PPPoS example problem: AT mode and Data mode switching not working
Palonso
Postby Palonso » Fri Feb 19, 2021 9:22 pm
I'm trying to run the PPPoS example but I'm trying to implement "data_mode <=> command_mode" switching.
I'm using an ESP-WROVER-B (16MB version) and a BG96 modem.
I modified the code like this:
/* PPPoS Client Example
#include <string.h>
#include "esp_netif.h"
#include "esp_netif_ppp.h"
#include "mqtt_client.h"
#include "esp_modem.h"
#include "esp_modem_netif.h"
#include "esp_log.h"
#include "sim800.h"
#include "bg96.h"
#include "sim7600.h"
#define BROKER_URL "mqtt://broker.hivemq.com:1883"
static const char *TAG = "pppos_example";
static EventGroupHandle_t event_group = NULL;
static const int CONNECT_BIT = BIT0;
static const int STOP_BIT = BIT1;
static const int GOT_DATA_BIT = BIT2;
#if CONFIG_EXAMPLE_SEND_MSG
 * @brief This example will also show how to send short message using the infrastructure provided by esp modem library.
 * @note Not all modem support SMG.
static esp_err_t example_default_handle(modem_dce_t *dce, const char *line)
    esp_err_t err = ESP_FAIL;
    if (strstr(line, MODEM_RESULT_CODE_SUCCESS)) {
        err = esp_modem_process_command_done(dce, MODEM_STATE_SUCCESS);
    } else if (strstr(line, MODEM_RESULT_CODE_ERROR)) {
        err = esp_modem_process_command_done(dce, MODEM_STATE_FAIL);
    return err;
static esp_err_t example_handle_cmgs(modem_dce_t *dce, const char *line)
    } else if (!strncmp(line, "+CMGS", strlen("+CMGS"))) {
        err = ESP_OK;
    return err;
#define MODEM_SMS_MAX_LENGTH (128)
#define MODEM_COMMAND_TIMEOUT_SMS_MS (120000)
#define MODEM_PROMPT_TIMEOUT_MS (10)
static esp_err_t example_send_message_text(modem_dce_t *dce, const char *phone_num, const char *text)
    modem_dte_t *dte = dce->dte;
    dce->handle_line = example_default_handle;
    /* Set text mode */
    if (dte->send_cmd(dte, "AT+CMGF=1\r", MODEM_COMMAND_TIMEOUT_DEFAULT) != ESP_OK) {
        ESP_LOGE(TAG, "send command failed");
        goto err;
    if (dce->state != MODEM_STATE_SUCCESS) {
        ESP_LOGE(TAG, "set message format failed");
        goto err;
    ESP_LOGD(TAG, "set message format ok");
    /* Specify character set */
    if (dte->send_cmd(dte, "AT+CSCS=\"GSM\"\r", MODEM_COMMAND_TIMEOUT_DEFAULT) != ESP_OK) {
        goto err;
        ESP_LOGE(TAG, "set character set failed");
        goto err;
    ESP_LOGD(TAG, "set character set ok");
    /* send message */
    char command[MODEM_SMS_MAX_LENGTH] = {0};
    int length = snprintf(command, MODEM_SMS_MAX_LENGTH, "AT+CMGS=\"%s\"\r", phone_num);
    /* set phone number and wait for "> " */
    dte->send_wait(dte, command, length, "\r\n> ", MODEM_PROMPT_TIMEOUT_MS);
    /* end with CTRL+Z */
    snprintf(command, MODEM_SMS_MAX_LENGTH, "%s\x1A", text);
    dce->handle_line = example_handle_cmgs;
    if (dte->send_cmd(dte, command, MODEM_COMMAND_TIMEOUT_SMS_MS) != ESP_OK) {
        goto err;
        ESP_LOGE(TAG, "send message failed");
