Problem with reboot W/O backtrace on ESP32 - esp-idf 3.0.9
brazoayeye
Postby brazoayeye » Tue Feb 16, 2021 10:38 am
Hello, I have a problem in an esp32 that crashes and reboot every ~10h for an irs interrupt without writing the problem:
ets Jun  8 2016 00:22:57
rst:0x8 (TG1WDT_SYS_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5560
load:0x40078000,len:12568
entry 0x40078fe8
[0;33mW (26) boot: PRO CPU has been reset by WDT.[0m
[0;33mW (27) boot: WDT reset info: PRO CPU PC=0x400840d6[0m
[0;33mW (27) boot: WDT reset info: APP CPU PC=0x400faf86[0m
[0;32mI (33) boot: ESP-IDF v3.0.9-dirty 2nd stage bootloader[0m
I tried to change the interrupt watchdog timeout from 300ms to 1000ms or to 50ms without noticeable differences.
I also enabled the core dump from menuconfig, but nothing is printed before the reboot.
How can I have information regarding the problem that blocked the interrupt?
I have different tasks running on the device, but most of the code is running without interrupts. The device is communicating with an UART device, connected to wifi and sending information to an MQTT broker.
illy@scharco.de
Re: Problem with reboot W/O backtrace on ESP32 - esp-idf 3.0.9
Postby illy@scharco.de » Mon Apr 12, 2021 1:14 pm
I am also trying to find an WiFi issue, I get
when running esp-idf example softAP.
Working on ESP32WROOM powered with LSH14 battery and buckboost, I can send MQTT messages with a SIM7070 Modem, so I don't think it is a HW problem (since modem can take 2A peak).
Aim is to work in deepsleep mode but no display so all configurations will take part on webserver.
I (615) wifi_init: WiFi RX IRAM OP enabled
I (625) phy_init: phy_version 4660,0162888,Dec 23 2020
load:0x3fff001c,len:6776
load:0x40078000,len:12152
load:0x40080400,len:6664
entry 0x40080774
I (113) boot: Chip Revision: 1
I (131) boot_comm: chip revision: 1, min. bootloader chip revision: 0
W (79) boot: PRO CPU has been reset by WDT.
W (80) boot: WDT reset info: PRO CPU PC=0x40003611
W (80) boot: WDT reset info: APP CPU PC=0x9279c147
I (86) boot: ESP-IDF v3.3.5 2nd stage bootloader
I (91) boot: compile time 15:01:22
I (96) boot: Enabling RNG early entropy source...
I (101) boot: SPI Speed : 40MHz
I (105) boot: SPI Mode : DIO
I (109) boot: SPI Flash Size : 4MB
I (113) boot: Partition Table:
I (117) boot: ## Label Usage Type ST Offset Length
I (124) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (132) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (139) boot: 2 factory factory app 00 00 00010000 00100000
I (147) boot: End of partition table
I (151) boot_comm: chip revision: 1, min. application chip revision: 0
I (158) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x14d18 ( 85272) map
I (197) esp_image: segment 1: paddr=0x00024d40 vaddr=0x3ffb0000 size=0x0277c ( 10108) load
I (201) esp_image: segment 2: paddr=0x000274c4 vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at C:/msys32/home/illy/esp/esp-idf/components/freertos/xtensa_vectors.S:1779
I (204) esp_image: segment 3: paddr=0x000278cc vaddr=0x40080400 size=0x08744 ( 34628) load
I (227) esp_image: segment 4: paddr=0x00030018 vaddr=0x400d0018 size=0x5e8c8 (387272) map
0x400d0018: _stext at ??:?
I (363) esp_image: segment 5: paddr=0x0008e8e8 vaddr=0x40088b44 size=0x0a4b4 ( 42164) load
0x40088b44: xQueueGenericReceive at C:/msys32/home/illy/esp/esp-idf/components/freertos/queue.c:2038
I (392) boot: Loaded app from partition at offset 0x10000
I (392) boot: Disabling RNG early entropy source...
