Hey,
esp_http_client_fetch_headers has a bug. It calls http_parser_execute with incomplete headers, and when it does that, the latter will call the on_header_value functions with erroneous data.
To make this concrete :
- I'm requesting stuff from the letsencrypt.org
- on some requests, the set of headers exceeds 512 bytes
- it regularly cuts the line with the nonce in half (so my code picks up a short nonce, and further communication is not accepted)
Workaround is possible by setting a larger value than by default :
httpc.buffer_size = 1024; // HACK to ensure the nonce header doesn't get cut in two
but that's arbitrary : the same could still happen.
I propose a fix like below.
Comments ?
Danny
#if 0
// Original code calls http_parser_execute with a buffer that may end on an incompletely read line
while (client->state < HTTP_STATE_RES_COMPLETE_HEADER) {
buffer->len = esp_transport_read(client->transport, buffer->data, client->buffer_size, client->timeout_ms);
if (buffer->len <= 0) {
return ESP_FAIL;
http_parser_execute(client->parser, client->parser_settings, buffer->data, buffer->len);
#else
// In this version, detect incomplete header, allocate more memory, only call http_parser when that's ok.
int off = 0;
int eoh;
while ((eoh = _header_end(buffer->data, buffer->len)) < 0) {
off = buffer->len;
buffer->data = realloc(buffer->data, buffer->len + 200);
int r = esp_transport_read(client->transport, buffer->data+off, 200, client->timeout_ms);
if (r < 0) {
return ESP_FAIL;
buffer->len += r;
#endif
to go with that, you also need :
int _header_end(const char *ptr, const int len) {
for (int i=0; i<len-3; i++)
if (ptr == 0x0D && ptr[i+1] == 0x0A && ptr[i+2] == 0x0D && ptr[i+3] == 0x0A)
return i+3;
return -1;
Bug in esp_http_client_fetch_headers
Re: Bug in esp_http_client_fetch_headers
Over three weeks and not a single reply
The same bug is present in esp-idf-4.2.1 .
Here's a diff for esp-idf-v4.2.1/components/esp_http_client/esp_http_client.c :
hp: {16} diff esp_http_client.c.orig esp_http_client.c
1005a1006,1012
> if (ptr[i] == 0x0D && ptr[i+1] == 0x0A && ptr[i+2] == 0x0D && ptr[i+3] == 0x0A)
> return i+3;
> return -1;
1015a1023,1024
> #if 0
1022a1032,1051
> #else
> int off = 0;
> buffer->len = esp_transport_read(client->transport, buffer->data, client->buffer_size_rx, client->timeout_ms);
> int eoh;
> off = buffer->len;
> if (r < 0) {
> return ESP_FAIL;
> buffer->len += r;
> #endif
hp: {17}
Thanks for reporting this, but you may be better off opening an issue on Github, as more devs look there and we can track the status of this.
Users browsing this forum: mikecarlos and 90 guests
