How do I save a variable in the nvs?
I'm looking at the sample nvs_value_example_main, and I can't understand a thing!!!
Say I've got 5 different variables that I want to save into the nvs, and retrieve them whenever I want.
variable_1
variable_2
variable_3
variable_4
variable_5
Can someone give me an example on how to do it?
In the example supplied there is just one single int32_t restart_counter
But I can't understand the address where is being written, and where to read it from whenever you want.
Or is it that you don't assign them an address, but the operating system is looking just for the name of the variable?
Can someone illuminate me please, I'm in total darkness.
how do I save variables into the nvs?
Re: how do I save variables into the nvs?
NVS variables aren't stored by address, they're stored by key, where a 'key' is a short string. For instance, in the example:
the 2nd argument is the key. The key and the variable are called the same, which may be confusing, so let me change it a bit:
You're effectively saying "Hey nvs, fetch the value I stored under "restart_counter" and dump it into the 'myvar' variable".
nvs_get_i32(my_handle, "restart_counter", &restart_counter);
int32_t myvar;
nvs_get_i32(my_handle, "restart_counter", &myvar);
printf("Restart counter is %d\n", myvar);
Thanks ESP_Sprite
Very good explanation, and easy to understand.
When running the supplied example in nvs_value_example_main everything works perfectly.
But obviously, nobody is using reading and writing to-from NVS in one single go, as in the example supplied.
Everybody writes now, and reads it back much later.
So I have tried to split it in two separate parts:
one Reading
and one writing.
And now writing is not working.
Now I get FAILED when trying to write into the NVS.
Why?
variables defined globally:
reading from NVS:
Writing to the NVS:
my flash_wr_size is 327680 in this case
what is "storage" in:
one Reading
and one writing.
Why?
int32_t user_msg1_length = 0; // value will default to 0, if not set yet in NVS
esp_err_t err ;
// Initialize NVS
err = nvs_flash_init();
if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) {
// NVS partition was truncated and needs to be erased
// Retry nvs_flash_init
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK( err );
// Open
printf("\n");
printf("Opening Non-Volatile Storage (NVS) handle to Read only... ");
nvs_handle_t my_handle;
err = nvs_open("storage", NVS_READONLY, &my_handle);
if (err != ESP_OK) {
printf("Error (%s) opening NVS handle!\n", esp_err_to_name(err));
} else {
printf("Done\n");
/* Read from NVS: */
printf("Reading length of first User Message from NVS ... ");
err = nvs_get_i32(my_handle, "user_msg1_length", &user_msg1_length);
switch (err) {
case ESP_OK:
printf("Done\n");
printf("First User Message length = %d\n", user_msg1_length);
break;
case ESP_ERR_NVS_NOT_FOUND:
printf("The value is not initialized yet!\n");
break;
default :
printf("Error (%s) reading!\n", esp_err_to_name(err));
// Close
nvs_close(my_handle);
// Open
printf("\n");
printf("Opening Non-Volatile Storage (NVS) handle to Write ... ");
err = nvs_open("storage", NVS_READWRITE, &my_handle);
} else {
printf("Done\n");
// Write value into the NVS
printf("Updating the length of first User Message in NVS ... ");
user_msg1_length = flash_wr_size;
err = nvs_set_i32(my_handle, "user_msg1_length", user_msg1_length);
printf((err != ESP_OK) ? "Failed!\n" : "Done\n");
// Commit written value.
// After setting any values, nvs_commit() must be called to ensure changes are written
// to flash storage. Implementations may write to storage at other times,
// but this is not guaranteed.
printf("Committing updates in NVS ... ");
err = nvs_commit(my_handle);
// Close
The maximum length of a NVS key is 15 characters: https://docs.espressif.com/projects/esp ... and-values, the key "user_msg1_length" you used is 16 characters.
Thanks markkuk
works perfect now.
works perfect now.
Users browsing this forum: No registered users and 253 guests
