i2c_config_t union issue on definition of variables
kyrpav
Postby kyrpav » Thu Jul 29, 2021 6:53 am
I am trying to create a i2c_config_t in order to user i2c for BME680.
My setup is
 i2c_config_t i2c_config = {
                        .mode = I2C_MODE_MASTER,
                        .sda_io_num = _sda,
                        .scl_io_num = _clk,
                        .sda_pullup_en = GPIO_PULLUP_ENABLE,
                        .scl_pullup_en = GPIO_PULLUP_ENABLE,
                        .master.clk_speed = 100000};
compiler disaggrees with .master.clk_speed and specifically with the first . before master
and returns error
"resource": "/Users/kyrpav/workspace/esp32/tutorials/LearnEsp32/main/Lesson5/BME680.cpp",
"owner": "cpp",
"severity": 8,
"message": "expected primary-expression before '.' token",
"startLineNumber": 38,
"startColumn": 25,
"endLineNumber": 38,
"endColumn": 25
My compiler extra path on configuration is :
.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin
.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin
.espressif/tools/esp32ulp-elf/2.28.51-esp-20191205/esp32ulp-elf-binutils/bin
.espressif/tools/esp32s2ulp-elf/2.28.51-esp-20191205/esp32s2ulp-elf-binutils/bin
.espressif/tools/openocd-esp32/v0.10.0-esp32-20200709/openocd-esp32/bin
Esp-idf version is 4.1.1
from i2c_types.h the definition of the struct is
 * @brief I2C initialization parameters
typedef struct{
    i2c_mode_t mode;     /*!< I2C mode */
    int sda_io_num;      /*!< GPIO number for I2C sda signal */
    int scl_io_num;      /*!< GPIO number for I2C scl signal */
    bool sda_pullup_en;  /*!< Internal GPIO pull mode for I2C sda signal*/
    bool scl_pullup_en;  /*!< Internal GPIO pull mode for I2C scl signal*/
    union {
        struct {
            uint32_t clk_speed;     /*!< I2C clock frequency for master mode, (no higher than 1MHz for now) */
        } master;
        struct {
            uint8_t addr_10bit_en;  /*!< I2C 10bit address mode enable for slave mode */
            uint16_t slave_addr;    /*!< I2C address for slave mode */
        } slave;
} i2c_config_t;
i tried to place a name to the union like "testit" and the same setup on my code like .testit.master.clk_speed and it works but i do not want to touch the library of idf
boarchuz
Re: i2c_config_t union issue on definition of variables
Postby boarchuz » Thu Jul 29, 2021 7:00 am
.master = {
  .clk_speed = 100000,
kyrpav
Postby kyrpav » Thu Jul 29, 2021 7:10 am
.master = {
Thank you this is solving the issue. One more comment i think also in examples of idf in i2c the setup of config_t follows the logic of .master.clk_speed
and it could bring to others also issue.
I would like to know why it works for others like this and not for me what other setup should i check
Postby ESP_Sprite » Thu Jul 29, 2021 10:08 am
It works if you set it in code as a struct member:
config.master.spi_clock=123; //works
It does not work in a named initializer:
i2c_config_t config={
	master.spi_clock=123 //does NOT work
Users browsing this forum: Baidu [Spider] and 112 guests
