Build stopped, ninja failed, win10, universal online installer 2.13
Hello, I followed the installtion steps, but every time i got this error.
Can someone tell me where the problem is?
Setting PYTHONNOUSERSITE, was not set
Using Python in C:\Espressif\python_env\idf4.4_py3.8_env\Scripts\
Python 3.8.7
Using Git in C:\Espressif\tools\idf-git\2.34.2\cmd\
git version 2.34.1.windows.1
Setting IDF_PATH: C:\Espressif\frameworks\esp-idf-v4.4
Adding ESP-IDF tools to PATH...
C:\Espressif\tools\xtensa-esp32-elf\esp-2021r2-patch2-8.4.0\xtensa-esp32-elf\bin
C:\Espressif\tools\xtensa-esp32s2-elf\esp-2021r2-patch2-8.4.0\xtensa-esp32s2-elf\bin
C:\Espressif\tools\xtensa-esp32s3-elf\esp-2021r2-patch2-8.4.0\xtensa-esp32s3-elf\bin
C:\Espressif\tools\riscv32-esp-elf\esp-2021r2-patch2-8.4.0\riscv32-esp-elf\bin
C:\Espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin
C:\Espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin
C:\Espressif\tools\cmake\3.20.3\bin
C:\Espressif\tools\openocd-esp32\v0.11.0-esp32-20211220\openocd-esp32\bin
C:\Espressif\tools\ninja\1.10.2\
C:\Espressif\tools\idf-exe\1.0.3\
C:\Espressif\tools\ccache\4.3\ccache-4.3-windows-64
C:\Espressif\tools\dfu-util\0.9\dfu-util-0.9-win64
C:\Espressif\frameworks\esp-idf-v4.4\tools
Checking if Python packages are up to date...
Python requirements from C:\Espressif\frameworks\esp-idf-v4.4\requirements.txt are satisfied.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
C:\Espressif\frameworks\esp-idf-v4.4>cd %userprofile%
C:\Users\Michael Kremer>cd desktip
Das System kann den angegebenen Pfad nicht finden.
C:\Users\Michael Kremer>dc desktop
Der Befehl "dc" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
C:\Users\Michael Kremer>dc Desktop
C:\Users\Michael Kremer>cd desktop
C:\Users\Michael Kremer\Desktop>cd hello_world
C:\Users\Michael Kremer\Desktop\hello_world>idf.py set-target esp32
Adding "set-target"'s dependency "fullclean" to list of commands with default set of options.
Executing action: fullclean
Build directory 'c:\users\michael kremer\desktop\hello_world\build' not found. Nothing to clean.
Executing action: set-target
Set Target to: esp32, new sdkconfig created. Existing sdkconfig renamed to sdkconfig.old.
Running cmake in directory 'c:\users\michael kremer\desktop\hello_world\build'
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=1 'c:\users\michael kremer\desktop\hello_world'"...