I (393) cpu_start: cpu freq: 80
I (396) cpu_start: Pro cpu up.
I (400) cpu_start: Application information:
I (405) cpu_start: Project name: wifi_softAP
I (410) cpu_start: App version: 1
I (415) cpu_start: Compile time: Apr 12 2021 14:59:58
I (421) cpu_start: ELF file SHA256: b91c8d666bc25074...
I (427) cpu_start: ESP-IDF: v3.3.5
I (431) cpu_start: Single core mode
I (436) heap_init: Initializing. RAM available for dynamic allocation:
I (443) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (449) heap_init: At 3FFB7D48 len 000282B8 (160 KiB): DRAM
I (455) heap_init: At 3FFE0440 len 0001FBC0 (126 KiB): D/IRAM
I (462) heap_init: At 40078000 len 00008000 (32 KiB): IRAM
I (468) heap_init: At 40092FF8 len 0000D008 (52 KiB): IRAM
I (474) cpu_start: Pro cpu start user code
I (492) cpu_start: Starting scheduler on PRO CPU.
I (515) wifi softAP: ESP_WIFI_MODE_AP
I (525) wifi:wifi driver task: 3ffbda90, prio:23, stack:3584, core=0
I (525) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (545) wifi:wifi firmware version: dc30037
I (545) wifi:config NVS flash: enabled
I (545) wifi:config nano formating: disabled
I (545) wifi:Init data frame dynamic rx buffer num: 32
I (555) wifi:Init management frame dynamic rx buffer num: 32
I (555) wifi:Init management short buffer num: 32
I (565) wifi:Init dynamic tx buffer num: 32
I (565) wifi:Init static rx buffer size: 1600
I (575) wifi:Init static rx buffer num: 10
I (575) wifi:Init dynamic rx buffer num: 32
I (575) wifi_init: rx ba win: 6
I (585) wifi_init: tcpip mbox: 32
I (585) wifi_init: udp mbox: 6
I (595) wifi_init: tcp mbox: 6
I (595) wifi_init: tcp tx win: 5744
I (595) wifi_init: tcp rx win: 5744
I (605) wifi_init: tcp mss: 1436
I (605) wifi_init: WiFi IRAM OP enabled
and so on, no way I can debugging anything.
Would have someone here a clue?
Best regards
illy@scharco.de
Postby illy@scharco.de » Mon Apr 12, 2021 2:15 pm
I just try the station example on esp-idf and I get the following error:
I (0) cpu_start: App cpu up.
I (449) heap_init: Initializing. RAM available for dynamic allocation:
I (456) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (462) heap_init: At 3FFB8620 len 000279E0 (158 KiB): DRAM
I (469) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (475) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (481) heap_init: At 40093B70 len 0000C490 (49 KiB): IRAM
I (488) cpu_start: Pro cpu start user code
rst:0x10 (RTCWDT_RTC_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
entry 0x40080774
I (72) boot: Chip Revision: 1
I (72) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (39) boot: ESP-IDF v3.3.5 2nd stage bootloader
I (39) boot: compile time 15:28:18
I (40) boot: Enabling RNG early entropy source...
I (44) boot: SPI Speed : 40MHz
I (48) boot: SPI Mode : DIO
I (52) boot: SPI Flash Size : 4MB
I (56) boot: Partition Table:
I (60) boot: ## Label Usage Type ST Offset Length
I (67) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (74) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (82) boot: 2 factory factory app 00 00 00010000 00100000
I (89) boot: End of partition table
I (94) boot_comm: chip revision: 1, min. application chip revision: 0
I (101) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x180f8 ( 98552) map
I (144) esp_image: segment 1: paddr=0x00028120 vaddr=0x3ffb0000 size=0x02fa0 ( 12192) load
I (149) esp_image: segment 2: paddr=0x0002b0c8 vaddr=0x40080000 size=0x00400 ( 1024) load
I (151) esp_image: segment 3: paddr=0x0002b4d0 vaddr=0x40080400 size=0x04b40 ( 19264) load
I (168) esp_image: segment 4: paddr=0x00030018 vaddr=0x400d0018 size=0x5ed90 (388496) map
I (305) esp_image: segment 5: paddr=0x0008edb0 vaddr=0x40084f40 size=0x0ec30 ( 60464) load
0x40084f40: phy_en_hw_set_freq at /home/cff/gittree/chip7.1_phy/chip_7.1/board_code/app_test/pp/phy/phy_chip_v7_ana.c:349
I (342) boot: Loaded app from partition at offset 0x10000
I (342) boot: Disabling RNG early entropy source...
