Sniffer mode: wifi_pkt_rx_ctrl_t 11n not working?
kioracnn
Postby kioracnn » Sat Jun 24, 2017 7:34 pm
https://github.com/espressif/esp-idf/bl ... fi_types.h
typedef struct {
    signed rssi:8;            /**< signal intensity of packet */
    unsigned rate:5;          /**< data rate */
    unsigned :1;              /**< reserve */
    unsigned sig_mode:2;      /**< 0:is not 11n packet; 1:is 11n packet */
    unsigned :16;             /**< reserve */
    unsigned mcs:7;           /**< if is 11n packet, shows the modulation(range from 0 to 76) */
    unsigned cwb:1;           /**< if is 11n packet, shows if is HT40 packet or not */
    unsigned smoothing:1;     /**< reserve */
    unsigned not_sounding:1;  /**< reserve */
    unsigned aggregation:1;   /**< Aggregation */
    unsigned stbc:2;          /**< STBC */
    unsigned fec_coding:1;    /**< if is 11n packet, shows if is LDPC packet or not */
    unsigned sgi:1;           /**< SGI */
    unsigned noise_floor:8;   /**< noise floor */
    unsigned ampdu_cnt:8;     /**< ampdu cnt */
    unsigned channel:4;       /**< which channel this packet in */
    unsigned :12;             /**< reserve */
    unsigned timestamp:32;    /**< timestamp */
    unsigned :32;             /**< reserve */
    unsigned sig_len:12;      /**< It is really lenth of packet */
    unsigned rx_state:8;      /**< rx state */
} wifi_pkt_rx_ctrl_t;
I have set the wifi card into sniffer mode but I am not getting any 11n packets? and hence none of the 11n fields are getting populated. They are always 0. Also, the "rate" field seems to be only the values "11" or "0" for me. No other value is shown even though packets are being captured successfully.
I am not sure what do I have to do to capture 11n packets? and get the rest of the fields populated?
kioracnn
Re: Sniffer mode: wifi_pkt_rx_ctrl_t 11n not working?
Postby kioracnn » Mon Jun 26, 2017 5:57 pm
Any help would be much appreciated guys!
I am under a deadline and I was assuming all along that these fields would be available and populated, but it does not seem to be so in sniffer mode.
Anyone from Espressif?
Users browsing this forum: No registered users and 76 guests
