Hello, I execute install.sh export.sh and all works fine, can write firm in my esp with no problem.
But when close my shell and reopenit, virtual env of esp idf remains active, all system python path is in
/root/.espressif/python_env/idf5.0_py3.8_env.
When run "which python" have this response
.espressif/python_env/idf5.0_py3.8_env/bin/python
I tried instructions from this post https://www.esp32.com/viewtopic.php?t=12481, the virtual env disapering when delete virtual env path
.espressif/python_env/idf5.0_py3.8_env/bin/python and works fine this solution.
My question is, allways need delete path for reseting virtualenv?
Don't have any way more easy and smart?
Kali linux,
esp-idf latest
D'ont exit of virtual env of esp-idf
- ESP_Roland
Re: D'ont exit of virtual env of esp-idf
Please check the configuration files of your shell (probably bash). Maybe you have updated there PATH or you have sourced export.sh there. Some of the older guides suggested to do this.
Users browsing this forum: Bing [Bot] and 104 guests
