Hi @Ashvajit.P,
Sorry for the late response, please try to use the last patch from the topic below and increase the CONFIG_FMB_MASTER_TIMEOUT_MS_RESPOND, and disable the CONFIG_FMB_TIMER_PORT_ENABLED value in Modbus configuration.
https://github.com/espressif/esp-idf/issues/6134
Unfortunately, I can not provide you with the exact solution for this issue because I need more information about your projects and versions of IDF.
ESP32 MODBUS descriptor CID field issue
- Contact:
Re: ESP32 MODBUS descriptor CID field issue
The following are my project and IDF details for the same project.
ESP_IDF checkout : v4.3.1
Toolchain : GCC 8.4.0, GDB : 8.1.0, ESP-IDF 4.2, Revision 6
Let me know if I am missing anything.
Also I observed that after restarting ESP after programming the first time. Resource release failure is occurring rarely.
I also wanted to know that are there any available APIs for multiple write and read MODBUS registers
instead of using single read/write commands ?
- Contact:
Thank you for information.
Currently for reading and writing the holding registers stack uses the MB_FUNC_READ_HOLDING_REGISTER:MB_FUNC_WRITE_MULTIPLE_REGISTERS accordingly. It is a pretty typical approach for Modbus master. If absolutely required you can use the API https://github.com/espressif/esp-idf/bl ... ter.c#L166 that can be made public for your project through CMakeLists.txt file.
The resource release failure can be related to the slave response after timeout.
Please try to apply the v4.3 patch from this post to solve the issue:
Please then increase the CONFIG_FMB_MASTER_TIMEOUT_MS_RESPOND time in kconfig and disable the CONFIG_FMB_TIMER_PORT_ENABLED.
Let me know If you have any issues applying the patch. There is a delay with the final solution but it will be available soon.
Thanks for the response ,
I'll try to apply the pacth for the resource failure issue.
Do you have any reference/ example to implement multiple read/ write registers using above mentioned function. I did found that static API (esp_err_t mbc_serial_master_send_request(mb_param_request_t* request, void* data_ptr)) while searching through the library but not sure how to implement it.If absolutely required you can use the API https://github.com/espressif/esp-idf/bl ... ter.c#L166 that can be made public for your project through CMakeLists.txt file.
- Contact:
@Ashvajit.P
The `mbc_serial_master_send_request(mb_param_request_t* request, void* data_ptr));` can be accessed through the function `mbc_master_send_request()`
https://github.com/espressif/esp-idf/bl ... ster.c#L83 which will translate the call to `mbc_serial_master_send_request()`.
An example of using of the function for standard commands:
https://github.com/alisitsyn/modbus_sup ... r.cpp#L173
The `mbc_serial_master_send_request` can be made public by removing the `static` attribute and exposing the func prototype through the your project CMakeLists.txt. The dependency injection technique can allow calling this static func from your code as well.
However, it is a hard tricks and I do not recommend this because of the public available API.
I implemented MODBUS read/write using the API you suggested and it is working now.
Thanks for your support !!
- Contact:
@Ashvajit.P ,
You are welcome! Good luck with your project!
Users browsing this forum: No registered users and 243 guests