I (343) cpu_start: cpu freq: 160
I (346) cpu_start: Pro cpu up.
I (350) cpu_start: Application information:
I (355) cpu_start: Project name: wifi_station
I (360) cpu_start: App version: 1
I (365) cpu_start: Compile time: Apr 12 2021 15:26:31
I (371) cpu_start: ELF file SHA256: 0a134358c5ec9057...
I (377) cpu_start: ESP-IDF: v3.3.5
I (382) cpu_start: Starting app cpu, entry point is 0x40081170
0x40081170: call_start_cpu1 at C:/msys32/home/illy/esp/esp-idf/components/esp32/cpu_start.c:274
I (392) heap_init: Initializing. RAM available for dynamic allocation:
I (399) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (405) heap_init: At 3FFB8620 len 000279E0 (158 KiB): DRAM
I (411) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (418) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (424) heap_init: At 40093B70 len 0000C490 (49 KiB): IRAM
I (430) cpu_start: Pro cpu start user code
I (113) cpu_start: Starting scheduler on PRO CPU.
I (176) wifi station: ESP_WIFI_MODE_STA
I (186) wifi:wifi driver task: 3ffc0324, prio:23, stack:3584, core=0
I (186) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (226) wifi:wifi firmware version: dc30037
I (226) wifi:config NVS flash: enabled
I (226) wifi:config nano formating: disabled
I (226) wifi:Init data frame dynamic rx buffer num: 32
I (226) wifi:Init management frame dynamic rx buffer num: 32
I (236) wifi:Init management short buffer num: 32
I (236) wifi:Init dynamic tx buffer num: 32
I (246) wifi:Init static rx buffer size: 1600
I (246) wifi:Init static rx buffer num: 10
I (246) wifi:Init dynamic rx buffer num: 32
I (256) wifi_init: rx ba win: 6
I (256) wifi_init: tcpip mbox: 32
I (266) wifi_init: udp mbox: 6
I (266) wifi_init: tcp mbox: 6
I (266) wifi_init: tcp tx win: 5744
I (276) wifi_init: tcp rx win: 5744
I (276) wifi_init: tcp mss: 1440
I (286) wifi_init: WiFi IRAM OP enabled
I (286) wifi_init: WiFi RX IRAM OP enabled
I (296) phy_init: phy_version 4660,0162888,Dec 23 2020
I (396) wifi:mode : sta (ac:67:b2:4��&&'LLJC��+L�&�[R��396) wifi station: wifi_init_sta finished.
I (396) wifi station: connect to ap SSID:Scharco passord:11enhabe�[��+L[���B���J�����r�����b��bz�����b��b
������b����b������b��b������j��
��S%�W-V-�.]X�Y��init -> auth (b0)
Interrupt wdt timeout on CPU0Core0 register dump:
PC 08c4 PS 06b4 A0 0d49 A1 fbb0 : 0x3f03: 0x0000: 0x8081: 0x3fa8
A6 0003 A7 0603 A8 00bb A9 00dd : 0xb3ff: 0x00aa: 0x0002: 0x0000
A14 06b0 A15 0000 SAR 0000 EXCCAUSE0005 : 0x0000: 0x0000: 0x0000: 0x0000
ELF file SHA256:
0x4079fbb00d46:0x3fa6 0x4015fbb00d19:0x3fab 0x4086fbb008d2:0x3faf
Core1 register dump:
PC 0d01 PS 0614 A0 0d45 A1 fb20 : 0x3fbd: 0x3fbd: 0x8081: 0x3fbf
A6 0003 A7 0603 A8 f500 A9 0001 : 0x3fbe: 0x0002: 0x0002: 0x0000
A14 0610 A15 0603 SAR 0000 EXCCAUSE0005 : 0x0000: 0x0000: 0x0000: 0x0000
ELF file SHA256:
0x4015fb200d42:0x3fbd 0x4015fb300d19:0x3fb2 0x4086fb3008d2:0x3fb6
Rebooting...
