Bluetooth doesn’t work / flash_erase
filipesdkerplunk
Postby filipesdkerplunk » Tue Oct 19, 2021 9:44 pm
Hi!
I've been having issues with my ESP32 which I think are flash memory issues. In my ESP32 there was data in SPIFFS, EEPROM and wifi chip. I recently erased all flash memory with esptools and the erase_flash command. Thus, it erased both the saved information from wifi, data in EEPROM and data from SPIFFS. However, I went to test the bluetooth and it no longer connects to any device and before I erased the flash, it worked. The same sketch worked on another ESP32. It's the actual example sketch:
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
  SerialBT.begin("ESP32test"); //Bluetooth device name
  Serial.println("The device started, now you can pair it with bluetooth!");
  if (Serial.available()) {
    SerialBT.write(Serial.read());
  if (SerialBT.available()) {
    Serial.write(SerialBT.read());
  delay(20);
I would also like to know if all these SPIFFS, EEPROM and WIFI data writes are written in the same place. I'm new to Arduino and C++, but if they are saved in the same location, is there a chance that one EEPROM write and another SPIFFS write overlap, or some other information overlap? Is it correct or smart to use both SPIFFS and EEPROM in the same sketch?
But that's it, I started having problems with ESP32 after I made EEPROM writes and after I decided to erase the entire flash memory and now I don't know if there are any solutions.
Thank you!
Users browsing this forum: Baidu [Spider], Bing [Bot] and 100 guests
