Attach ISR to Pulse Counter
gfvalvo
Postby gfvalvo » Sat May 08, 2021 10:48 pm
Hi All.
So, scanning through the API reference, it appears there are two different methods to attach an ISR the Pulse Counter:
* pcnt_isr_service_install() / pcnt_isr_handler_add()
* pcnt_isr_register()
However, I haven't yet found an explanation of what the difference between these two is. Anyone have an explanation or a pointer to an explanation?
Thanks.
WiFive
Re: Attach ISR to Pulse Counter
Postby WiFive » Sun May 09, 2021 4:40 am
pcnt_isr_register is only if you want to write your own low level isr
gfvalvo
Postby gfvalvo » Sun May 09, 2021 11:22 am
Thanks. Is that distinction documented somewhere?
WiFive
Postby WiFive » Mon May 10, 2021 2:14 am
Not sure, but it is common to most of the peripheral drivers. The interrupt service manages its own isr so it will call pcnt_isr_register internally.
Users browsing this forum: No registered users and 95 guests
