Edited: Need help with MODBUS TCP on esp32 (wroom-32D - devkitc-v4)
pmoneta
Postby pmoneta » Wed Oct 06, 2021 6:08 pm
i'm trying to stablish communications between an esp32 and a virtual modbus tcp opc server on my computer. to do so, i create a netif wifi station on the esp32 and connect it to my router (so far so good), the esp appears in the router page and i already assigned a static ip to it (i have AP isolation turned off on the router).
Edit: i updated the debug code with extra backtrace information, so i guess its a hostname error:
I (31452) MB_TCP_MASTER_PORT: TCP master stack initialized.
D (31452) intr_alloc: Connected src 14 to int 13 (cpu 0)
I (31452) MB_TCP_MASTER_PORT: Host[IP]: "192.168.1.180"[192.168.1.180]
I (31452) MB_TCP_MASTER_PORT: Add slave IP: 192.168.1.180
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core  0 register dump:
PC      : 0x400e669b  PS      : 0x00060130  A0      : 0x800f19d3  A1      : 0x3ffbe1e0
0x400e669b: dns_gethostbyname_addrtype at C:/esp-idf/components/lwip/lwip/src/core/dns.c:1609
A2      : 0x00000002  A3      : 0x3ffba7a0  A4      : 0x400f085c  A5      : 0x3ffba760
0x400f085c: lwip_netconn_do_dns_found at C:/esp-idf/components/lwip/lwip/src/api/api_msg.c:2219
A6      : 0x00000000  A7      : 0x00000000  A8      : 0x00000000  A9      : 0x00000000
A10     : 0x00000000  A11     : 0x3ffbe240  A12     : 0x3ffbd470  A13     : 0x00000000
A14     : 0x00000000  A15     : 0xff000000  SAR     : 0x0000001c  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000002  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0xffffffff
Backtrace:0x400e6698:0x3ffbe1e0 0x400f19d0:0x3ffbe200 0x400e5855:0x3ffbe220 0x400e58fc:0x3ffbe240 0x4008c121:0x3ffbe270
0x400e6698: dns_gethostbyname_addrtype at C:/esp-idf/components/lwip/lwip/src/core/dns.c:1608
0x400f19d0: lwip_netconn_do_gethostbyname at C:/esp-idf/components/lwip/lwip/src/api/api_msg.c:2254
apparently, i can create the TCP slave (which has my computer IP address) but i can't get to the part where the connection starts, because i got the core 0 panic'ed error.
here's the code i used (i'm programming on platformio using esp-idf):
/* WiFi station Example
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_netif.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#include "esp_modbus_master.h"
#include "sodium.h"
#include "sdkconfig.h"
#define MB_TCP_PORT 502
#define STR(fieldname) ((const char*)( fieldname ))
#define OPTS(min_val, max_val, step_val) { .opt1 = min_val, .opt2 = max_val, .opt3 = step_val }
#define MASTER_TAG "MASTER_TEST"
#define MASTER_CHECK(a, ret_val, str, ...) \
    if (!(a)) { \
        ESP_LOGE(MASTER_TAG, "%s(%u): " str, __FUNCTION__, __LINE__, ##__VA_ARGS__); \
        return (ret_val); \
// ***************************************************** wi-fi *****************************************************
/* The examples use WiFi configuration that you can set via project configuration menu
   If you'd rather not, just change the below entries to strings with
   the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_ESP_WIFI_SSID      "APT_102_2G"
#define EXAMPLE_ESP_WIFI_PASS      "101203vitoria"
#define EXAMPLE_ESP_MAXIMUM_RETRY  5
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t s_wifi_event_group;
/* The event group allows multiple bits for each event, but we only care about two events:
 * - we are connected to the AP with an IP
 * - we failed to connect after the maximum amount of retries */
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT      BIT1
static const char *TAG = "wifi station";
static int s_retry_num = 0;
static void event_handler(void* arg, esp_event_base_t event_base,
                                int32_t event_id, void* event_data)
    if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
        esp_wifi_connect();
    } else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
        if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
            esp_wifi_connect();
            s_retry_num++;
            ESP_LOGI(TAG, "retry to connect to the AP");
            xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
        ESP_LOGI(TAG,"connect to the AP fail");
    } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
        ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
        ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
        s_retry_num = 0;
        xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
esp_netif_t *netif_ptr;
int teste;
void wifi_init_sta(void)
    s_wifi_event_group = xEventGroupCreate();
    netif_ptr = esp_netif_create_default_wifi_sta();
    assert(netif_ptr);
    esp_event_handler_instance_t instance_any_id;
    esp_event_handler_instance_t instance_got_ip;
    ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
                                                        ESP_EVENT_ANY_ID,
                                                        &event_handler,
                                                        NULL,
                                                        &instance_any_id));
    ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
                                                        IP_EVENT_STA_GOT_IP,
                                                        &event_handler,
                                                        NULL,
                                                        &instance_got_ip));
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = EXAMPLE_ESP_WIFI_SSID,
            .password = EXAMPLE_ESP_WIFI_PASS,
            /* Setting a password implies station will connect to all security modes including WEP/WPA.