        goto err;
    ESP_LOGD(TAG, "send message ok");
    return ESP_OK;
err:
    return ESP_FAIL;
#endif
static void modem_event_handler(void *event_handler_arg, esp_event_base_t event_base, int32_t event_id, void *event_data)
    switch (event_id) {
    case ESP_MODEM_EVENT_PPP_START:
        ESP_LOGI(TAG, "Modem PPP Started");
    case ESP_MODEM_EVENT_PPP_STOP:
        ESP_LOGI(TAG, "Modem PPP Stopped");
        xEventGroupSetBits(event_group, STOP_BIT);
    case ESP_MODEM_EVENT_UNKNOWN:
        ESP_LOGW(TAG, "Unknow line received: %s", (char *)event_data);
    default:
static esp_err_t mqtt_event_handler(esp_mqtt_event_handle_t event)
    esp_mqtt_client_handle_t client = event->client;
    int msg_id;
    switch (event->event_id) {
    case MQTT_EVENT_CONNECTED:
        ESP_LOGI(TAG, "MQTT_EVENT_CONNECTED");
        msg_id = esp_mqtt_client_subscribe(client, "tretre", 0);
        ESP_LOGI(TAG, "sent subscribe successful, msg_id=%d", msg_id);
    case MQTT_EVENT_DISCONNECTED:
        ESP_LOGI(TAG, "MQTT_EVENT_DISCONNECTED");
    case MQTT_EVENT_SUBSCRIBED:
        ESP_LOGI(TAG, "MQTT_EVENT_SUBSCRIBED, msg_id=%d", event->msg_id);
        msg_id = esp_mqtt_client_publish(client, "tretre", "esp32-pppos", 0, 0, 0);
        ESP_LOGI(TAG, "sent publish successful, msg_id=%d", msg_id);
    case MQTT_EVENT_UNSUBSCRIBED:
        ESP_LOGI(TAG, "MQTT_EVENT_UNSUBSCRIBED, msg_id=%d", event->msg_id);
    case MQTT_EVENT_PUBLISHED:
        ESP_LOGI(TAG, "MQTT_EVENT_PUBLISHED, msg_id=%d", event->msg_id);
    case MQTT_EVENT_DATA:
        ESP_LOGI(TAG, "MQTT_EVENT_DATA");
        printf("TOPIC=%.*s\r\n", event->topic_len, event->topic);
        printf("DATA=%.*s\r\n", event->data_len, event->data);
        xEventGroupSetBits(event_group, GOT_DATA_BIT);
    case MQTT_EVENT_ERROR:
        ESP_LOGI(TAG, "MQTT_EVENT_ERROR");
    default:
        ESP_LOGI(TAG, "MQTT other event id: %d", event->event_id);
    return ESP_OK;
static void on_ppp_changed(void *arg, esp_event_base_t event_base,
    ESP_LOGI(TAG, "PPP state changed event %d", event_id);
    if (event_id == NETIF_PPP_ERRORUSER) {
        /* User interrupted event from esp-netif */
        esp_netif_t *netif = *(esp_netif_t**)event_data;
        ESP_LOGI(TAG, "User interrupted event from netif:%p", netif);
static void on_ip_event(void *arg, esp_event_base_t event_base,
    ESP_LOGD(TAG, "IP event! %d", event_id);
    if (event_id == IP_EVENT_PPP_GOT_IP) {
        esp_netif_dns_info_t dns_info;
        ip_event_got_ip_t *event = (ip_event_got_ip_t *)event_data;
        esp_netif_t *netif = event->esp_netif;
        ESP_LOGI(TAG, "Modem Connect to PPP Server");
        ESP_LOGI(TAG, "~~~~~~~~~~~~~~");
        ESP_LOGI(TAG, "IP          : " IPSTR, IP2STR(&event->ip_info.ip));
        ESP_LOGI(TAG, "Netmask     : " IPSTR, IP2STR(&event->ip_info.netmask));
        ESP_LOGI(TAG, "Gateway     : " IPSTR, IP2STR(&event->ip_info.gw));
