I am using the ESP32 and I have code that performs the OTA update using HTTPS it uses MbedTLS. Here is repository for code : https://github.com/NaitikSanas/esp32-ota-https
In order to connect with S3 bucket it requires the Server Root CA. I have no clue how to get it. if someone has done similar thing kindly give me some directions.
Thanks.
How to get Server Root CA for S3 Bucket?
Re: How to get Server Root CA for S3 Bucket?
openssl s_client -showcerts -servername www.example.com -connect www.example.com:443
https://stackoverflow.com/questions/788 ... m-a-server
then copy and paste all blocks with cerificates ------BEGIN... -------- END in one file and embed this as in the example of IDF.
Thank You this command worked for me.atlascoder wrote: ↑Thu Apr 22, 2021 3:47 pmopenssl s_client -showcerts -servername www.example.com -connect www.example.com:443
Users browsing this forum: Baidu [Spider] and 175 guests