             * However these modes are deprecated and not advisable to be used. Incase your Access point
             * doesn't support WPA2, these mode can be enabled by commenting below line */
	     .threshold.authmode = WIFI_AUTH_WPA2_PSK,
            .pmf_cfg = {
                .capable = true,
                .required = false
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_wifi_start() );
    ESP_LOGI(TAG, "wifi_init_sta finished.");
    /* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
     * number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
    EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
            WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
            pdFALSE,
            pdFALSE,
            portMAX_DELAY);
    /* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
     * happened. */
    if (bits & WIFI_CONNECTED_BIT) {
        ESP_LOGI(TAG, "connected to ap SSID:%s password:%s",
                 EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
    } else if (bits & WIFI_FAIL_BIT) {
        ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s",
        ESP_LOGE(TAG, "UNEXPECTED EVENT");
    /* The event will not be processed after unregister */
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
    vEventGroupDelete(s_wifi_event_group);
// ******************************************* MODBUS *************************************************
// Enumeration of modbus slave addresses accessed by master device
enum {
    MB_DEVICE_ADDR1 = 3,
    MB_SLAVE_COUNT
// Enumeration of all supported CIDs for device
enum {
    CID_TENSAO = 0,
    CID_SW_VER1,
    CID_TEMP_DATA_1,
const mb_parameter_descriptor_t* param_descriptor = NULL;
    uint8_t temp_data[4] = {0}; // temporary buffer to hold maximum CID size
    uint8_t type = 0;
    uint16_t cid = 0;
static esp_err_t read_modbus_parameter(uint16_t cid, uint16_t *par_data)
    esp_err_t err = mbc_master_get_cid_info(cid, &param_descriptor);
    if ((err != ESP_ERR_NOT_FOUND) && (param_descriptor != NULL)) {
        uint8_t type = 0;
        err = mbc_master_get_parameter(cid, (char*)param_descriptor->param_key,
                                                        (uint8_t*)par_data, &type);
        if (err == ESP_OK) {
            ESP_LOGI(MASTER_TAG, "Characteristic #%d %s (%s) value = (0x%04x) parameter read successful.",
                                     param_descriptor->cid,
                                     (char*)param_descriptor->param_units,
                                     *(uint16_t*)par_data);
        else
            ESP_LOGE(MASTER_TAG, "Characteristic #%d %s (%s), parameter read fail.",
                                    (char*)param_descriptor->param_units);
    return err;
static esp_err_t write_modbus_parameter(uint16_t cid, uint16_t *par_data)
        uint8_t type = 0; // type of parameter from dictionary
        err = mbc_master_set_parameter(cid, (char*)param_descriptor->param_key,
            ESP_LOGI(MASTER_TAG, "Characteristic #%d %s (%s) value = (0x%04x), write successful.",
            ESP_LOGE(MASTER_TAG, "Characteristic #%d (%s) write fail, err = 0x%x (%s).",
                                    (int)err,
                                    (char*)esp_err_to_name(err));
    return err;
// This is user function to read and write modbus holding registers
static void master_read_write_func(void *arg)
    esp_err_t err = ESP_OK;
    uint16_t register_data = 0;
    ESP_LOGI(MASTER_TAG, "Start modbus test...");
    for(uint16_t retry = 0; retry <= 5; retry++) {
        // Simply read your register here CID_DEV_REG0 - one register from address 0 (see device_parameters)
        err = read_modbus_parameter(CID_TENSAO, &register_data);
            // if read successful then increase value of the parameter
            // Insert your modbus read_write register functionality here
            register_data += 1;
