Replacing ESP-IDF components in CMakeLists
Palonso
Postby Palonso » Wed Jul 28, 2021 2:38 pm
I know this topic is widely discussed but most examples I found are done over 'make' and I have my complains on doing them over CMakeLists.
based on: https://docs.espressif.com/projects/esp ... -same-name it says:
Multiple components with the same name
When ESP-IDF is collecting all the components to compile, it will do this in the order specified by COMPONENT_DIRS; by default, this means ESP-IDF’s internal components first (IDF_PATH/components), then any components in directories specified in EXTRA_COMPONENT_DIRS, and finally the project’s components (PROJECT_DIR/components). If two or more of these directories contain component sub-directories with the same name, the component in the last place searched is used. This allows, for example, overriding ESP-IDF components with a modified version by copying that component from the ESP-IDF components directory to the project components directory and then modifying it there. If used in this way, the ESP-IDF directory itself can remain untouched.
Here is the scheme I'm using:
myProject:
    -build/
    -components/
        -esp_http_client/
            (a modified version of the http_client library)
        -include/
            CustomHeader_1.h
            CustomHeader_2.h
        -src/
            CustomLib_1.c
            CustomLib_2.c
        -CMakeLists.txt (components Cmake list)
    -main/
        main.c
        CMakeLists.txt (main Cmake list)
    -someFiles.*
    -CmakeLists.txt (project Cmake list)
And this is my 'components Cmake list':
set(srcs "src/file_1.c"
	"src/file_2.c"
idf_component_register(SRCS "${srcs}"
                    INCLUDE_DIRS include esp_http_client
                    REQUIRES nvs_flash mqtt json app_update esp_https_ota esp_adc_cal ulp bt)
with these scheme I'm not able of compiling the project since the compiler can't find the custom 'esp_http_client' files, here is the compiler include log:
-Iconfig
-I/home/pablo/esp/esp-idf/components/newlib/platform_include
-I/home/pablo/esp/esp-idf/components/freertos/include
-I/home/pablo/esp/esp-idf/components/freertos/xtensa/include
-I/home/pablo/esp/esp-idf/components/heap/include
-I/home/pablo/esp/esp-idf/components/log/include
-I/home/pablo/esp/esp-idf/components/lwip/include/apps
-I/home/pablo/esp/esp-idf/components/lwip/include/apps/sntp
-I/home/pablo/esp/esp-idf/components/lwip/lwip/src/include
-I/home/pablo/esp/esp-idf/components/lwip/port/esp32/include
-I/home/pablo/esp/esp-idf/components/lwip/port/esp32/include/arch
-I/home/pablo/esp/esp-idf/components/lwip/port/esp32/tcp_isn
-I/home/pablo/esp/esp-idf/components/soc/src/esp32/.
-I/home/pablo/esp/esp-idf/components/soc/src/esp32/include
-I/home/pablo/esp/esp-idf/components/soc/include
-I/home/pablo/esp/esp-idf/components/esp_rom/include
-I/home/pablo/esp/esp-idf/components/esp_common/include
-I/home/pablo/esp/esp-idf/components/esp_system/include
-I/home/pablo/esp/esp-idf/components/xtensa/include
-I/home/pablo/esp/esp-idf/components/xtensa/esp32/include
-I/home/pablo/esp/esp-idf/components/esp32/include
-I/home/pablo/esp/esp-idf/components/driver/include
-I/home/pablo/esp/esp-idf/components/driver/esp32/include
-I/home/pablo/esp/esp-idf/components/esp_ringbuf/include
-I/home/pablo/esp/esp-idf/components/efuse/include
-I/home/pablo/esp/esp-idf/components/efuse/esp32/include
-I/home/pablo/esp/esp-idf/components/espcoredump/include
-I/home/pablo/esp/esp-idf/components/esp_timer/include
-I/home/pablo/esp/esp-idf/components/esp_ipc/include
-I/home/pablo/esp/esp-idf/components/soc/soc/esp32/include
-I/home/pablo/esp/esp-idf/components/soc/soc/esp32/../include
-I/home/pablo/esp/esp-idf/components/soc/soc/esp32/private_include
-I/home/pablo/esp/esp-idf/components/vfs/include
-I/home/pablo/esp/esp-idf/components/esp_wifi/include
-I/home/pablo/esp/esp-idf/components/esp_wifi/esp32/include
-I/home/pablo/esp/esp-idf/components/esp_event/include
-I/home/pablo/esp/esp-idf/components/esp_netif/include
-I/home/pablo/esp/esp-idf/components/tcpip_adapter/include
-I/home/pablo/esp/esp-idf/components/app_trace/include
-I/home/pablo/esp/esp-idf/components/mbedtls/port/include
-I/home/pablo/esp/esp-idf/components/mbedtls/mbedtls/include
-I/home/pablo/esp/esp-idf/components/mbedtls/esp_crt_bundle/include
-I/home/pablo/esp/esp-idf/components/bootloader_support/include
-I/home/pablo/esp/esp-idf/components/app_update/include
-I/home/pablo/esp/esp-idf/components/spi_flash/include
-I/home/pablo/esp/esp-idf/components/wpa_supplicant/include
-I/home/pablo/esp/esp-idf/components/wpa_supplicant/port/include
-I/home/pablo/esp/esp-idf/components/wpa_supplicant/include/esp_supplicant
-I/home/pablo/esp/esp-idf/components/nvs_flash/include
-I/home/pablo/esp/esp-idf/components/pthread/include
