Successful connection of Segger J-Link for JTAG use
justinmreina
Postby justinmreina » Fri Jul 21, 2017 3:57 am
I am trying to get ESP32 JTAG debugging working, and I am having a hard time establishing connection. I am using the following setup & instructions:
Setup Instructions Problem
At Step 3.3.3 I cannot get my Segger to be recognized & used in OpenOCD. It is attached to my Virtualbox as follows (from dmesg):
dmesg output from connected Segger
[ 73.722856] usb 2-2: new full-speed USB device number 3 using ohci-pci
[ 74.270737] usb 2-2: New USB device found, idVendor=1366, idProduct=0101
[ 74.270741] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 74.270744] usb 2-2: Product: J-Link
[ 74.270746] usb 2-2: Manufacturer: SEGGER
[ 74.270748] usb 2-2: SerialNumber: 000269402770
How do you get the Segger to work for OpenOCD here, what is the target value to use for Step 3.3.3? Are there any examples that use the Segger for reference?
So excited to get JTAG working here, please let me know! :)
Re: Successful connection of Segger J-Link for JTAG User
Postby ESP_Sprite » Fri Jul 21, 2017 7:02 am
Edit the copied esp32.cfg file. Most importantly, change the source [find interface/ftdi/tumpa.cfg] line to reflect the physical JTAG adapter connected. (Note that this step is not needed when using the ESP-WROVER-KIT
What did you do at this step?
justinmreina
Postby justinmreina » Fri Jul 21, 2017 1:41 pm
Nothing yet, that is where I got stuck!
Re: Successful connection of Segger J-Link for JTAG use
Postby ESP_Sprite » Fri Jul 21, 2017 2:59 pm
If you change that line to '[find tcl/interface/jlink.cfg]', it should work.
justinmreina
Postby justinmreina » Fri Jul 21, 2017 4:29 pm
what is 'esp108', how do I get this working?
Now I see -
./esp32.cfg:48: Error: invalid command name "esp108"
in procedure 'script'
at file "embedded:startup.tcl", line 60
at file "./esp32.cfg", line 48
caco666
Postby caco666 » Mon Aug 21, 2017 3:08 pm
Hi Justin,
Did you manage to make this work?
I kind of managed OpenOCD work with JLink but then (for some reason) after updating to the latest changes in OpenOCD repository this stopped working correctly.
[Sorry, this is my first post here]
I am using this post as a reference because the previous 'esp108' command stopped working: http://bbs.esp32.com/viewtopic.php?f=2&t=2404
Then, when running the result is:
src/openocd -s tcl -f ./tcl/interface/jlink.cfg -f ./tcl/board/esp-wroom-32.cfg Open On-Chip Debugger 0.10.0-dev-gcc5b0f7 (2017-08-21-15:36)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
force hard breakpoints
Info : No device selected, using first device.
Info : J-Link ARM V8 compiled Nov 28 2014 13:44:46
Info : Hardware version: 8.00
Info : VTarget = 3.306 V
Info : Reduced speed from 20000 kHz to 12000 kHz (maximum).
Info : clock speed 20000 kHz
Info : Target halted. PRO_CPU: PC=0x4014689C (active)    APP_CPU: PC=0x00000000
Then, after that I can only connect to port 3333 (port 3334 is not open).
When connecting with GDB, I get this:
xtensa-esp32-elf-gdb -ex 'target remote localhost:3333' ./build/abb-esp32-fw.elf
GNU gdb (crosstool-NG crosstool-ng-1.22.0-61-gab8375a) 7.10
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-build_pc-linux-gnu --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./build/abb-esp32-fw.elf...done.
Remote debugging using localhost:3333
0x00000000 in ?? ()
(gdb) monitor targets
    TargetName         Type       Endian TapName            State
 0* esp32              esp32      little esp32.cpu0         halted
(gdb)
Before updating to the latest changes I could connect to both CPUs and this command showed two items, one per CPU.
I see some changes were done on esp32.cfg and a esp108.cfg file was added for the case of using one CPU.
Could anyone give some hing on what could be the problem?
Thank you.
Cheers
Users browsing this forum: No registered users and 128 guests
