ESP32-S2 UART1 as wakeup source in light sleep mode
yusufbavas
Postby yusufbavas » Thu Apr 22, 2021 12:57 pm
I faced a problem on esp32-s2 light sleep. I can use UART0 as wakeup source but its not working when i try to use UART1. I cant find something like "its only works for UART0". This codes works. When I send some data from UART0, esp wakes up. But when I change it to UART1, its not working. I tried to get data from UART1 without sleep, its works. I can get data from UART1 but esp dont use it as wakeup source. Am I doing something wrong? Thank you. (I use esp-idf-v4.4-dev)
while (true) {
    uart_set_wakeup_threshold(CONFIG_ESP_CONSOLE_UART_NUM,3);
    esp_sleep_enable_uart_wakeup(CONFIG_ESP_CONSOLE_UART_NUM);
    printf("Entering light sleep\n");
    uart_wait_tx_idle_polling(CONFIG_ESP_CONSOLE_UART_NUM);
    esp_light_sleep_start();
    printf("Returned from light sleep\n");
WiFive
Re: ESP32-S2 UART1 as wakeup source in light sleep mode
Postby WiFive » Thu Apr 22, 2021 9:59 pm
You have to use gpio18 as rx and probably manually configure the iomux for that function.
Users browsing this forum: Baidu [Spider] and 141 guests