I am applying 3.6V on VIN with 1A limit on a power supply so it can't come from power supply I guess.
I am now clueless (ESP IDF v3.3.5), flash erased all cleaned....
Any suggestion?
ESP_Sprite
Postby ESP_Sprite » Tue Apr 13, 2021 1:53 am
Still sounds like a power issue, to be honest...
VIN? Of what devboard? Many devboards have a regulator that requires a larger voltage difference between Vin and the output 3.3V. For instance, the AMS1117 common on most devboards requires 1.15V, meaning the board may not work right if Vin is smaller than 4.45V.
illy@scharco.de
Postby illy@scharco.de » Tue Apr 13, 2021 8:14 am
Hello ESP_Sprite,
well I have a power supply set on 3,5V with current limit 1A directly on 3V3.
We are making various custom PCBs with ESP32WROOM. On one of the last boards I have cut all lines from ESP32WROOM, so there are only RX0,TX0, BOOT, EN and supply (3V5 on 3V3 because there is also a modem, now unconnected, which need some more voltage).
I never had this WiFi problem before :).
Now I am only trying softAP and Station example from esp-idf-v3.3.5 (all other functions like deep sleep, wakeup, timer, ulp co pro, uart und touch are working fine).
Result are:
for station:
I (207) wifi_init: WiFi RX IRAM OP enabled
I (217) phy_init: phy_version 4660,0162888,Dec 23 2020
I (297) wifi:mode : sta (ac:67:b2:4a:52:08)
[0���j%�B���J�����������������}����}����2����������j5R�����j%�B���J�����������������������
���M%��������������������*����������j5R�I (417) wifi:new:<1,0>, old:<1�X ap:<����255>, sta:<1,0>, prof:1
I (417) wifi:sta����init -> auth (b0)
and nothing else or
���M%��������������������*������5���������������r��������������
�r����Rz��*������R���������
������2���R$��2��
������j �����������
�����������*�R���2��
��2�������*�
5��2���jE�������������% I������5UU
����R�eEJ ��*�bU I����2�*������"�b=9���2����jjTe��J���&Y����,!�X-�,'H^��e5x3fb810080f60 x40e4x3fb86000b30f60 x4017d:x3fb80052f0f6c0x4097a:x3fb80
05b0f70 x40d6:x3fb8300c3f0f70 x40d3:x3fb8a008650fa0 x40d21:x3fb8a00910f0 x40d27:x3fb8c0000fa0 x408a:x3fb8c
eotn..
entry 0x40080774
for softAP:
I (629) phy_init: phy_version 4660,0162888,Dec 23 2020
I (729) wifi:mode : softAP (ac:67:b2:4a:52:09)
I (729) wifi:Total power save buffer number: 16
I (72�������Z�Z�R�Z��max length of beacon: 752/752
I (729) wifi:Init max length of beacon: 752/752
I (739) wifi softAP: wifi_init_softap finished. SSID:PREM_KP password:12345678 channel:1
and nothing else or (I could see once the AP PREM_KP but not able to connect)
I (669) wifi:mode : softAP (ac:67:b2:4a:52:09)
I (679) wifi:Total power save buffer number: 16
I (679��������J����j���b������z�����������z���j��
��S�%HW-V-�R+�R+�b������z�����������z���j������j%�B���J���������A�����}����}�������2���������5��J�%U���
��������������������������j5R�������]������Aa`���������$��t�����Hj�z�������
��������%uy�U����.�W�
�K�Y@����a�g�U����������ets Jun 8 2016 00:22:57
flash read err, 1000
ets_main.c 371
I have already made erase flash, cleaned, played with menuconfig... with no success.