        esp_netif_get_dns_info(netif, 0, &dns_info);
        ESP_LOGI(TAG, "Name Server1: " IPSTR, IP2STR(&dns_info.ip.u_addr.ip4));
        esp_netif_get_dns_info(netif, 1, &dns_info);
        ESP_LOGI(TAG, "Name Server2: " IPSTR, IP2STR(&dns_info.ip.u_addr.ip4));
        xEventGroupSetBits(event_group, CONNECT_BIT);
        ESP_LOGI(TAG, "GOT ip event!!!");
    } else if (event_id == IP_EVENT_PPP_LOST_IP) {
        ESP_LOGI(TAG, "Modem Disconnect from PPP Server");
    } else if (event_id == IP_EVENT_GOT_IP6) {
        ESP_LOGI(TAG, "GOT IPv6 event!");
        ip_event_got_ip6_t *event = (ip_event_got_ip6_t *)event_data;
        ESP_LOGI(TAG, "Got IPv6 address " IPV6STR, IPV62STR(event->ip6_info.ip));
void app_main(void)
#if CONFIG_LWIP_PPP_PAP_SUPPORT
    esp_netif_auth_type_t auth_type = NETIF_PPP_AUTHTYPE_PAP;
#elif CONFIG_LWIP_PPP_CHAP_SUPPORT
    esp_netif_auth_type_t auth_type = NETIF_PPP_AUTHTYPE_CHAP;
#elif !defined(CONFIG_EXAMPLE_MODEM_PPP_AUTH_NONE)
#error "Unsupported AUTH Negotiation"
#endif
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, ESP_EVENT_ANY_ID, &on_ip_event, NULL));
    ESP_ERROR_CHECK(esp_event_handler_register(NETIF_PPP_STATUS, ESP_EVENT_ANY_ID, &on_ppp_changed, NULL));
    event_group = xEventGroupCreate();
    /* create dte object */
    esp_modem_dte_config_t config = ESP_MODEM_DTE_DEFAULT_CONFIG();
    /* setup UART specific configuration based on kconfig options */
    config.tx_io_num = CONFIG_EXAMPLE_MODEM_UART_TX_PIN;
    config.rx_io_num = CONFIG_EXAMPLE_MODEM_UART_RX_PIN;
    config.rts_io_num = CONFIG_EXAMPLE_MODEM_UART_RTS_PIN;
    config.cts_io_num = CONFIG_EXAMPLE_MODEM_UART_CTS_PIN;
    config.rx_buffer_size = CONFIG_EXAMPLE_MODEM_UART_RX_BUFFER_SIZE;
    config.tx_buffer_size = CONFIG_EXAMPLE_MODEM_UART_TX_BUFFER_SIZE;
    config.pattern_queue_size = CONFIG_EXAMPLE_MODEM_UART_PATTERN_QUEUE_SIZE;
    config.event_queue_size = CONFIG_EXAMPLE_MODEM_UART_EVENT_QUEUE_SIZE;
    config.event_task_stack_size = CONFIG_EXAMPLE_MODEM_UART_EVENT_TASK_STACK_SIZE;
    config.event_task_priority = CONFIG_EXAMPLE_MODEM_UART_EVENT_TASK_PRIORITY;
    config.line_buffer_size = CONFIG_EXAMPLE_MODEM_UART_RX_BUFFER_SIZE / 2;
    modem_dte_t *dte = esp_modem_dte_init(&config);
    /* Register event handler */
    ESP_ERROR_CHECK(esp_modem_set_event_handler(dte, modem_event_handler, ESP_EVENT_ANY_ID, NULL));
    // Init netif object
    esp_netif_config_t cfg = ESP_NETIF_DEFAULT_PPP();
    esp_netif_t *esp_netif = esp_netif_new(&cfg);
    assert(esp_netif);
    void *modem_netif_adapter;
    // void *modem_netif_adapter = esp_modem_netif_setup(dte);
    // esp_modem_netif_set_default_handlers(modem_netif_adapter, esp_netif);
    while (1) {
        modem_dce_t *dce = NULL;
        /* create dce object */
        dce = bg96_init(dte);
        assert(dce != NULL);
        ESP_ERROR_CHECK(dce->set_flow_ctrl(dce, MODEM_FLOW_CONTROL_NONE));
        ESP_ERROR_CHECK(dce->store_profile(dce));
