My router is a 2.4g/5g dual band hybrid. Esp32 cannot connect.
I have used my computer to test that WiFi has 2.4G band and can be connected through 2.4G band.
What should I do to connect the eps32 to the router through the 2.4G band?
Who has experienced similar problems? Can you help me? thank you very much!
How to connect esp32 to 2.4/5g dual band WiFi?
Re: How to connect esp32 to 2.4/5g dual band WiFi?
I've solved it. Two points to note:
1. Set the correct authentication mode.
2. Check the channel of 2.4G band through the computer and set it in esp32.
Users browsing this forum: netfox and 175 guests
