Hii;
I am facing issue to connect wifi mqtt with ssl. i already generated client certificate and key. when i try to run example code
(esp-idf\examples\protocols\mqtt\ssl)i get below error.
E (7204) esp-tls-mbedtls: mbedtls_x509_crt_parse returned -0x2180
E (7204) esp-tls-mbedtls: Failed to set client pki context
E (7204) esp-tls-mbedtls: Failed to set client configurations
E (7214) esp-tls: create_ssl_handle failed
E (7214) esp-tls: Failed to open new connection
E (7214) TRANS_SSL: Failed to open a new connection
E (7224) MQTT_CLIENT: Error transport connect
I (7234) MQTTS_EXAMPLE: MQTT_EVENT_ERROR
I (7234) MQTTS_EXAMPLE: MQTT_EVENT_DISCONNECTED
can someone guide me what i m doing wrong???
mqtt ssl example certificate error in esp idf
Re: mqtt ssl example certificate error in esp idf
Hi jaimits,
As described in the logs, the problem here comes from the certificate :
First you are saying that you created both client key and certificate but the example you are using (examples\protocols\mqtt\ssl) is only for server authentication.
For mutual authentication use the example examples\protocols\mqtt\ssl_mutual_auth
Then make sure that the commands you are using to generate certificates and keys are correct.
To create a self-signed certificate with openssl it should be something like :
To avoid errors you really need to understand how mutual auth and more generally PKI works.
openssl req -x509 -sha256 -nodes -days 365 -newkey rsa:2048 -keyout client.key -out client.crt
Users browsing this forum: longo92 and 145 guests
