CMAKE and compiler defines
dovoto
Postby dovoto » Wed Jan 26, 2022 8:47 pm
I think I have a concept error and I could use some knowledge...
I have an idf project with the following structure (ish):
components
--component_1
----CMakeLists.txt
----sourc.cpp
--component_2
----CMakeLists.txt
----sourc.cpp
main
--main.cpp
--CMakeLists.txt
CMakeLists.txt
sdkcofig
My components require some processor defines and so in the top level CMakeLists.txt I do something like this:
cmake_minimum_required(VERSION 3.5)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
project(my_amazing_project)
add_compile_definitions(
  "DO_THING_A"
  "ENABLE_AWESOMENESS"
message(STATUS "Building: root")
Now, if i check the build.ninja file the DEFINES variable in the
# Order-only phony target for my_amazing_project.elf
has the correct defines...but these defines dont seem to be making it to the components (the compile command line output only has the -DESP_PLATFORM and version define set)
Do I need to set these defines some other way or at some other level in the cmake lists?
Thanks!
gtjoseph
Re: CMAKE and compiler defines
Postby gtjoseph » Thu Jan 27, 2022 1:08 pm
Things like add_compile_options and add_compile_definitions have to come before the "project" statement.
dovoto
Postby dovoto » Fri Jan 28, 2022 8:17 pm
Thanks!
  "DO_THING_A"
did the trick
Users browsing this forum: Baidu [Spider], Google [Bot] and 166 guests
