nvs_partition_config.csv now doesn't like quotation marks
mzimmers
Postby mzimmers » Thu Sep 16, 2021 6:54 pm
Hi all -
I'm starting on a new ESP32 project. New development environment is Linux. I grabbed a copy of a nvs_partition_config.csv file from an older project which was developed on Windows 10.
In my original file, all string values were contained in quotes, eg:
NTP_SERVER,data,string,"pool.ntp.org"
This worked fine in my old application, but my new one retains the quotes when I retrieve values from the partition.
Is this something that was changed in a recent version of the IDF tools, or is a Linux/Windows thing, or just something weird?
I guess I'm wondering whether it's safe to remove the quotations from the file.
Thanks...
fasani
Contact:
Re: nvs_partition_config.csv now doesn't like quotation marks
Postby fasani » Fri Sep 17, 2021 12:45 pm
I think you are safe removing the quotes. If you look at the default partitions they do not use quotes at all:
https://github.com/espressif/esp-idf/tr ... tion_table
Other than that why in Windows is different I don't know, it shouldn't be, but truth to be told I don't use Windows since about 15 years.
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
mbratch
Postby mbratch » Fri Sep 17, 2021 2:14 pm
But standard CSV format permits the quotes (intended, for example, to handle the case where the item may itself include a comma, in the general case). So ESP-IDF tools don't permit standard CSV for the partition table?
Users browsing this forum: djixon, MicroController and 143 guests
