As of right now, espressif only supports the two authentication modes "Basic" and "Digest" with no support for "Bearer":
https://docs.espressif.com/projects/esp ... entication
I would like to make use of the JWT token authentication using esp https client which would require that.
My question therefore is: Is there a plan in the near future to implement "bearer" type authentication on the esp https client? If not, can someone give a rought estimate on how extensive a custom implementation would be?
Support for "bearer" authentication type in https client [solved]
Re: Support for "bearer" authentication type in https client
Unless I'm missing something with the existing toolset in IDF you could handle this.
https://github.com/martinberlin/cale-id ... e.cpp#L411
Of course I don't know the internals of your particular OAuth but you could get a token and then pass it on every request as an authorization Bearer token.
I'm also quite sure there should be some example of this if you Google around.
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
Thanks a lot! I just wanted to get back to you and say that it worked
Awesome! You can edit the first entry and add [Solved] or similar so you help to identify the entries that are still not resolved.
Users browsing this forum: Baidu [Spider], spenderIng and 161 guests
