Hi, everyone.
I'm seeing a lockup in what I believe is the Mesh Stack. I have 8 units connected using a small project based almost entirely on the internal_communication mesh example project. The are connected to a single AP. The hardware is the Saola board using the ESP32-S2-WROOM-1 module.
After running for a little while (1-12 hours) I'm noticing a few units locking up with the following output:
I (57232851) mesh: [wifi]disconnected reason:202(), continuous:2/max:12, non-root, vote(,stopped)<><>
I (57232861) wifi<7,1>, old:<7,0>, ap:<7,1>, sta:<7,1>, prof:7
I (57232871) wifi:state: init -> auth (b0)
I (57232871) wifi:state: auth -> init (7a0)
I (57232881) wifi<7,0>, old:<7,1>, ap:<7,1>, sta:<7,1>, prof:7
All have a similar output, though the disconnect reason varies from 202(?) to 2(auth expire) to 4(assoc expire).
Has anyone else seen this issue or similar behaviour?
Thank you
mesh lockup using base internal_communication example project
Users browsing this forum: Bing [Bot], Google [Bot], StanInexeon and 130 guests