-- Found Git: C:/Espressif/tools/idf-git/2.34.2/cmd/git.exe (found version "2.34.1.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- Found assembler: C:/Espressif/tools/xtensa-esp32-elf/esp-2021r2-patch2-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Espressif/tools/xtensa-esp32-elf/esp-2021r2-patch2-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe - skipped
-- Check for working CXX compiler: C:/Espressif/tools/xtensa-esp32-elf/esp-2021r2-patch2-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe - skipped
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Project sdkconfig file C:/Users/Michael Kremer/Desktop/hello_world/sdkconfig
-- Found PythonInterp: C:/Espressif/python_env/idf4.4_py3.8_env/Scripts/python.exe (found version "3.8.7")
-- Could NOT find Perl (missing: PERL_EXECUTABLE)
-- App "hello_world" version: 1
-- Adding linker script C:/Users/Michael Kremer/Desktop/hello_world/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/ld/esp32/sections.ld.in
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32/ld/esp32.rom.api.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32/ld/esp32.rom.newlib-time.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/soc/esp32/ld/esp32.peripherals.ld
-- Components: app_trace app_update asio bootloader bootloader_support bt cbor cmock coap console cxx driver efuse esp-tls esp32 esp_adc_cal esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_ipc esp_lcd esp_local_ctrl esp_netif esp_phy esp_pm esp_ringbuf esp_rom esp_serial_slave_link esp_system esp_timer esp_websocket_client esp_wifi espcoredump esptool_py expat fatfs freemodbus freertos hal heap idf_test ieee802154 jsmn json libsodium log lwip main mbedtls mdns mqtt newlib nghttp nvs_flash openssl openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport tcpip_adapter tinyusb ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: C:/Espressif/frameworks/esp-idf-v4.4/components/app_trace C:/Espressif/frameworks/esp-idf-v4.4/components/app_update C:/Espressif/frameworks/esp-idf-v4.4/components/asio C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader_support C:/Espressif/frameworks/esp-idf-v4.4/components/bt C:/Espressif/frameworks/esp-idf-v4.4/components/cbor C:/Espressif/frameworks/esp-idf-v4.4/components/cmock C:/Espressif/frameworks/esp-idf-v4.4/components/coap C:/Espressif/frameworks/esp-idf-v4.4/components/console C:/Espressif/frameworks/esp-idf-v4.4/components/cxx C:/Espressif/frameworks/esp-idf-v4.4/components/driver C:/Espressif/frameworks/esp-idf-v4.4/components/efuse C:/Espressif/frameworks/esp-idf-v4.4/components/esp-tls C:/Espressif/frameworks/esp-idf-v4.4/components/esp32 C:/Espressif/frameworks/esp-idf-v4.4/components/esp_adc_cal C:/Espressif/frameworks/esp-idf-v4.4/components/esp_common C:/Espressif/frameworks/esp-idf-v4.4/components/esp_eth C:/Espressif/frameworks/esp-idf-v4.4/components/esp_event C:/Espressif/frameworks/esp-idf-v4.4/components/esp_gdbstub C:/Espressif/frameworks/esp-idf-v4.4/components/esp_hid C:/Espressif/frameworks/esp-idf-v4.4/components/esp_http_client C:/Espressif/frameworks/esp-idf-v4.4/components/esp_http_server C:/Espressif/frameworks/esp-idf-v4.4/components/esp_https_ota C:/Espressif/frameworks/esp-idf-v4.4/components/esp_https_server C:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support C:/Espressif/frameworks/esp-idf-v4.4/components/esp_ipc C:/Espressif/frameworks/esp-idf-v4.4/components/esp_lcd C:/Espressif/frameworks/esp-idf-v4.4/components/esp_local_ctrl C:/Espressif/frameworks/esp-idf-v4.4/components/esp_netif C:/Espressif/frameworks/esp-idf-v4.4/components/esp_phy C:/Espressif/frameworks/esp-idf-v4.4/components/esp_pm C:/Espressif/frameworks/esp-idf-v4.4/components/esp_ringbuf C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom C:/Espressif/frameworks/esp-idf-v4.4/components/esp_serial_slave_link