        /* Print Module ID, Operator, IMEI, IMSI */
        ESP_LOGI(TAG, "Module: %s", dce->name);
        ESP_LOGI(TAG, "Operator: %s", dce->oper);
        ESP_LOGI(TAG, "IMEI: %s", dce->imei);
        ESP_LOGI(TAG, "IMSI: %s", dce->imsi);
        /* Get signal quality */
        uint32_t rssi = 0, ber = 0;
        ESP_ERROR_CHECK(dce->get_signal_quality(dce, &rssi, &ber));
        ESP_LOGI(TAG, "rssi: %d, ber: %d", rssi, ber);
        /* Get battery voltage */
        uint32_t voltage = 0, bcs = 0, bcl = 0;
        ESP_ERROR_CHECK(dce->get_battery_status(dce, &bcs, &bcl, &voltage));
        ESP_LOGI(TAG, "Battery voltage: %d mV", voltage);
        /* setup PPPoS network parameters */
// #if !defined(CONFIG_EXAMPLE_MODEM_PPP_AUTH_NONE) && (defined(CONFIG_LWIP_PPP_PAP_SUPPORT) || defined(CONFIG_LWIP_PPP_CHAP_SUPPORT))
//         esp_netif_ppp_set_auth(esp_netif, auth_type, CONFIG_EXAMPLE_MODEM_PPP_AUTH_USERNAME, CONFIG_EXAMPLE_MODEM_PPP_AUTH_PASSWORD);
// #endif
        /* attach the modem to the network interface */
        esp_netif_attach(esp_netif, modem_netif_adapter);
        /* Wait for IP address */
        xEventGroupWaitBits(event_group, CONNECT_BIT, pdTRUE, pdTRUE, portMAX_DELAY);
        /* Config MQTT */
        esp_mqtt_client_config_t mqtt_config = {
            .uri = BROKER_URL,
            .event_handle = mqtt_event_handler,
        esp_mqtt_client_handle_t mqtt_client = esp_mqtt_client_init(&mqtt_config);
        esp_mqtt_client_start(mqtt_client);
        xEventGroupWaitBits(event_group, GOT_DATA_BIT, pdTRUE, pdTRUE, portMAX_DELAY);
        esp_mqtt_client_destroy(mqtt_client);
        /* Exit PPP mode */
        ESP_ERROR_CHECK(esp_modem_stop_ppp(dte));
        xEventGroupWaitBits(event_group, STOP_BIT, pdTRUE, pdTRUE, portMAX_DELAY);
        const char *message = "Welcome to ESP32!";
        ESP_ERROR_CHECK(example_send_message_text(dce, CONFIG_EXAMPLE_SEND_MSG_PEER_PHONE_NUMBER, message));
        ESP_LOGI(TAG, "Send send message [%s] ok", message);
#endif
        /* Power down module */
        // ESP_ERROR_CHECK(dce->power_down(dce));
        // ESP_LOGI(TAG, "Power down");
        // ESP_ERROR_CHECK(dce->deinit(dce));
        ESP_LOGI(TAG, "Restart after 5 seconds");
        vTaskDelay(pdMS_TO_TICKS(5000));
    /* Unregister events, destroy the netif adapter and destroy its esp-netif instance */
    esp_modem_netif_clear_default_handlers(modem_netif_adapter);
    esp_modem_netif_teardown(modem_netif_adapter);
    esp_netif_destroy(esp_netif);
    ESP_ERROR_CHECK(dte->deinit(dte));
I added a couple lines to the modem library so I could get the next log output:
I (29) boot: ESP-IDF v4.2-dirty 2nd stage bootloader
I (29) boot: compile time 16:47:51
I (29) boot: chip revision: 1
I (32) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (39) boot.esp32: SPI Speed      : 40MHz
I (44) boot.esp32: SPI Mode       : DIO
I (49) boot.esp32: SPI Flash Size : 2MB
I (53) boot: Enabling RNG early entropy source...
