Make errors
Jumoke
Make errors
Postby Jumoke » Thu Jun 01, 2017 1:06 pm
I've been trying for a few days through different platforms to compile a blink or hello world example for ESP32 DevKit on Ubuntu and everything always seems to work until I hit the "make" command which gives me the following error:
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/soc.h:163:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
ASSERT_IF_DPORT_REG((_r), REG_SET_BIT);
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/io_mux_reg.h:111:5: note: in expansion of macro 'REG_SET_BIT'
REG_SET_BIT(PIN_NAME, FUN_PD);
make[1]: *** [src/bootloader_random.o] Error 1
make: *** [bootloader_support-build] Error 2
I've tried using multiple methods and toolchains but toolchain always compiles fine but I cannot make or flash.
ESP_Sprite
Re: Make errors
Postby ESP_Sprite » Fri Jun 02, 2017 1:51 am
You are missing the important bit of the error. You have an error in a call to REG_SET_BIT somewhere, but you cut off the bit stating what error and where.
Jumoke
Re: Make errors
Postby Jumoke » Fri Jun 02, 2017 1:21 pm
Thanks for the response. I didn't put the whole code because it was pretty long but here it is
jumoke@jumoke-VirtualBox:~/Desktop/iotbits_esp32/esp-idf/examples/get-started/blink$ make
WARNING: Toolchain version is not supported: crosstool-NG crosstool-ng-1.22.0-59-g8d95cad
Expected to see version: crosstool-NG crosstool-ng-1.22.0-61-gab8375a
Please check ESP-IDF setup instructions and update the toolchain, or proceed at your own risk.
WARNING: Compiler version is not supported: 4.8.5
Expected to see version(s): 5.2.0
CC src/bootloader_random.o
In file included from /home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/soc.h:20:0,
                 from /home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/wdev_reg.h:17,
                 from /home/jumoke/Desktop/iotbits_esp32/esp-idf/components/bootloader_support/src/bootloader_random.c:16:
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/io_mux_reg.h: In function 'PIN_PULLUP_DIS':
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/esp32/include/esp_assert.h:23:28: error: first argument to '__builtin_choose_expr' not a constant
             _Static_assert(__builtin_choose_expr(__builtin_constant_p(CONDITION), (CONDITION), 1), #MSG);   \
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/soc.h:138:38: note: in expansion of macro 'TRY_STATIC_ASSERT'
 #define ASSERT_IF_DPORT_REG(_r, OP)  TRY_STATIC_ASSERT(!IS_DPORT_REG(_r), (Cannot use OP for DPORT registers use DPORT_##OP));
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/soc.h:169:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
             ASSERT_IF_DPORT_REG((_r), REG_CLR_BIT);        \
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/io_mux_reg.h:96:5: note: in expansion of macro 'REG_CLR_BIT'
     REG_CLR_BIT(PIN_NAME, FUN_PU);
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/esp32/include/esp_assert.h:23:28: error: expression in static assertion is not constant
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/io_mux_reg.h: In function 'PIN_PULLUP_EN':
             ASSERT_IF_DPORT_REG((_r), REG_SET_BIT);        \
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/io_mux_reg.h:101:5: note: in expansion of macro 'REG_SET_BIT'
     REG_SET_BIT(PIN_NAME, FUN_PU);
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/io_mux_reg.h: In function 'PIN_PULLDWN_DIS':
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/io_mux_reg.h:106:5: note: in expansion of macro 'REG_CLR_BIT'
     REG_CLR_BIT(PIN_NAME, FUN_PD);
/home/jumoke/Desktop/iotbits_esp32/esp-idf/components/soc/esp32/include/soc/io_mux_reg.h: In function 'PIN_PULLDWN_EN':
ESP_Sprite
Re: Make errors
Postby ESP_Sprite » Fri Jun 02, 2017 3:44 pm
There seems to be a fair amount of things wrong with your setup, the fact that e.g. esp-idf is complaining about the version of the compiler is indicative of this. Could you try deleting what you have re toolchain and esp-idf and setting up according to the official docs?
Jumoke
Re: Make errors
Postby Jumoke » Fri Jun 02, 2017 5:32 pm
Hello, here is my output after "make flash"
jumoke@jumoke-VirtualBox:~/esp/myapp$ make flash
/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc: 1: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc: Syntax error: "(" unexpected
WARNING: Failed to find Xtensa toolchain, may need to alter PATH or set one in the configuration menu
CC src/bootloader_flash.o
make[2]: *** [src/bootloader_flash.o] Error 2
make[1]: *** [bootloader_support-build] Error 2
make: *** [/home/jumoke/esp/myapp/build/bootloader/bootloader.bin] Error 2
f.h-f.s.
Re: Make errors
Postby f.h-f.s. » Sat Jun 03, 2017 6:08 pm
What does your path env variable contain?
bash:
$PATH
Pretty cool error.
This one is compiling.
This one cant find the compiler.
And this one states a compiler error.
Did you remove the old toolchain? Did you remove the old toolchain path from $PATH?
Jumoke
Re: Make errors
Postby Jumoke » Tue Jun 06, 2017 7:14 pm
Hello, I started all over in a new machine but now this is my error after "make menuconfig"
jumoke@jumoke-VirtualBox:~/esp/hello_world$ make menuconfig
/home/jumoke/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc: 1: /home/jumoke/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc: ELF: not found
/home/jumoke/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc: 2: /home/jumoke/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc: Syntax error: "(" unexpected
MENUCONFIG
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
And these are my PATHs:
jumoke@jumoke-VirtualBox:~$ printenv PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/jumoke/esp/xtensa-esp32-elf/bin
jumoke@jumoke-VirtualBox:~/esp/hello_world$ printenv IDF_PATH
/home/jumoke/esp/esp-idf
Jumoke
Re: Make errors
Postby Jumoke » Tue Jun 06, 2017 7:49 pm
I'm missing a "snap/bin" in my PATH but don't know how to add it.
f.h-f.s.
Re: Make errors
Postby f.h-f.s. » Thu Jun 15, 2017 12:45 pm
You can export your path in the terminal.
export PATH=$PATH:/dir/to/add/
this will append to the path variable.
If you add this line in your ~/.profile or ~/.bash_profile ~/.bashrc it will add it at login? (not sure exactly which, i just put them everywhere :lol: )
Jumoke
Re: Make errors
Postby Jumoke » Wed Jul 05, 2017 1:29 pm
For anyone wondering- I got it to work. I have no idea why Ubuntu 64-bit was not compatible with the 64-bit. I used the 32-bit on Ubuntu 64-bit.
Users browsing this forum: No registered users and 113 guests
