AT+HTTPCLIENT headers missing
For the new AT commands AT+HTTPCLIENT and AT+HTTPCPOST: It seems impossible to get the headers from the server answer? For instance, the client calls a server and gets a cookie (=in the HTTP answer header) in return. How to get the cookie content? It seems impossible.
Re: AT+HTTPCLIENT headers missing
I found the answer myself. The HTTP parser works with callback functions at various points, where additional functionality can be insert. ESP-IDF inits these callback functions as follows (see esp_http_client_init()):
Then I could go into http_on_header_value() and take care of header key/value pairs when read. In the example below, I made them simply visible on the Log screen:
which gives
client->parser_settings->on_message_begin = http_on_message_begin;
client->parser_settings->on_url = http_on_url;
client->parser_settings->on_status = http_on_status;
client->parser_settings->on_header_field = http_on_header_field;
client->parser_settings->on_header_value = http_on_header_value;
client->parser_settings->on_headers_complete = http_on_headers_complete;
client->parser_settings->on_body = http_on_body;
client->parser_settings->on_message_complete = http_on_message_complete;
client->parser_settings->on_chunk_complete = http_on_chunk_complete;
static int http_on_header_value(http_parser *parser, const char *at, size_t length)
esp_http_client_handle_t client = parser->data;
if (client->current_header_key == NULL) {
return 0;
if (strcasecmp(client->current_header_key, "Location") == 0) {
http_utils_assign_string(&client->location, at, length);
} else if (strcasecmp(client->current_header_key, "Transfer-Encoding") == 0
&& memcmp(at, "chunked", length) == 0) {
client->response->is_chunked = true;
} else if (strcasecmp(client->current_header_key, "WWW-Authenticate") == 0) {
http_utils_assign_string(&client->auth_header, at, length);
http_utils_assign_string(&client->current_header_value, at, length);
//ESP_LOGD(TAG, "HEADER=%s:%s", client->current_header_key, client->current_header_value);
ESP_LOGE(TAG, "HEADER=%s:%s", client->current_header_key, client->current_header_value);
- HTTP_CLIENT: HEADER=Date:Wed, 23 Jun 2021 19:07:25 GMT
HTTP_CLIENT: HEADER=Server:Apache
HTTP_CLIENT: HEADER=Content-Type:text/xml;charset=ISO-8859-1
HTTP_CLIENT: HEADER=Content-Length:483
HTTP_CLIENT: HEADER=Set-Cookie:JSESSIONID=4CBED8DB34FF062F372D6ADC3EF11655; Path=/dibbsDaisy; HttpOnly
HTTP_CLIENT: HEADER=Vary:Accept-Encoding
Users browsing this forum: Bing [Bot] and 134 guests
