I use an ESP32 WROVER-E and want to configure GPIO3/U0RXD pin as UART0 Tx , is that possible?
I've attached my "Common ESP-related" config where i set "UART TX" to 3.
I've tested this and measured that pin but it doesn't toggle so no data is sent although I sen debug data using esp_log_write function.
It works good if I use default setting and use GPIO1 as UART0 Tx and GPIO3 as UART0 Rx.
BR,
Jonas
Configure U0RXD as Uart Tx for debugging
- config.png (36.36 KiB) Viewed 1354 times
Users browsing this forum: Majestic-12 [Bot] and 251 guests
