sleep mode + FreeRtos task
Is it possible to put the ESP32 in sleep mode while keeping a FreeRTOS with HIGHEST priority task active?
Re: sleep mode + FreeRtos task
Sleep mode is generally intended as a way to shut the CPU down... so no, not really, you can't have a CPU that is shutdown and also running a task; the CPU needs to wake up to do something.
Can you tell us a bit more on what you're trying to do? Perhaps we can help you better with some more info.
I have an ESp32 connected to a battery, doing stuff with WiFi MQTT and so on..
I would like to put in sleep mode in order to save battery, but I have connected to the ESP32 EN PIN a HW Watchdog, which is feeded by a FreeRtos task with HIGHEST priority.
I need to feed it with a square wave, and the reset time of the WDT is 1sec.
So I would like to put the ESP32 in sleep mode, but I need also that the task for the WDT won't stop.
Hope is clear enough
What particular sleep mode do you mean? If light sleep, you can probably have the CPU wake up on a timer and flip the square wave bit. If deep sleep, you'd need to use the ULP to generate the square wave.
Users browsing this forum: Baidu [Spider] and 145 guests