I (59) boot: Partition Table:
I (62) boot: ## Label            Usage          Type ST Offset   Length
I (69) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (77) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (84) boot:  2 factory          factory app      00 00 00010000 00100000
I (92) boot: End of partition table
I (96) boot_comm: chip revision: 1, min. application chip revision: 0
I (103) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1874c (100172) map
I (150) esp_image: segment 1: paddr=0x00028774 vaddr=0x3ffb0000 size=0x02164 (  8548) load
I (154) esp_image: segment 2: paddr=0x0002a8e0 vaddr=0x40080000 size=0x00404 (  1028) load
0x40080000: _WindowOverflow4 at /home/pablo/esp/esp-idf/components/freertos/xtensa/xtensa_vectors.S:1730
I (157) esp_image: segment 3: paddr=0x0002acec vaddr=0x40080404 size=0x0532c ( 21292) load
I (175) esp_image: segment 4: paddr=0x00030020 vaddr=0x400d0020 size=0x6355c (406876) map
0x400d0020: _stext at ??:?
I (331) esp_image: segment 5: paddr=0x00093584 vaddr=0x40085730 size=0x06014 ( 24596) load
0x40085730: pxPortInitialiseStack at /home/pablo/esp/esp-idf/components/freertos/xtensa/port.c:218
I (348) boot: Loaded app from partition at offset 0x10000
I (348) boot: Disabling RNG early entropy source...
I (348) cpu_start: Pro cpu up.
I (352) cpu_start: Application information:
I (357) cpu_start: Project name:     pppos_client
I (362) cpu_start: App version:      1
I (367) cpu_start: Compile time:     Feb 19 2021 16:47:45
I (373) cpu_start: ELF file SHA256:  58b6b4143284fd79...
I (379) cpu_start: ESP-IDF:          v4.2-dirty
I (384) cpu_start: Starting app cpu, entry point is 0x400818e4
0x400818e4: call_start_cpu1 at /home/pablo/esp/esp-idf/components/esp32/cpu_start.c:287
I (0) cpu_start: App cpu up.
I (394) heap_init: Initializing. RAM available for dynamic allocation:
I (401) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (407) heap_init: At 3FFB39F0 len 0002C610 (177 KiB): DRAM
I (414) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (420) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (426) heap_init: At 4008B744 len 000148BC (82 KiB): IRAM
I (433) cpu_start: Pro cpu start user code
I (451) spi_flash: detected chip: gd
I (452) spi_flash: flash io: dio
W (452) spi_flash: Detected size(16384k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (462) cpu_start: Starting scheduler on PRO CPU.
I (475) uart: queue free spaces: 30
W (485) esp_modem_dte_send_cmd: AT --> AT
W (485) esp_handle_uart_pattern: AT <--
W (485) esp_handle_uart_pattern: AT <-- OK
W (495) esp_modem_dte_send_cmd: AT --> ATE0
W (505) esp_handle_uart_pattern: AT <--
W (505) esp_handle_uart_pattern: AT <-- OK
W (505) esp_modem_dte_send_cmd: AT --> AT+CGMM
W (515) esp_handle_uart_pattern: AT <--
W (515) esp_handle_uart_pattern: AT <-- BG96
W (525) esp_handle_uart_pattern: AT <--
W (525) esp_handle_uart_pattern: AT <-- OK
W (535) esp_modem_dte_send_cmd: AT --> AT+CGSN
W (545) esp_handle_uart_pattern: AT <--
W (545) esp_handle_uart_pattern: AT <-- 867035049868472
W (555) esp_handle_uart_pattern: AT <--
W (555) esp_handle_uart_pattern: AT <-- OK
W (565) esp_modem_dte_send_cmd: AT --> AT+CIMI
W (565) esp_handle_uart_pattern: AT <--
W (575) esp_handle_uart_pattern: AT <-- 748070102245966
W (585) esp_handle_uart_pattern: AT <-- OK
W (585) esp_modem_dte_send_cmd: AT --> AT+COPS?
