[Solved] StoreProhibited sha engine?
f.h-f.s.
Postby f.h-f.s. » Tue Jun 27, 2017 9:25 am
Hi all,
Lately we have seen this error occur. We have two running TLS connections using mbedtls.
Is this crash caused by both mbedtls connections requesting use of the SHA engine?
Guru Meditation Error of type StoreProhibited occurred on core  0. Exception was unhandled.
Register dump:
0x40087dc9: uxListRemove at C:/IoT/BEASTv3/esp-idf/components/freertos/list.c:214
PC      : 0x40087dc9  PS      : 0x00060e33  A0      : 0x80086041  A1      : 0x3ffe8f40
A2      : 0x3ffdcd40  A3      : 0x00060e23  A4      : 0x00060020  A5      : 0x00000000
A6      : 0x00000000  A7      : 0x00000002  A8      : 0xff03104e  A9      : 0x02ac0f00
A10     : 0x1edd0000  A11     : 0x3ffe90a0  A12     : 0x00000025  A13     : 0x0000000d
A14     : 0x00000073  A15     : 0x00000025  SAR     : 0x00000010  EXCCAUSE: 0x0000001d
0x4000c2e0: ?? ??:0
0x4000c2f6: ?? ??:0
EXCVADDR: 0x02ac0f08  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0x00000000
0x4008603e: xTaskPriorityDisinherit at C:/IoT/BEASTv3/esp-idf/components/freertos/tasks.c:4010
0x4008662e: prvCopyDataToQueue at C:/IoT/BEASTv3/esp-idf/components/freertos/queue.c:2034
0x4008693c: xQueueGenericSend at C:/IoT/BEASTv3/esp-idf/components/freertos/queue.c:2034
0x40081c11: lock_release_generic at C:/IoT/BEASTv3/esp-idf/components/newlib/locks.c:197
0x40081cb3: _lock_release at C:/IoT/BEASTv3/esp-idf/components/newlib/locks.c:203
0x401880be: esp_sha_unlock_engine at C:/IoT/BEASTv3/esp-idf/components/esp32/hwcrypto/sha.c:196
0x401734e4: mbedtls_sha512_finish at C:/IoT/BEASTv3/esp-idf/components/mbedtls/port/esp_sha512.c:394
0x40178dcd: sha384_finish_wrap at C:/IoT/BEASTv3/esp-idf/components/mbedtls/library/md_wrap.c:496
0x4016afe6: mbedtls_md_hmac_finish at C:/IoT/BEASTv3/esp-idf/components/mbedtls/library/md.c:138
0x4015f6a8: ssl_encrypt_buf at C:/IoT/BEASTv3/esp-idf/components/mbedtls/library/ssl_tls.c:6007
0x4015fc8d: mbedtls_ssl_write_record at C:/IoT/BEASTv3/esp-idf/components/mbedtls/library/ssl_tls.c:6007
0x40160a9d: ssl_write_real at C:/IoT/BEASTv3/esp-idf/components/mbedtls/library/ssl_tls.c:6007
0x40160af5: ssl_write_split at C:/IoT/BEASTv3/esp-idf/components/mbedtls/library/ssl_tls.c:6007
0x40160ba4: mbedtls_ssl_write at C:/IoT/BEASTv3/esp-idf/components/mbedtls/library/ssl_tls.c:6007
0x400ebd11: tlsio_mbedtls_send at C:/IoT/BEASTv3/components/azure_iot/tlsio_mbedtls.c:603
0x401895ef: xio_send at C:/IoT/BEASTv3/components/azure_iot/xio.c:150
0x400e7665: conn_send_all at C:/IoT/BEASTv3/components/azure_iot/httpapi_compact.c:46
0x400e7f39: SendHeadsToXIO at C:/IoT/BEASTv3/components/azure_iot/httpapi_compact.c:46
0x400e805a: HTTPAPI_ExecuteRequest at C:/IoT/BEASTv3/components/azure_iot/httpapi_compact.c:46
0x400e3303: _ZN14HttpClient_Api3GetEPKcP10BUFFER_TAGPj at C:/IoT/BEASTv3/main/HttpClient_Api.cpp:98
0x400e2a04: _ZN6BACAPI4PingEPKc at C:/IoT/BEASTv3/main/BACAPI.cpp:43
0x400e1a7e: _ZL7on_pingv at C:/IoT/BEASTv3/main/Main.cpp:430
0x400e309d: _ZN4Ping3NowEv at C:/IoT/BEASTv3/main/Ping.cpp:57
0x400e30ad: _ZN4Ping4TaskEPv at C:/IoT/BEASTv3/main/Ping.cpp:69 (discriminator 1)
Backtrace: 0x40087dc9:0x3ffe8f40 0x4008603e:0x3ffe8f60 0x4008662e:0x3ffe8f80 0x4008693c:0x3ffe8fa0 0x40081c11:0x3ffe8fe0 0x40081cb3:0x3ffe9010 0x401880be:0x3ffe9030 0x401734e4:0x3ffe9050 0x40178dcd:0x3ffe9080 0x4016afe6:0x3ffe90a0 0x4015f6a8:0x3ffe9100 0x4015fc8d:0x3ffe9170 0x40160a9d:0x3ffe91a0 0x40160af5:0x3ffe91d0 0x40160ba4:0x3ffe91f0 0x400ebd11:0x3ffe9210 0x401895ef:0x3ffe9230 0x400e7665:0x3ffe9250 0x400e7f39:0x3ffe9270 0x400e805a:0x3ffe96a0 0x400e3303:0x3ffe96e0 0x400e2a04:0x3ffe9720 0x400e1a7e:0x3ffe97a0 0x400e309d:0x3ffe97c0 0x400e30ad:0x3ffe97e0
ESP_igrr
Re: StoreProhibited sha engine?
Postby ESP_igrr » Tue Jun 27, 2017 11:03 am
What is the stack size of this ping task?
f.h-f.s.
Postby f.h-f.s. » Tue Jun 27, 2017 11:25 am
The PingTask has 8 * 1024 bytes of stackspace, Priority: 02, StackHighWatermark: 4888 at runtime.
I should mention this problem does not always occur. This crash has occured 11 times since 6-6-2017.
9 times within 70000ms ( the ping task pings every 60seconds).
Two times after a long while (11h and one after 50minutes).
I also got a few assertions that failed
C:/IoT/BEASTv3/esp-idf/components/freertos/tasks.c:4013 (xTaskPriorityDisinherit)- assert failed!
D (4667504) tlsio_mbedtls InitTask: tlsio_mbedtls_send
D (4667524) tlsio_mbedtls InitTask: tlsio_mbedtls_send
D (4667544) tlsio_mbedtls InitTask: tlsio_mbedtls_send
D (4667564) tlsio_mbedtls InitTask: tlsio_mbedtls_send
D (4667594) tlsio_mbedtls InitTask: tlsio_mbedtls_send
There are two tasks that use the same mbedtls connection. Which probably cause these crashes.
Users browsing this forum: tomy983 and 269 guests