            err = write_modbus_parameter(CID_TENSAO, &register_data);
        /*err = read_modbus_parameter(CID_DEV_REG1, &register_data);
            register_data += 1;
            err = write_modbus_parameter(CID_DEV_REG1, &register_data);
    ESP_LOGI(MASTER_TAG, "Modbus test is completed.");
// Inicializar MODBUS
static esp_err_t master_init(void){
    //  Dicionário MODBUS
    // Example Data Dictionary for Modbus parameters in 1 slave in the segment
    mb_parameter_descriptor_t device_parameters[] = {
        // CID, Name, Units, Modbus addr, register type, Modbus Reg Start Addr, Modbus Reg read length,
        // Instance offset (NA), Instance type, Instance length (bytes), Options (NA), Permissions
        { CID_TENSAO, STR("Tensão_1"), STR("V"), MB_DEVICE_ADDR1, MB_PARAM_HOLDING, 0, 2,
                        0, PARAM_TYPE_U16, 2, OPTS( 0,0,0 ), PAR_PERMS_READ_WRITE_TRIGGER },
    // Calculate number of parameters in the table
    const uint16_t num_device_parameters = (sizeof(device_parameters)/sizeof(device_parameters[0]));
    #define MB_SLAVE_COUNT 1 // Number of slaves in the segment being accessed (as defined in Data Dictionary)
    void* master_handler = NULL; // Pointer to allocate interface structure
    // Initialization of Modbus slave for TCP
    esp_err_t err = mbc_master_init_tcp(&master_handler);
    if (master_handler == NULL || err != ESP_OK) {
    // Error handling is performed here
    ESP_LOGE(MASTER_TAG, "mb controller initialization fail.");
    char* slave_ip_address_table[MB_SLAVE_COUNT] = {
    "192.168.1.180",     // Address corresponds to UID1 and set to predefined value by user
     mb_communication_info_t comm_info = {
    .ip_port = MB_TCP_PORT,                                 // Modbus TCP port number (default = 502)
    .ip_addr_type = MB_IPV4,                                // version of IP protocol
    .ip_mode = MB_MODE_TCP,                                 // Port communication mode
    .ip_addr = slave_ip_address_table,               // assign table of IP addresses
    .ip_netif_ptr = netif_ptr     // esp_netif_ptr pointer to the corresponding network interface
    ESP_ERROR_CHECK(mbc_master_setup((void*)&comm_info));
    ESP_ERROR_CHECK(mbc_master_set_descriptor(&device_parameters[0], num_device_parameters));
    // Início comunicação MODBUS
    esp_err_t err1 = mbc_master_start();
    if (err1 != ESP_OK) {
        ESP_LOGE(MASTER_TAG, "mb controller start fail, err=%x.", err1);
    vTaskDelay(5);
    esp_err_t err2 = mbc_master_set_descriptor(&device_parameters[0], num_device_parameters);
    MASTER_CHECK((err2 == ESP_OK), ESP_ERR_INVALID_STATE,
                                "mb controller set descriptor fail, returns(0x%x).",
                                (uint32_t)err2);
    ESP_LOGI(MASTER_TAG, "Modbus master stack initialized...");
    return err2;
void app_main(void)
    // *************************************************** Conectar wi-fi ***************************************************
    //Initialize NVS
    ESP_ERROR_CHECK(ret);
    ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
    wifi_init_sta();
    vTaskDelay(50);
    // ***************************************************** Modbus TCP *****************************************************
    // Initialization of device peripheral and objects
    ESP_ERROR_CHECK(master_init());
    vTaskDelay(50);
    master_read_write_func(NULL);
    // Processamento de dados
    // Criptografia
    // Envio de dados
ESP_alisitsyn
Contact:
Re: Edited: Need help with MODBUS TCP on esp32 (wroom-32D - devkitc-v4)
Postby ESP_alisitsyn » Fri Oct 15, 2021 9:23 am
@pmoneta,
Please add the NULL at the end of IP address table:`
char* slave_ip_address_table[MB_SLAVE_COUNT + 1] = {
    NULL                      // <<<<<<<<<<<< End of slave address list condition
Please try this change and post result here. Thanks.
pmoneta
Postby pmoneta » Fri Oct 15, 2021 12:45 pm
now it's connecting!! thanks for the reply!!!!