W (595) esp_handle_uart_pattern: AT <--
W (595) esp_handle_uart_pattern: AT <-- +COPS: 0,0,"Movistar movistar",0
W (605) esp_handle_uart_pattern: AT <--
W (605) esp_handle_uart_pattern: AT <-- OK
W (615) esp_modem_dte_send_cmd: AT --> AT+IFC=0,0
W (625) esp_handle_uart_pattern: AT <--
W (625) esp_handle_uart_pattern: AT <-- OK
W (625) esp_modem_dte_send_cmd: AT --> AT&W
W (635) esp_handle_uart_pattern: AT <--
W (635) esp_handle_uart_pattern: AT <-- OK
I (645) pppos_example: Module: BG96
I (645) pppos_example: Operator: "Movistar movistar"
I (655) pppos_example: IMEI: 867035049868472
I (655) pppos_example: IMSI: 748070102245966
W (665) esp_modem_dte_send_cmd: AT --> AT+CSQ
W (675) esp_handle_uart_pattern: AT <--
W (675) esp_handle_uart_pattern: AT <-- +CSQ: 27,99
W (685) esp_handle_uart_pattern: AT <-- OK
I (685) pppos_example: rssi: 27, ber: 99
W (695) esp_modem_dte_send_cmd: AT --> AT+CBC
W (705) esp_handle_uart_pattern: AT <--
W (705) esp_handle_uart_pattern: AT <-- +CBC: 0,74,3993
W (715) esp_handle_uart_pattern: AT <--
W (715) esp_handle_uart_pattern: AT <-- OK
I (725) pppos_example: Battery voltage: 3993 mV
W (725) esp_modem_dte_send_cmd: AT --> AT+CGDCONT=1,"IP","webapn.movistar.com.uy"
W (765) esp_handle_uart_pattern: AT <--
W (765) esp_handle_uart_pattern: AT <-- OK
W (765) esp_modem_dte_send_cmd: AT --> ATD*99***1#
W (775) esp_handle_uart_pattern: AT <--
W (775) esp_handle_uart_pattern: AT <-- CONNECT 150000000
I (875) pppos_example: Modem PPP Started
I (875) pppos_example: PPP state changed event 259
I (875) pppos_example: PPP state changed event 262
I (895) pppos_example: PPP state changed event 263
I (895) pppos_example: PPP state changed event 265
I (1575) esp-netif_lwip-ppp: Connected
I (1575) esp-netif_lwip-ppp: Name Server1: 200.58.141.163
I (1575) esp-netif_lwip-ppp: Name Server2: 200.58.157.11
I (1575) pppos_example: Modem Connect to PPP Server
I (1585) pppos_example: ~~~~~~~~~~~~~~
I (1585) pppos_example: IP          : 10.155.119.219
I (1595) pppos_example: Netmask     : 255.255.255.255
I (1605) pppos_example: Gateway     : 10.64.64.64
I (1605) pppos_example: Name Server1: 200.58.141.163
I (1615) pppos_example: Name Server2: 200.58.157.11
I (1615) pppos_example: ~~~~~~~~~~~~~~
I (1625) pppos_example: GOT ip event!!!
I (1625) pppos_example: PPP state changed event 266
I (1635) system_api: Base MAC address is not set
I (1635) system_api: read default base MAC address from EFUSE
I (1645) pppos_example: MQTT other event id: 7
I (3655) pppos_example: MQTT_EVENT_CONNECTED
I (3655) pppos_example: sent subscribe successful, msg_id=60072
I (4135) pppos_example: MQTT_EVENT_SUBSCRIBED, msg_id=60072
I (4135) pppos_example: sent publish successful, msg_id=0
I (4615) pppos_example: MQTT_EVENT_DATA
TOPIC=tretre
DATA=esp32-pppos
W (5575) esp_handle_uart_data: AT <-- ~!E
W (6095) esp_modem_dte_send_cmd: AT --> +++
W (6995) esp_handle_uart_data: AT <--
OK
W (6995) esp_modem_dte_send_cmd: AT --> ATH
W (6995) esp_handle_uart_pattern: AT <--
I (6995) pppos_example: Modem PPP Stopped
I (7005) pppos_example: PPP state changed event 267
W (7005) esp_handle_uart_pattern: AT <-- OK
I (7005) pppos_example: PPP state changed event 265
I (7015) pppos_example: PPP state changed event 262
I (19005) pppos_example: PPP state changed event 268
I (19005) pppos_example: PPP state changed event 256
I (19005) esp-netif_lwip-ppp: User interrupt
I (19005) pppos_example: PPP state changed event 5
I (19015) pppos_example: User interrupted event from netif:0x0
I (19015) esp-modem-netif: PPP state changed event 5
I (19025) pppos_example: Restart after 5 seconds