-I/home/pablo/esp/esp-idf/components/perfmon/include
-I/home/pablo/esp/esp-idf/components/asio/asio/asio/include
-I/home/pablo/esp/esp-idf/components/asio/port/include
-I/home/pablo/esp/esp-idf/components/bt/include
-I/home/pablo/esp/esp-idf/components/bt/common/osi/include
-I/home/pablo/esp/esp-idf/components/bt/host/bluedroid/api/include/api
-I/home/pablo/esp/esp-idf/components/cbor/port/include
-I/home/pablo/esp/esp-idf/components/coap/port/include
-I/home/pablo/esp/esp-idf/components/coap/port/include/coap
-I/home/pablo/esp/esp-idf/components/coap/libcoap/include
-I/home/pablo/esp/esp-idf/components/coap/libcoap/include/coap2
-I/home/pablo/esp/esp-idf/components/console
-I/home/pablo/esp/esp-idf/components/nghttp/port/include
-I/home/pablo/esp/esp-idf/components/nghttp/nghttp2/lib/includes
-I/home/pablo/esp/esp-idf/components/esp-tls
-I/home/pablo/esp/esp-idf/components/esp_adc_cal/include
-I/home/pablo/esp/esp-idf/components/esp_gdbstub/include
-I/home/pablo/esp/esp-idf/components/esp_hid/include
-I/home/pablo/esp/esp-idf/components/tcp_transport/include
[b]-I/home/pablo/esp/esp-idf/components/esp_http_client/include [/b]
-I/home/pablo/esp/esp-idf/components/esp_http_server/include
-I/home/pablo/esp/esp-idf/components/esp_https_ota/include
-I/home/pablo/esp/esp-idf/components/protobuf-c/protobuf-c
-I/home/pablo/esp/esp-idf/components/protocomm/include/common
-I/home/pablo/esp/esp-idf/components/protocomm/include/security
-I/home/pablo/esp/esp-idf/components/protocomm/include/transports
-I/home/pablo/esp/esp-idf/components/mdns/include
-I/home/pablo/esp/esp-idf/components/esp_local_ctrl/include
-I/home/pablo/esp/esp-idf/components/sdmmc/include
-I/home/pablo/esp/esp-idf/components/esp_serial_slave_link/include
-I/home/pablo/esp/esp-idf/components/esp_websocket_client/include
-I/home/pablo/esp/esp-idf/components/expat/expat/expat/lib
-I/home/pablo/esp/esp-idf/components/expat/port/include
-I/home/pablo/esp/esp-idf/components/wear_levelling/include
-I/home/pablo/esp/esp-idf/components/fatfs/diskio
-I/home/pablo/esp/esp-idf/components/fatfs/vfs
-I/home/pablo/esp/esp-idf/components/fatfs/src
-I/home/pablo/esp/esp-idf/components/freemodbus/common/include
-I/home/pablo/esp/esp-idf/components/idf_test/include
-I/home/pablo/esp/esp-idf/components/idf_test/include/esp32
-I/home/pablo/esp/esp-idf/components/jsmn/include
-I/home/pablo/esp/esp-idf/components/json/cJSON
-I/home/pablo/esp/esp-idf/components/libsodium/libsodium/src/libsodium/include
-I/home/pablo/esp/esp-idf/components/libsodium/port_include
-I/home/pablo/esp/esp-idf/components/mqtt/esp-mqtt/include
-I/home/pablo/esp/esp-idf/components/openssl/include
-I/home/pablo/esp/esp-idf/components/spiffs/include
-I/home/pablo/esp/esp-idf/components/ulp/include
-I/home/pablo/esp/esp-idf/components/unity/include
-I/home/pablo/esp/esp-idf/components/unity/unity/src
-I/home/pablo/esp/esp-idf/components/wifi_provisioning/include
-I../components/include
[b]-I../components/esp_http_client[/b]
In my custom http_client I have:
#define CUSTOM_ESP_HTTP_CLIENT_H
in wich the the main.c file checks for it:
#ifndef CUSTOM_ESP_HTTP_CLIENT_H
	#error "Custom HTTP client not defined"
#endif
And my compiler output is:
../main/main.c:13:3: error: #error "Custom HTTP client not defined"
[1202/1237] Building C object esp-idf/libsodium/CMakeFiles/__idf_libso...rc/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ref.c.obj
The terminal process "bash '-c', 'cmake --build .'" terminated with exit code: 1.
What's wrong? This should be straightforward..
Best regards,
P
ESP_igrr
Re: Replacing ESP-IDF components in CMakeLists
Postby ESP_igrr » Wed Jul 28, 2021 2:44 pm
I think the structure should look like this:
- project
  - components
    - esp_http_client
      - CMakeLists.txt
      - (any source files and header directories of esp_http_client)
    - your_custom_component
      - CMakeLists.txt
      - (any source files and header directories of your_custom_component
  - main
    - CMakeLists.txt and source files
  - CMakeLists.txt (for the project)
It looks like you are placing CMakeLists.txt file inside `components` directory. The build system thinks that `components` directory contains some component, and doesn't search it recursively for more components, hence doesn't find esp_http_client.
If you place esp_http_client and your_custom_component at the same level in `components` directory, it should work.
Palonso
Postby Palonso » Wed Jul 28, 2021 5:37 pm
Hi ESP_igrr,
I'm trying to add the custom component and I'm not able to do so. What should the CMakeList.txt be? I try to add new folders with the components, but the compiler doesn't seem to "replace" the one of the IDF with the custom one.
I added:
	#error "custom IDF files needed"
#endif
And the compiler stops in that error.
Users browsing this forum: ESP_Roland and 226 guests
