I'm trying to benchmark the best UDP/Wifi performance we can get from the ESP32 module to evaluate it's use in a project.
Running udp_perf as a station/sender while clocked at 240MHz has yielded ~25Mbps to a Laptop running as a softAP (I'm looking to find a suitable real/hard AP to test with as well). This was on an otherwise empty channel at very short range.
Are there any obvious methods to increase the performance close to the claimed 135Mbps? (See https://espressif.com/en/products/hardw ... 2/overview). If required we can limit the problem space (fixing IP addresses, dedicated receiver etc) to help improve throughput. Is the upd_perf example the best place to start?
Once I've gotten a hold of an Access Point does anyone have a solid feel for a realistic maximum sustainable throughput?
Thanks,
Phil
Increasing UPD Wifi performance
Re: Increasing UPD Wifi performance
I got the same result in udp throughput test.And tcp performance was only about 2Mbps.........
We have a document about WiFi driver in preparation, it will have some information on achievable throughput.
130Mbps can be achieved by passing packets directly to WiFi driver (i.e. without the overhead of LwIP stack), and with testing being performed inside a shield box.
Maximum UDP throughput (TX or RX) with LwIP stack, and testing being performed in a shield box, is around 80Mbps.
In air, maximum value achieved was around 30Mbps, your 25Mbps result looks fairly close to that.
You mean not socket API to netconn API, but working around LwIP entirely? Are there code examples somewhere? My issue is maintaining consistent throughput currently.130Mbps can be achieved by passing packets directly to WiFi driver
Can we get hold of the said Wi-Fi driver documentation?ESP_igrr wrote:We have a document about WiFi driver in preparation, it will have some information on achievable throughput.
Hi I´am trying to obtain 25 Mb throughput.
I read you could get this speed, I wonder if I can get your code
Thanks in advance
Mauricio
Thanks in advance
Mauricio
Users browsing this forum: bushpulbek, djixon, steevke and 124 guests
