Modbus - tcp_master_task - Task watchdog got triggered
sarasini
Postby sarasini » Thu Sep 23, 2021 7:37 am
I'm developing a project using the new tcp modbus library provided in esp-idf v4.3
Everything is working well for some hours of continuous reading modbus parameters (with a 150ms delay between each reading).
Then suddently the esp32 crash with this message:
task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
task_wdt:  - IDLE (CPU 0)
task_wdt: Tasks currently running:
task_wdt: CPU 0: tcp_master_task
task_wdt: CPU 1: IDLE
task_wdt: Aborting.
It seems that the idf task that is handling the modbus procedures does not reset the task watchdog correctly.
How can I solve it?
sarasini
Re: Modbus - tcp_master_task - Task watchdog got triggered
Postby sarasini » Mon Sep 27, 2021 7:13 am
any ideas?
thanks
ESP_alisitsyn
Contact:
Postby ESP_alisitsyn » Mon Sep 27, 2021 8:02 am
Hi @sarasini,
Could you provide full log of your application or at least all latest lines before crash?
Also please share the sdkconfig file.
Thanks.
sarasini
Postby sarasini » Mon Sep 27, 2021 8:20 am
Hi @ESP_alisitsyn,
attached log and sdkconfig
Thank you
sdkconfig.txt
(42.51 KiB) Downloaded 171 times
pilomat_modbus_crash.txt
(36.89 KiB) Downloaded 180 times
ESP_alisitsyn
Contact:
Postby ESP_alisitsyn » Tue Sep 28, 2021 12:38 am
HI @sarasini,
Thank you for the files. I need to ask you to provide additions: your project *.elf/map files located in build folder of your project. These files needed to decode the coredump file. Also, you can decode it by youself using the command like below:
espcoredump.py info_corefile -t b64 -c coredump.b64 your_poj_elf_file.elf -d3 -m
coredump.b64 - the coredump output from your log file.
Thanks.
Users browsing this forum: MicroController and 98 guests
