ESP32S2 USB-CDC does not appear as option in CONFIG_ESP_CONSOLE_UART
lmagalhaes
Postby lmagalhaes » Tue Apr 20, 2021 3:44 pm
Hi there,
I have a custom board with a ESP32-S2 and I'm using the native USB port to flash the IC. I'm trying to configure it also to serve as the console, but in the menuconfig that option does not appear. According to the documentation,
On chips with USB peripheral, “USB CDC” option redirects output to the CDC port. This option uses the CDC driver in the chip ROM. This option is incompatible with TinyUSB stack.
However, the TinyUSB stack is disabled and even like that I don't have the USB CDC option. I only have the default (UART0), Custom which let's me choose between UART0 and UART1 and None.
What am I missing?
Thanks,
Luís
ESP_Roland
Re: ESP32S2 USB-CDC does not appear as option in CONFIG_ESP_CONSOLE_UART
Postby ESP_Roland » Tue Apr 20, 2021 4:26 pm
Have you run "idf.py set-target esp32s2" in your project before running "idf.py menuconfig"?
lmagalhaes
Postby lmagalhaes » Tue Apr 20, 2021 9:15 pm
Yes, I even have in the SDKCONFIG:
CONFIG_IDF_CMAKE=y
CONFIG_IDF_TARGET="esp32s2"
CONFIG_IDF_TARGET_ESP32S2=y
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0002
chegewara
Postby chegewara » Tue Apr 20, 2021 9:49 pm
Next question would be: what esp-idf version you are running at?
lmagalhaes
Postby lmagalhaes » Tue Apr 20, 2021 9:57 pm
IDF v4.2
chegewara
Postby chegewara » Wed Apr 21, 2021 4:38 am
I believe that CDC console has been added from v4.3.
lmagalhaes
Postby lmagalhaes » Wed Apr 21, 2021 8:01 am
Ah. Since I'm using VSCode, how can I choose the ESP-IDF version ? I just let the extension install everything and apparentely it's pulling the 4.2 version.
Users browsing this forum: No registered users and 263 guests
