ESP32 S2 MINI CMake Error
adam_esp
Postby adam_esp » Mon Apr 19, 2021 10:57 am
I have a big problem with ESP-IDF 4.2 (and 4.3 too) and ESP32 S2:
Building in: C:\ESP32\workspace\iot\build
Configuring in: C:\ESP32\workspace\iot\build
cmake -G Ninja -DCMAKE_TOOLCHAIN_FILE=C:\ESP32\esp-idf-v4.3\tools\cmake\toolchain-esp32s2.cmake -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCCACHE_ENABLE=1 -DIDF_TARGET=esp32s2 C:\ESP32\workspace\iot
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.21.0.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- Found assembler: C:/msys_2019/home/anonymous/esp/esp-idf/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc.exe
-- Check for working C compiler: C:/msys_2019/home/anonymous/esp/esp-idf/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc.exe
-- Check for working C compiler: C:/msys_2019/home/anonymous/esp/esp-idf/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc.exe -- works
-- Check for working CXX compiler: C:/msys_2019/home/anonymous/esp/esp-idf/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-g++.exe
-- Check for working CXX compiler: C:/msys_2019/home/anonymous/esp/esp-idf/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-g++.exe -- works
-- Building ESP-IDF components for target esp32s2
-- Checking Python dependencies...
Python requirements from C:\ESP32\esp-idf-v4.3\requirements.txt are satisfied.
-- Project sdkconfig file C:/ESP32/workspace/iot/sdkconfig
Loading defaults file C:/ESP32/workspace/iot/sdkconfig.defaults...
-- Found PythonInterp: C:/msys_2019/home/anonymous/esp/esp-idf/python_env/idf4.3_py3.8_env/Scripts/python.exe (found version "3.8.2")
-- Could NOT find Perl (missing: PERL_EXECUTABLE)
-- App "iot" version: ESP_TEST
-- Adding linker script C:/ESP32/esp-idf-v4.3/components/esp_rom/esp32s2/ld/esp32s2.rom.ld
-- Adding linker script C:/ESP32/esp-idf-v4.3/components/esp_rom/esp32s2/ld/esp32s2.rom.api.ld
-- Adding linker script C:/ESP32/esp-idf-v4.3/components/esp_rom/esp32s2/ld/esp32s2.rom.libgcc.ld
-- Adding linker script C:/ESP32/esp-idf-v4.3/components/esp_rom/esp32s2/ld/esp32s2.rom.newlib-funcs.ld
-- Adding linker script C:/ESP32/esp-idf-v4.3/components/esp_rom/esp32s2/ld/esp32s2.rom.newlib-data.ld
-- Adding linker script C:/ESP32/esp-idf-v4.3/components/esp_rom/esp32s2/ld/esp32s2.rom.spiflash.ld
-- Adding linker script C:/ESP32/workspace/iot/build/esp-idf/esp32s2/esp32s2_out.ld
-- Adding linker script C:/ESP32/esp-idf-v4.3/components/esp32s2/ld/esp32s2.project.ld.in
-- Adding linker script C:/ESP32/esp-idf-v4.3/components/esp32s2/ld/esp32s2.peripherals.ld
CMake Error at C:/ESP32/esp-idf-v4.3/tools/cmake/component.cmake:315 (message):
  Component main only supports targets: esp32
  C:/ESP32/esp-idf-v4.3/tools/cmake/component.cmake:433 (__component_check_target)
  main/CMakeLists.txt:1 (idf_component_register)
Anyone knows what and how else to configure?
adam_esp
Re: ESP32 S2 MINI CMake Error
Postby adam_esp » Thu Apr 22, 2021 11:13 am
I reinstalled everything and it works perfectly !
Users browsing this forum: Bing [Bot], hdsjulian2 and 124 guests