illy@scharco.de
Postby illy@scharco.de » Tue Apr 13, 2021 8:43 am
and I get often this last thread:
I (726) wifi:mode : softAP (ac:67:b2:4a:52:09)
I (731) wifi:Total power save buffer number: 16
I (73�������������:Init max length of beacon: 752/752
I (732) wifi:Init max length of beacon: 752/752
I (738) Premiertech: SYSTEM_EVENT_AP_START
and then nothing happens anymore... :(
illy@scharco.de
Postby illy@scharco.de » Tue Apr 13, 2021 9:21 am
What alos weird is, is that the next task (just print a timer counter) doesn't fired, as if CPU hangs in wifi_start():
I (731) ������`i:Init max length of beacon: 752/752
I (740) Premiertech: wifi_init_softap finished. SSID:PREM_KP password:PREM2020 channel:0
illy@scharco.de
Postby illy@scharco.de » Tue Apr 13, 2021 12:07 pm
I rechecked all voltage levels with & without buck boost, I have now fixed 3.5V on ESP32 (max 3.6V in datasheet).
I could connect twice to softAP but Wifi makes all system hanging and I can't see anything on monitor just frozen.
I (735) wifi:mode : softAP (ac:67:b2:4a:ef:f1)
I (739) wifi:Total power save buffer number: 16
I (740) wifi:Init max length of beacon: 752/752
I (741) wifi:Init max length of beacon: 752/752
I (746) Premiertech: SYSTEM_EVENT_AP_START
I (748) Premiertech: wifi_init_softap finished. SSID:PREM_KP password:PREM2020 channel:0
time before sleep: 53s
stops randomly (hier @ 53s).
sometimes I can connect but then same behaviour, jsut reset helps:
time before sleep: 52sI (9077) wifi:new:<1,1>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (9079) wifi:station: dc:4e:f4:08:66:0a join, AID=1, bgn, 40U
I (9104) Premiertech: SYSTEM_EVENT_STA_CONNECTED_TO_AP: start webserver
I (9143) tcpip_adapter: softAP assign IP to station,IP is: 192.168.4.2
I (9144) Premiertech: === WiFi EVENT: 18 ===
time before sleep: 47sets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
Every clue is now welcome after third day of debuging... :)
ESP_Sprite
Postby ESP_Sprite » Wed Apr 14, 2021 1:09 am
Do you have enough decoupling on your voltage lines? Especially with a slow-reacting power supply, putting a few uF near the ESP32 itself may help.
(Also, only just saw you're using ESP-IDF 3.0 - that one went out of support a while ago. Not saying it'll solve your issue, but you may want to think of changing to a more recent version.)
illy@scharco.de
Wifi initialization freezes ESP32 - esp-idf 3.3.5
Postby illy@scharco.de » Wed Apr 14, 2021 6:46 am
Hello ESP_Sprite,
I will double capacitor then. What I have seen is that :
- when I only pull EN down to restart ESP, wifi task will freeze (same behaviour after deep_sleep wake-up)
I can see garbage in monitor
I (5749) wifi:mode : softAP (ac:67:b2:4a:ef:f1)
I (5749) wifi:Total power save buffer number: 16
I (57������fi:Init max length of beacon: 752/752
I (5759) wifi:Init max length of beacon: 752/752
- when I shut the power supply down and let capacitors discharging under 3V, wifi will work when I reactivate the power supply.
Here is the monitor clean
I (5869) wifi:mode : softAP (ac:67:b2:4a:ef:f1)
I (5869) wifi:Total power save buffer number: 16
I (5869) wifi:Init max length of beacon: 752/752
My EPS-IDF is v3.3.5 (I reedit the subject name) :)
Users browsing this forum: No registered users and 230 guests