C:/Espressif/frameworks/esp-idf-v4.4/components/esp_system C:/Espressif/frameworks/esp-idf-v4.4/components/esp_timer C:/Espressif/frameworks/esp-idf-v4.4/components/esp_websocket_client C:/Espressif/frameworks/esp-idf-v4.4/components/esp_wifi C:/Espressif/frameworks/esp-idf-v4.4/components/espcoredump C:/Espressif/frameworks/esp-idf-v4.4/components/esptool_py C:/Espressif/frameworks/esp-idf-v4.4/components/expat C:/Espressif/frameworks/esp-idf-v4.4/components/fatfs C:/Espressif/frameworks/esp-idf-v4.4/components/freemodbus C:/Espressif/frameworks/esp-idf-v4.4/components/freertos C:/Espressif/frameworks/esp-idf-v4.4/components/hal C:/Espressif/frameworks/esp-idf-v4.4/components/heap C:/Espressif/frameworks/esp-idf-v4.4/components/idf_test C:/Espressif/frameworks/esp-idf-v4.4/components/ieee802154 C:/Espressif/frameworks/esp-idf-v4.4/components/jsmn C:/Espressif/frameworks/esp-idf-v4.4/components/json C:/Espressif/frameworks/esp-idf-v4.4/components/libsodium C:/Espressif/frameworks/esp-idf-v4.4/components/log C:/Espressif/frameworks/esp-idf-v4.4/components/lwip C:/Users/Michael Kremer/Desktop/hello_world/main C:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls C:/Espressif/frameworks/esp-idf-v4.4/components/mdns C:/Espressif/frameworks/esp-idf-v4.4/components/mqtt C:/Espressif/frameworks/esp-idf-v4.4/components/newlib C:/Espressif/frameworks/esp-idf-v4.4/components/nghttp C:/Espressif/frameworks/esp-idf-v4.4/components/nvs_flash C:/Espressif/frameworks/esp-idf-v4.4/components/openssl C:/Espressif/frameworks/esp-idf-v4.4/components/openthread C:/Espressif/frameworks/esp-idf-v4.4/components/partition_table C:/Espressif/frameworks/esp-idf-v4.4/components/perfmon C:/Espressif/frameworks/esp-idf-v4.4/components/protobuf-c C:/Espressif/frameworks/esp-idf-v4.4/components/protocomm C:/Espressif/frameworks/esp-idf-v4.4/components/pthread C:/Espressif/frameworks/esp-idf-v4.4/components/sdmmc C:/Espressif/frameworks/esp-idf-v4.4/components/soc C:/Espressif/frameworks/esp-idf-v4.4/components/spi_flash C:/Espressif/frameworks/esp-idf-v4.4/components/spiffs C:/Espressif/frameworks/esp-idf-v4.4/components/tcp_transport C:/Espressif/frameworks/esp-idf-v4.4/components/tcpip_adapter C:/Espressif/frameworks/esp-idf-v4.4/components/tinyusb C:/Espressif/frameworks/esp-idf-v4.4/components/ulp C:/Espressif/frameworks/esp-idf-v4.4/components/unity C:/Espressif/frameworks/esp-idf-v4.4/components/usb C:/Espressif/frameworks/esp-idf-v4.4/components/vfs C:/Espressif/frameworks/esp-idf-v4.4/components/wear_levelling C:/Espressif/frameworks/esp-idf-v4.4/components/wifi_provisioning C:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant C:/Espressif/frameworks/esp-idf-v4.4/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Michael Kremer/Desktop/hello_world/build
C:\Users\Michael Kremer\Desktop\hello_world>idf.py menueconfig
Executing action: menueconfig
ninja: error: unknown target 'menueconfig', did you mean 'menuconfig'?
command "menueconfig" is not known to idf.py and is not a Ninja target
C:\Users\Michael Kremer\Desktop\hello_world>idf.py menuconfig
Executing action: menuconfig
Running ninja in directory 'c:\users\michael kremer\desktop\hello_world\build'
Executing "ninja menuconfig"...
[0/1] cmd.exe /C "cd /D "C:\Users\Michael Kremer\Desktop\hello_w... config "C:/Users/Michael Kremer/Desktop/hello_world/sdkconfig""
C:/Espressif/frameworks/esp-idf-v4.4/Kconfig:14: warning: IDF_ENV_FPGA has 'option env="IDF_ENV_FPGA"', but the environment variable IDF_ENV_FPGA is not set
Loaded configuration 'C:/Users/Michael Kremer/Desktop/hello_world/sdkconfig'
No changes to save (for 'C:/Users/Michael Kremer/Desktop/hello_world/sdkconfig')
C:\Users\Michael Kremer\Desktop\hello_world>idf.py build
Executing action: all (aliases: build)
Executing "ninja all"...
