1 Blue
{ .raw = { 0x00, 0xff, 0x00 } },//2 Lime
{ .raw = { 0xff, 0x00, 0x00 } },//3 Red
{ .raw = { 0x80, 0x00, 0x00 } },//4 marooon
{ .raw = { 0x80, 0x80, 0x00 } },//5 Olive
{ .raw = { 0xF7, 0xB6, 0x13 } },//6 Orange
{ .raw = { 0xFF, 0x00, 0xFF } },//7 Magenta
{ .raw = { 0x00, 0x80, 0x80 } },//8 Teal
{ .raw = { 0x80, 0x00, 0x80 } },//9 Purple
#define COLORS_TOTAL (sizeof(colors) / sizeof(rgb_t))
// Led setup done
//LED Control function
void HelloWorld(){
printf("Hello world 1 2 3 4 5 6 7 8 9 \n");
void orange(void *pvParameters){
led_strip_t strip = {
.type = LED_TYPE,
.length = LED_STRIP_LEN,
.gpio = LED_GPIO,
.channel = LED_CHANNEL,
.buf = NULL
ESP_ERROR_CHECK(led_strip_init(&strip));
printf("Green and blue \n");
ESP_ERROR_CHECK(led_strip_fill(&strip, 0, strip.length, colors[1]));
ESP_ERROR_CHECK(led_strip_flush(&strip));
vTaskDelay(pdMS_TO_TICKS(1000));
ESP_ERROR_CHECK(led_strip_fill(&strip, 0, strip.length, colors[2]));
// LED control function doen
// #define MEMORY_DEBUG
static const char *TAG = "NODE";
static void receiver_task(void *arg){
MDF_ERROR_ASSERT(esp_wifi_start());
gpio_pad_select_gpio(BLINK_GPIO);
gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
mdf_err_t ret = MDF_OK;
char *data = MDF_MALLOC(MWIFI_PAYLOAD_LEN);
size_t size = MWIFI_PAYLOAD_LEN;
uint8_t src_addr[MWIFI_ADDR_LEN] = {0x0};
mwifi_data_type_t data_type = {0};
MDF_LOGI("Receiver task is running");
#if CONFIG_DEVICE_TYPE != MESH_ROOT
while(mwifi_is_connected() == false) {
vTaskDelay(500 / portTICK_RATE_MS);
ESP_LOGI(TAG, "[Wait for root connected");
continue;
#endif
for (int i = 0;; --i)
memset(data, 0, MWIFI_PAYLOAD_LEN);
ESP_LOGI(TAG, "Receive...");
ret = mwifi_read(src_addr, &data_type, data, &size, portMAX_DELAY);
ESP_LOGI(TAG, "Received data: %s", data);
MDF_ERROR_CONTINUE(ret != MDF_OK, "<%s> mwifi_read", mdf_err_to_name(ret));
vTaskDelay(100 / portTICK_RATE_MS);
LedStatus = data;
if (LedStatus % 2 == 0)
// mwifi_print_config(); //Prints all Network Info (Alot)
layer = esp_mesh_get_layer();
printf("The layer is = %d and i = %d \n", layer, i);
printf(" %s is Dicisiable by 2 \n", data);
printf(" On \n " );
gpio_set_level(BLINK_GPIO, 1);
vTaskDelay(100);
gpio_set_level(BLINK_GPIO, 0);
if (i <= -10){
printf("i is now below -10 Now brekaing loop \n");
HelloWorld();
//MDF_ERROR_ASSERT(esp_wifi_stop());
// vTaskDelete(NULL);
i=0;
MDF_LOGW("Receiver task is exit");
MDF_FREE(data);
vTaskDelete(NULL);
static mdf_err_t wifi_init()
printf("wifi_init \n");
mdf_err_t ret = nvs_flash_init();
MDF_ERROR_ASSERT(nvs_flash_erase());
MDF_ERROR_ASSERT(ret);
tcpip_adapter_init();
MDF_ERROR_ASSERT(esp_event_loop_init(NULL, NULL));
MDF_ERROR_ASSERT(esp_wifi_init(&cfg));
MDF_ERROR_ASSERT(esp_wifi_set_storage(WIFI_STORAGE_RAM));
MDF_ERROR_ASSERT(esp_wifi_set_mode(WIFI_MODE_STA));
MDF_ERROR_ASSERT(esp_wifi_set_ps(WIFI_PS_NONE));
MDF_ERROR_ASSERT(esp_mesh_set_6m_rate(false));
return MDF_OK;
* @brief All module events will be sent to this task in esp-mdf
* @Note:
* 1. Do not block or lengthy operations in the callback function.