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6900
load:0x40078000,len:14308
load:0x40080400,len:3716
0x40080400: _init at ??:?
entry 0x40080680
I (27) boot: ESP-IDF v4.3.1-dirty 2nd stage bootloader
I (27) boot: compile time 19:13:31
I (27) boot: chip revision: 1
I (30) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (37) boot.esp32: SPI Speed      : 40MHz
I (42) boot.esp32: SPI Mode       : DIO
I (47) boot.esp32: SPI Flash Size : 4MB
I (51) boot: Enabling RNG early entropy source...
I (57) boot: Partition Table:
I (60) boot: ## Label            Usage          Type ST Offset   Length
I (67) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (75) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (82) boot:  2 factory          factory app      00 00 00010000 00100000
I (90) boot: End of partition table
I (94) boot_comm: chip revision: 1, min. application chip revision: 0
I (146) esp_image: segment 1: paddr=00028440 vaddr=3ffb0000 size=042b8h ( 17080) load
I (153) esp_image: segment 2: paddr=0002c700 vaddr=40080000 size=03918h ( 14616) load
I (159) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=76dc8h (486856) map
I (336) esp_image: segment 4: paddr=000a6df0 vaddr=40083918 size=11830h ( 71728) load
I (366) esp_image: segment 5: paddr=000b8628 vaddr=50000000 size=00010h (    16) load
I (376) boot: Loaded app from partition at offset 0x10000
I (377) boot: Disabling RNG early entropy source...
I (388) cpu_start: Pro cpu up.
I (388) cpu_start: Starting app cpu, entry point is 0x40081394
0x40081394: call_start_cpu1 at C:/esp-idf/components/esp_system/port/cpu_start.c:141
I (375) cpu_start: App cpu up.
I (403) cpu_start: Pro cpu start user code
I (403) cpu_start: cpu freq: 160000000
I (403) cpu_start: Application information:
I (407) cpu_start: Project name:     TCC
I (412) cpu_start: App version:      1
I (416) cpu_start: Compile time:     Oct 13 2021 19:16:20
I (422) cpu_start: ELF file SHA256:  b35a8658041a515c...
I (428) cpu_start: ESP-IDF:          v4.3.1-dirty
I (434) heap_init: Initializing. RAM available for dynamic allocation:
I (441) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (447) heap_init: At 3FFB82F0 len 00027D10 (159 KiB): DRAM
I (453) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (459) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (466) heap_init: At 40095148 len 0000AEB8 (43 KiB): IRAM
I (473) spi_flash: detected chip: generic
I (477) spi_flash: flash io: dio
I (482) cpu_start: Starting scheduler on PRO CPU.
I (534) wifi station: ESP_WIFI_MODE_STA
I (554) wifi:wifi driver task: 3ffc1f9c, prio:23, stack:6656, core=0
I (554) system_api: Base MAC address is not set
I (554) system_api: read default base MAC address from EFUSE
I (574) wifi:wifi firmware version: 88c8747
I (574) wifi:wifi certification version: v7.0
I (574) wifi:config NVS flash: enabled
I (574) wifi:config nano formating: disabled
I (574) wifi:Init data frame dynamic rx buffer num: 32
I (574) wifi:Init management frame dynamic rx buffer num: 32
I (584) wifi:Init management short buffer num: 32
I (584) wifi:Init dynamic tx buffer num: 32
I (594) wifi:Init static rx buffer size: 1600
I (594) wifi:Init static rx buffer num: 10
I (604) wifi:Init dynamic rx buffer num: 32
I (604) wifi_init: rx ba win: 6
I (604) wifi_init: tcpip mbox: 32
I (614) wifi_init: udp mbox: 6
I (614) wifi_init: tcp mbox: 6
I (624) wifi_init: tcp tx win: 5744
I (624) wifi_init: tcp rx win: 5744
I (624) wifi_init: tcp mss: 1440
I (634) wifi_init: WiFi IRAM OP enabled
I (634) wifi_init: WiFi RX IRAM OP enabled
I (644) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
I (744) wifi:mode : sta (24:0a:c4:b0:04:24)
I (744) wifi:enable tsf
I (744) wifi station: wifi_init_sta finished.