W (24025) event: handler already registered, overwriting
W (24035) esp_modem_dte_send_cmd: AT --> AT
W (24035) esp_handle_uart_pattern: AT <--
W (24045) esp_handle_uart_pattern: AT <-- OK
W (24045) esp_modem_dte_send_cmd: AT --> ATE0
W (24055) esp_handle_uart_pattern: AT <--
W (24055) esp_handle_uart_pattern: AT <-- OK
W (24065) esp_modem_dte_send_cmd: AT --> AT+CGMM
W (24075) esp_handle_uart_pattern: AT <--
W (24075) esp_handle_uart_pattern: AT <-- BG96
W (24085) esp_handle_uart_pattern: AT <-- OK
W (24085) esp_modem_dte_send_cmd: AT --> AT+CGSN
W (24095) esp_handle_uart_pattern: AT <--
W (24105) esp_handle_uart_pattern: AT <-- 867035049868472
W (24115) esp_handle_uart_pattern: AT <-- OK
W (24115) esp_modem_dte_send_cmd: AT --> AT+CIMI
W (24125) esp_handle_uart_pattern: AT <--
W (24125) esp_handle_uart_pattern: AT <-- 748070102245966
W (24135) esp_handle_uart_pattern: AT <--
W (24135) esp_handle_uart_pattern: AT <-- OK
W (24145) esp_modem_dte_send_cmd: AT --> AT+COPS?
W (24155) esp_handle_uart_pattern: AT <--
W (24155) esp_handle_uart_pattern: AT <-- +COPS: 0,0,"Movistar movistar",0
W (24165) esp_handle_uart_pattern: AT <--
W (24165) esp_handle_uart_pattern: AT <-- OK
W (24175) esp_modem_dte_send_cmd: AT --> AT+IFC=0,0
W (24175) esp_handle_uart_pattern: AT <--
W (24185) esp_handle_uart_pattern: AT <-- OK
W (24185) esp_modem_dte_send_cmd: AT --> AT&W
W (24195) esp_handle_uart_pattern: AT <--
W (24195) esp_handle_uart_pattern: AT <-- OK
I (24205) pppos_example: Module: BG96
I (24205) pppos_example: Operator: "Movistar movistar"
I (24215) pppos_example: IMEI: 867035049868472
I (24215) pppos_example: IMSI: 748070102245966
W (24225) esp_modem_dte_send_cmd: AT --> AT+CSQ
W (24235) esp_handle_uart_pattern: AT <--
W (24235) esp_handle_uart_pattern: AT <-- +CSQ: 27,99
W (24245) esp_handle_uart_pattern: AT <--
W (24245) esp_handle_uart_pattern: AT <-- OK
I (24255) pppos_example: rssi: 27, ber: 99
W (24255) esp_modem_dte_send_cmd: AT --> AT+CBC
W (24265) esp_handle_uart_pattern: AT <--
W (24265) esp_handle_uart_pattern: AT <-- +CBC: 0,74,3993
W (24275) esp_handle_uart_pattern: AT <--
W (24275) esp_handle_uart_pattern: AT <-- OK
I (24285) pppos_example: Battery voltage: 3993 mV
W (24285) event: handler already registered, overwriting
W (24295) esp_modem_dte_send_cmd: AT --> AT+CGDCONT=1,"IP","webapn.movistar.com.uy"
W (24325) esp_handle_uart_pattern: AT <--
W (24325) esp_handle_uart_pattern: AT <-- OK
W (24325) esp_modem_dte_send_cmd: AT --> ATD*99***1#
W (24335) esp_handle_uart_pattern: AT <--
W (24335) esp_handle_uart_pattern: AT <-- NO CARRIER
W (24345) esp_modem_dte_send_cmd: AT --> ATO0
W (24355) esp_handle_uart_pattern: AT <--
W (24355) esp_handle_uart_pattern: AT <-- CONNECT 150000000
I (24465) pppos_example: Modem PPP Started
I (24465) pppos_example: PPP state changed event 259
I (24465) pppos_example: PPP state changed event 262
I (25105) pppos_example: PPP state changed event 263
I (25105) pppos_example: PPP state changed event 265
I (25135) esp-netif_lwip-ppp: Connected
I (25135) esp-netif_lwip-ppp: Name Server1: 200.58.141.163
I (25135) esp-netif_lwip-ppp: Name Server2: 200.58.157.11
I (25135) pppos_example: Modem Connect to PPP Server
I (25145) pppos_example: ~~~~~~~~~~~~~~
I (25145) pppos_example: IP          : 10.155.119.219
I (25155) pppos_example: Netmask     : 255.255.255.255
I (25155) pppos_example: Gateway     : 10.64.64.64
I (25165) pppos_example: Name Server1: 200.58.141.163
I (25175) pppos_example: Name Server2: 200.58.157.11
I (25175) pppos_example: ~~~~~~~~~~~~~~
I (25185) pppos_example: GOT ip event!!!