* 2. Do not consume a lot of memory in the callback function.
* The task memory of the callback function is only 4KB.
static mdf_err_t event_loop_cb(mdf_event_loop_t event, void *ctx)
printf("Event_Loop_cb \n");
MDF_LOGI("event_loop_cb, event: %d", event);
switch (event) {
case MDF_EVENT_MWIFI_STARTED:
MDF_LOGI("MESH is started");
case MDF_EVENT_MWIFI_PARENT_CONNECTED:
MDF_LOGI("Parent is connected on station interface");
case MDF_EVENT_MWIFI_PARENT_DISCONNECTED:
MDF_LOGI("Parent is disconnected on station interface");
default:
return MDF_OK;
void app_main()
mwifi_init_config_t cfg = MWIFI_INIT_CONFIG_DEFAULT();
mwifi_config_t config = {
.channel = CONFIG_MESH_CHANNEL,
.mesh_id = CONFIG_MESH_ID,
.mesh_type = MESH_NODE,
//.mesh_type = CONFIG_DEVICE_TYPE,
printf("Hello Have I looped yet ? ========== \n ");
* @brief Set the log level for serial port printing.
esp_log_level_set("*", ESP_LOG_INFO);
esp_log_level_set(TAG, ESP_LOG_DEBUG);
* @brief Initialize wifi mesh.
MDF_ERROR_ASSERT(mdf_event_loop_init(event_loop_cb));
MDF_ERROR_ASSERT(wifi_init());
MDF_ERROR_ASSERT(mwifi_init(&cfg));
MDF_ERROR_ASSERT(mwifi_set_config(&config));
MDF_ERROR_ASSERT(mwifi_start());
mesh_addr_t group_id = { .addr = {0xa8, 0x03, 0x2a, 0xc0, 0x46, 0x44}}; // 18-3-12-12-10-8
ESP_ERROR_CHECK(esp_mesh_set_group_id(&group_id,1));
/*** Receiver start ***/
xTaskCreate(receiver_task, "receiver_task", 16 * 1024, NULL, CONFIG_MDF_TASK_DEFAULT_PRIOTY, NULL);
printf("Hello Have I looped yet ? -----------------------------------------\n ");
// buzzerControler();
I (32673) mesh: 5118<active>parent layer:1(node), channel:13, rssi:-58, assoc:1(cnx rssi threshold:-120)my_assoc:0
I (34177) mesh: 5909<scan>parent layer:1, rssi:-59, assoc:1(cnx rssi threshold:-120)
I (34178) mesh: [SCAN][ch:13]AP:1, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:0,i:2][00:00:00:00:00:00][FIXED-ROOT]<weak>
I (34187) mesh: 7333[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85>
I (34195) mesh: 701[monitor]no change, parent:a8:03:2a:c0:46:45, rssi:-59
I (34201) mesh: 1990<arm>parent monitor, my layer:2(cap:16)(node), interval:10395ms, retries:3<>
I (44856) mesh: 5118<active>parent layer:1(node), channel:13, rssi:-58, assoc:1(cnx rssi threshold:-120)my_assoc:0
I (46360) mesh: 5909<scan>parent layer:1, rssi:-60, assoc:1(cnx rssi threshold:-120)
I (46361) mesh: [SCAN][ch:13]AP:1, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:2,i:2][00:00:00:00:00:00][FIXED-ROOT]<weak>
I (46370) mesh: 7333[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85>
I (46377) mesh: 701[monitor]no change, parent:a8:03:2a:c0:46:45, rssi:-60
I (46384) mesh: 1990<arm>parent monitor, my layer:2(cap:16)(node), interval:323319ms, retries:3<>
