I have a project flashed to ESp32 using DIO SPI flash mode, this project has a factory and 2 ota partitions. I accidentally changed SPI flash mode to QIO when building a newer version of the firmware, and it was installed using OTA.
Now the module does't boot anymore because of a mismatch between the SPI flash mode I initially flashed it with, and the new update which was built using QIO.
Is it possible to manually change the SPI flash mode from within the code without performing a full chip erase? ESp32 does randomly boot up from time to time, but its unpredictable due to this mismatch. Any help is appreciated.
Changing SPI flash mode from app
Users browsing this forum: Bing [Bot], Corand, MicroController and 244 guests