[0/1] Re-running CMake...
-- Configuring done
-- Generating done
[3/1011] Generating ../../partition_table/partition-table.bin
Partition table binary generated. Contents:
# ESP-IDF Partition Table
nvs,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,1M,
[252/1011] Performing configure step for 'bootloader'
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader/subproject/main/ld/esp32/bootloader.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader/subproject/main/ld/esp32/bootloader.rom.ld
-- Components: bootloader bootloader_support efuse esp32 esp_common esp_hw_support esp_rom esp_system esptool_py freertos hal log main micro-ecc newlib partition_table soc spi_flash xtensa
-- Component paths: C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader_support C:/Espressif/frameworks/esp-idf-v4.4/components/efuse C:/Espressif/frameworks/esp-idf-v4.4/components/esp32 C:/Espressif/frameworks/esp-idf-v4.4/components/esp_common C:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom C:/Espressif/frameworks/esp-idf-v4.4/components/esp_system C:/Espressif/frameworks/esp-idf-v4.4/components/esptool_py C:/Espressif/frameworks/esp-idf-v4.4/components/freertos C:/Espressif/frameworks/esp-idf-v4.4/components/hal C:/Espressif/frameworks/esp-idf-v4.4/components/log C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader/subproject/main C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader/subproject/components/micro-ecc C:/Espressif/frameworks/esp-idf-v4.4/components/newlib C:/Espressif/frameworks/esp-idf-v4.4/components/partition_table C:/Espressif/frameworks/esp-idf-v4.4/components/soc C:/Espressif/frameworks/esp-idf-v4.4/components/spi_flash C:/Espressif/frameworks/esp-idf-v4.4/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Michael Kremer/Desktop/hello_world/build/bootloader
[346/1011] Performing build step for 'bootloader'
[1/97] Generating project_elf_src_esp32.c
[2/97] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mpu_hal.c.obj
[3/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/soc_include_legacy_warn.c.obj
[4/97] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/wdt_hal_iram.c.obj
[5/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/adc_periph.c.obj
[6/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/lcd_periph.c.obj
[7/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2c_periph.c.obj
[8/97] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/cpu_hal.c.obj
[9/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/dac_periph.c.obj
[10/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/lldesc.c.obj
[11/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/gpio_periph.c.obj
[12/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/interrupts.c.obj
[13/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/ledc_periph.c.obj
[14/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2s_periph.c.obj
[15/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/pcnt_periph.c.obj
[16/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_io_periph.c.obj
[17/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdio_slave_periph.c.obj
[18/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rmt_periph.c.obj
[19/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdmmc_periph.c.obj
[20/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sigmadelta_periph.c.obj
[21/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/touch_sensor_periph.c.obj
[22/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/mcpwm_periph.c.obj
[23/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/timer_periph.c.obj
[24/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/spi_periph.c.obj
[25/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/uart_periph.c.obj
[26/97] Building C object esp-idf/spi_flash/CMakeFiles/__idf_spi_flash.dir/esp32/spi_flash_rom_patch.c.obj
[27/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common_loader.c.obj
[28/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random_esp32.c.obj
[29/97] Building C object esp-idf/micro-ecc/CMakeFiles/__idf_micro-ecc.dir/uECC_verify_antifault.c.obj
[30/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_mem.c.obj
[31/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_init.c.obj
[32/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common.c.obj
[33/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console_loader.c.obj
[34/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random.c.obj
[35/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash.c.obj
[36/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[37/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/secure_boot.c.obj
