I have a project that is using one interrupt but when the gpio activates the interrupt, the ESP32 keeps panicking and resetting.
If I comment out the interrupt setup and handler it works fine. Not sure what I have done wrong here. Using VScode with ESP-IDF 4.3, ESP-IDF extension v1.2.0. Device is WROOM 32
The interrupt and the semaphore it sets are in 1 module and the function that takes the semaphore in another. The interrupt signal is on the pin for 103ms and then off for 64ms till next interrupt. The interrupt is set up to trigger on positive going edge of the gpio.
First Module that sets up the interrupt and GPIO
[code]
xSemaphoreHandle got_wake;
static void IRAM_ATTR wake_interrupt(void* args)
xSemaphoreGiveFromISR(got_wake,false);
void io_init(void)
gpio_pad_select_gpio(WAKE);
gpio_set_direction(WAKE,GPIO_MODE_INPUT);
gpio_pullup_dis(WAKE);
gpio_pulldown_en(WAKE);
gpio_set_intr_type(WAKE,GPIO_INTR_POSEDGE);
gpio_install_isr_service(ESP_INTR_FLAG_DEFAULT); //was 0
gpio_isr_handler_add(WAKE,wake_interrupt,(void*) WAKE);
got_wake = xSemaphoreCreateBinary();
[/code]
SECOND module that uses the semaphore set in the interrupt
[code]
extern xSemaphoreHandle got_wake;
void lf_process(void * params)
while(1)
xSemaphoreTake(got_wake,portMAX_DELAY);
printf("Got Wake\n");
void init_lf(void)
xTaskCreate(&lf_process,"do wake process",4096*2,NULL,1,NULL);
[/code]
Error at Runtime when WAKE gpio pin goes high
ESP32 panics when using interrupt
Users browsing this forum: Bing [Bot], steevke and 52 guests