I (25185) pppos_example: PPP state changed event 266
I (25195) pppos_example: MQTT other event id: 7
I (26735) pppos_example: MQTT_EVENT_CONNECTED
I (26735) pppos_example: sent subscribe successful, msg_id=7131
I (27215) pppos_example: MQTT_EVENT_SUBSCRIBED, msg_id=7131
I (27215) pppos_example: sent publish successful, msg_id=0
I (27695) pppos_example: MQTT_EVENT_DATA
TOPIC=tretre
DATA=esp32-pppos
W (28895) esp_handle_uart_data: AT <-- ~!E
W (29415) esp_modem_dte_send_cmd: AT --> +++
E (34415) esp-modem: esp_modem_dte_send_cmd(308): process command timeout
I (34415) bg96: Sending "+++" command failed
W (34415) esp_modem_dte_send_cmd: AT --> AT
E (34915) esp-modem: esp_modem_dte_send_cmd(308): process command timeout
E (34915) bg96: bg96_set_working_mode(302): send command failed
E (34915) esp-modem: esp_modem_dte_change_mode(401): set new working mode:0 failed
E (34925) esp-modem: esp_modem_stop_ppp(597): enter command mode failed
ESP_ERROR_CHECK failed: esp_err_t 0xffffffff (ESP_FAIL) at 0x40083ecc
0x40083ecc: _esp_error_check_failed at /home/pablo/esp/esp-idf/components/esp_common/src/esp_err.c:45
file: "../main/pppos_client_main.c" line 303
func: app_main
expression: esp_modem_stop_ppp(dte)
abort() was called at PC 0x40083ecf on core 0
0x40083ecf: _esp_error_check_failed at /home/pablo/esp/esp-idf/components/esp_common/src/esp_err.c:46
Backtrace:0x4008501f:0x3ffb56b0 0x400856bd:0x3ffb56d0 0x4008938a:0x3ffb56f0 0x40083ecf:0x3ffb5760 0x400d599e:0x3ffb5780 0x400d3f0e:0x3ffb58b0 0x400856c5:0x3ffb58e0
0x4008501f: panic_abort at /home/pablo/esp/esp-idf/components/esp_system/panic.c:330
0x400856bd: esp_system_abort at /home/pablo/esp/esp-idf/components/esp_system/system_api.c:106
0x4008938a: abort at /home/pablo/esp/esp-idf/components/newlib/abort.c:46
0x400d599e: app_main at /home/pablo/esp_example_code/pppos_client/build/../main/pppos_client_main.c:303 (discriminator 1)
0x400d3f0e: main_task at /home/pablo/esp/esp-idf/components/esp32/cpu_start.c:600 (discriminator 2)
0x400856c5: vPortTaskWrapper at /home/pablo/esp/esp-idf/components/freertos/xtensa/port.c:143
Rebooting...
and then it keeps rebooting because the modem doesn't respond to the AT sync command.
Any idea of what could be the problem?
Users browsing this forum: Baidu [Spider], Bing [Bot], Semrush [Bot], trendictionbot and 2 guests