[38/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[39/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj
[40/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_loader.c.obj
[41/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj
[42/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash_config_esp32.c.obj
[43/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_efuse_esp32.c.obj
[44/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_qio_mode.c.obj
[45/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[46/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console.c.obj
[47/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_table.c.obj
[48/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[49/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_fields.c.obj
[50/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_soc.c.obj
[51/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_utility.c.obj
[52/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_fields.c.obj
[53/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_sha.c.obj
[54/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_esp32.c.obj
[55/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_panic.c.obj
[56/97] Building C object esp-idf/esp_system/CMakeFiles/__idf_esp_system.dir/esp_err.c.obj
[57/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/compare_set.c.obj
[58/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api_key_esp32.c.obj
[59/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_utility.c.obj
[60/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_init.c.obj
[61/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_pm.c.obj
[62/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_clk_init.c.obj
[63/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/cpu_util.c.obj
[64/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_clk.c.obj
[65/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_time.c.obj
[66/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/chip_info.c.obj
[67/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_wdt.c.obj
[68/97] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_noos.c.obj
[69/97] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/eri.c.obj
[70/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_sleep.c.obj
[71/97] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
[72/97] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_buffers.c.obj
[73/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_tjpgd.c.obj
[74/97] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/xt_trax.c.obj
[75/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_crc.c.obj
[76/97] Building C object esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj
[77/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_sys.c.obj
[78/97] Building ASM object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_longjmp.S.obj
[79/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_uart.c.obj
[80/97] Building C object CMakeFiles/bootloader.elf.dir/project_elf_src_esp32.c.obj
[81/97] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[82/97] Linking C static library esp-idf\log\liblog.a
[83/97] Linking C static library esp-idf\esp_rom\libesp_rom.a
[84/97] Linking C static library esp-idf\esp_common\libesp_common.a
[85/97] Linking C static library esp-idf\xtensa\libxtensa.a
[86/97] Linking C static library esp-idf\esp_hw_support\libesp_hw_support.a
[87/97] Linking C static library esp-idf\esp_system\libesp_system.a
[88/97] Linking C static library esp-idf\efuse\libefuse.a
[89/97] Linking C static library esp-idf\bootloader_support\libbootloader_support.a
[90/97] Linking C static library esp-idf\spi_flash\libspi_flash.a
[91/97] Linking C static library esp-idf\micro-ecc\libmicro-ecc.a
[92/97] Linking C static library esp-idf\soc\libsoc.a
[93/97] Linking C static library esp-idf\hal\libhal.a
[94/97] Linking C static library esp-idf\main\libmain.a
[95/97] Linking C executable bootloader.elf
[96/97] Generating binary image from built executable
esptool.py v3.2-dev
Merged 1 ELF section
Generated C:/Users/Michael Kremer/Desktop/hello_world/build/bootloader/bootloader.bin
[97/97] cmd.exe /C "cd /D "C:\Users\Michael Kremer\Desktop\hello_world\build\bootloader\esp-idf\esptool_py" && C:\Espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe C:/Espressif/frameworks/esp-idf-v4.4/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 "C:/Users/Michael Kremer/Desktop/hello_world/build/bootloader/bootloader.bin""
Bootloader binary size 0x62b0 bytes. 0xd50 bytes (12%) free.