I (754) wifi:new:<1,1>, old:<1,0>, ap:<255,255>, sta:<1,1>, prof:1
I (754) wifi:state: init -> auth (b0)
I (764) wifi:state: auth -> assoc (0)
I (764) wifi:state: assoc -> run (10)
I (844) wifi:connected with D-Link_DIR-615, aid = 1, channel 1, 40U, bssid = 70:62:b8:7e:e5:a4
I (844) wifi:security: WPA2-PSK, phy: bgn, rssi: -50
I (844) wifi:pm start, type: 1
W (864) wifi:<ba-add>idx:0 (ifx:0, 70:62:b8:7e:e5:a4), tid:0, ssn:2, winSize:64
I (874) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (2034) esp_netif_handlers: sta ip: 192.168.0.5, mask: 255.255.255.0, gw: 192.168.0.1
I (2034) wifi station: got ip:192.168.0.5
I (2034) wifi station: connected to ap SSID:D-Link_DIR-615 password:12345678
I (2544) MB_TCP_MASTER_PORT: TCP master stack initialized.
I (2544) MB_TCP_MASTER_PORT: Host[IP]: "192.168.0.21"[192.168.0.21]
I (2544) MB_TCP_MASTER_PORT: Add slave IP: 192.168.0.21
I (2544) MB_TCP_MASTER_PORT: Connecting to slaves...
-I (2564) MB_TCP_MASTER_PORT: Connected 1 slaves, start polling...
I (2614) MASTER_TEST: Modbus master stack initialized...
I (3114) MASTER_TEST: Start modbus test...
PC      : 0x400014fd  PS      : 0x00060d30  A0      : 0x8013d158  A1      : 0x3ffbab90
A2      : 0x0000000c  A3      : 0x00000008  A4      : 0x000000ff  A5      : 0x0000ff00
A6      : 0x00ff0000  A7      : 0xff000000  A8      : 0x00000000  A9      : 0x3ffbab50
A10     : 0x00000000  A11     : 0x3ffbaf65  A12     : 0x3ffbadd4  A13     : 0x3ffaef6c
A14     : 0x00000000  A15     : 0x00000001  SAR     : 0x00000004  EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000000c  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xffffffff
Backtrace:0x400014fa:0x3ffbab90 0x4013d155:0x3ffbaba0 0x4013e7c5:0x3ffbaeb0 0x40146dcd:0x3ffbaee0 0x4008e461:0x3ffbaf10 0x400d6465:0x3ffbaf60 0x400d68ca:0x3ffbafa0 0x400d6977:0x3ffbafd0 0x40146ae5:0x3ffbaff0 0x4008c0e5:0x3ffbb010
0x4013d155: _vfprintf_r at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/stdio/vfprintf.c:1528
0x4013e7c5: vprintf at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/stdio/vprintf.c:34 (discriminator 5)
0x40146dcd: esp_log_writev at C:/esp-idf/components/log/log.c:189
0x4008e461: esp_log_write at C:/esp-idf/components/log/log.c:199
0x400d6465: read_modbus_parameter at C:\Users\Avell\projetos_vscode\TCC\build/../main/main.c:195 (discriminator 13)
0x400d68ca: master_read_write_func at C:\Users\Avell\projetos_vscode\TCC\build/../main/main.c:248
0x400d6977: app_main at C:\Users\Avell\projetos_vscode\TCC\build/../main/main.c:353 (discriminator 2)
0x40146ae5: main_task at C:/esp-idf/components/freertos/port/port_common.c:133 (discriminator 2)
0x4008c0e5: vPortTaskWrapper at C:/esp-idf/components/freertos/port/xtensa/port.c:168
ESP_alisitsyn
Contact:
Postby ESP_alisitsyn » Tue Oct 19, 2021 10:35 am
@pmoneta ,
Good to hear it helps. I guess that your second issue is pretty simple to solve.
Users browsing this forum: No registered users and 132 guests
