(solved) sdkconfig.defaults not being (completely) read
mzimmers
Postby mzimmers » Tue Nov 16, 2021 4:59 pm
Hi all -
I'm trying to set up my project for use with an sdkconfig.defaults file. One of the settings (flash size) doesn't seem to be read. Here's the file:
# the device used on this project has 8MB of flash.
CONFIG_ESPTOOLPY_FLASHSIZE="8MB"
# we use a custom partition table on this project.
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_FILENAME="partitions.csv"
# the line below is necessary until Espressif fixes its expired certificat of 11/2021.
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE is not set
And upon attempting to build, I get this error:
FAILED: partition_table/partition-table.bin
cmd.exe /C "cd /D C:\Users\mzimmers\fluidra\cp_fluidra\fw\build\esp-idf\partition_table && C:\Users\mzimmers\.espressif\python_env\idf4.3_py3.8_env\Scripts\python.exe C:/Users/mzimmers/esp-idf/components/partition_table/gen_esp32part.py -q --offset 0x8000 --flash-size 2MB C:/Users/mzimmers/fluidra/cp_fluidra/fw/partitions.csv C:/Users/mzimmers/fluidra/cp_fluidra/fw/build/partition_table/partition-table.bin && C:\Users\mzimmers\.espressif\tools\cmake\3.16.4\bin\cmake.exe -E echo "Partition table binary generated. Contents:" && C:\Users\mzimmers\.espressif\tools\cmake\3.16.4\bin\cmake.exe -E echo ******************************************************************************* && C:\Users\mzimmers\.espressif\python_env\idf4.3_py3.8_env\Scripts\python.exe C:/Users/mzimmers/esp-idf/components/partition_table/gen_esp32part.py -q --offset 0x8000 --flash-size 2MB C:/Users/mzimmers/fluidra/cp_fluidra/fw/build/partition_table/partition-table.bin && C:\Users\mzimmers\.espressif\tools\cmake\3.16.4\bin\cmake.exe -E echo *******************************************************************************"
Partitions defined in 'C:/Users/mzimmers/fluidra/cp_fluidra/fw/partitions.csv' occupy 4.0MB of flash (4194304 bytes) which does not fit in configured flash size 2MB. Change the flash size in menuconfig under the 'Serial Flasher Config' menu.
And, indeed, in my newly-generated sdkconfig file, this is the setting:
CONFIG_ESPTOOLPY_FLASHSIZE_2MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_4MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_8MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_16MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="2MB"
Can someone see what I'm doing wrong?
Thanks...
chegewara
Re: sdkconfig.defaults not being (completely) read
Postby chegewara » Tue Nov 16, 2021 5:28 pm
Did you make clean build after preparing sdkconfig.defaults?
idf.py fullclean && idf.py build
mzimmers
Postby mzimmers » Tue Nov 16, 2021 5:32 pm
Hi Chegewara - yes I did.
chegewara
Postby chegewara » Tue Nov 16, 2021 5:39 pm
CONFIG_ESPTOOLPY_FLASHSIZE_8MB=y
mzimmers
Postby mzimmers » Tue Nov 16, 2021 5:48 pm
Still getting the same error. Tried using that line both with, and instead of, the original line.
chegewara
Postby chegewara » Tue Nov 16, 2021 6:02 pm
This should be enough, just delete build folder and rebuild project (and maybe delete sdkconfig too).
https://github.com/espressif/esp-idf/bl ... g.defaults
mzimmers
Postby mzimmers » Tue Nov 16, 2021 6:50 pm
Hi chegewara -
Yes, that did fix it. (It turns out I had two build directories at different levels in the project; once I deleted both of them, your fix worked.)
Thanks for the help.
Users browsing this forum: tomy983 and 121 guests