[994/1011] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj
ccache C:\Espressif\tools\xtensa-esp32-elf\esp-2021r2-patch2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -Iconfig -IC:/Espressif/frameworks/esp-idf-v4.4/components/newlib/platform_include -IC:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include/esp_additions/freertos -IC:/Espressif/frameworks/esp-idf-v4.4/components/freertos/port/xtensa/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include/esp_additions -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/include/soc -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/include/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/port/esp32/. -IC:/Espressif/frameworks/esp-idf-v4.4/components/heap/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/log/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/include/apps -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/include/apps/sntp -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/lwip/src/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/port/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/port/esp32/include/arch -IC:/Espressif/frameworks/esp-idf-v4.4/components/soc/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/soc/esp32/. -IC:/Espressif/frameworks/esp-idf-v4.4/components/soc/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/hal/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/hal/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/hal/platform_port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/include/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_common/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/soc -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/public_compat -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/xtensa/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/xtensa/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/driver/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/driver/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_pm/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_ringbuf/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/efuse/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/efuse/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/vfs/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_wifi/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_event/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_netif/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_eth/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/tcpip_adapter/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_phy/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_phy/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_ipc/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/app_trace/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_timer/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls/mbedtls/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls/esp_crt_bundle/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/app_update/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/spi_flash/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/bootloader_support/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/nvs_flash/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/pthread/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_gdbstub/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_gdbstub/xtensa -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_gdbstub/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/espcoredump/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/espcoredump/include/port/xtensa -IC:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant/esp_supplicant/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/ieee802154/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/console -IC:/Espressif/frameworks/esp-idf-v4.4/components/asio/asio/asio/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/asio/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/cbor/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/unity/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/unity/unity/src -IC:/Espressif/frameworks/esp-idf-v4.4/components/cmock/CMock/src -IC:/Espressif/frameworks/esp-idf-v4.4/components/coap/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/coap/libcoap/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/nghttp/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/nghttp/nghttp2/lib/includes -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp-tls -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp-tls/esp-tls-crypto -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_adc_cal/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hid/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/tcp_transport/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_http_client/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_http_server/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_https_ota/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_lcd/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_lcd/interface -IC:/Espressif/frameworks/esp-idf-v4.4/components/protobuf-c/protobuf-c -IC:/Espressif/frameworks/esp-idf-v4.4/components/protocomm/include/common -IC:/Espressif/frameworks/esp-idf-v4.4/components/protocomm/include/security -IC:/Espressif/frameworks/esp-idf-v4.4/components/protocomm/include/transports -IC:/Espressif/frameworks/esp-idf-v4.4/components/mdns/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_local_ctrl/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/sdmmc/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_serial_slave_link/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_websocket_client/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/expat/expat/expat/lib -IC:/Espressif/frameworks/esp-idf-v4.4/components/expat/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/wear_levelling/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/fatfs/diskio -IC:/Espressif/frameworks/esp-idf-v4.4/components/fatfs/vfs -IC:/Espressif/frameworks/esp-idf-v4.4/components/fatfs/src -IC:/Espressif/frameworks/esp-idf-v4.4/components/freemodbus/common/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/idf_test/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/idf_test/include/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/jsmn/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/json/cJSON -IC:/Espressif/frameworks/esp-idf-v4.4/components/libsodium/libsodium/src/libsodium/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/libsodium/port_include -IC:/Espressif/frameworks/esp-idf-v4.4/components/mqtt/esp-mqtt/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/openssl/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/perfmon/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/spiffs/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/ulp/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/wifi_provisioning/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og "-fmacro-prefix-map=C:/Users/Michael Kremer/Desktop/hello_world=." -fmacro-prefix-map=C:/Espressif/frameworks/esp-idf-v4.4=IDF -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.4\" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -MD -MT esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj -MF esp-idf\main\CMakeFiles\__idf_main.dir\hello_world_main.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj -c ../main/hello_world_main.c
xtensa-esp32-elf-gcc.exe: error: C:\Users\Michael: No such file or directory
xtensa-esp32-elf-gcc.exe: error: Kremer\AppData\Roaming/ccache/tmp/cmd_args.bB9taw: No such file or directory
xtensa-esp32-elf-gcc.exe: fatal error: no input files
compilation terminated.
[1003/1011] Building C object esp-idf/wifi_provisioning/CMakeFiles/__idf_wifi_provisioning.dir/src/manager.c.obj
ninja failed with exit code 1
Python 3.8.7
idf.py build
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
esptool.py v3.2-dev
- ESP_Roland
Re: Build stopped, ninja failed, win10, universal online installer 2.13
Your username contains a space. ESP-IDF v4.4 doesn't fully support spaces in the path. The full support will be added in v5.0.
As a workaround, you can move ESP-IDF and your project to a directory to which the path doesn't contain spaces.
We are sorry for the inconvenience.
Hi ESP_Roland. Thank's for the quick Answer.
I've changed the folder to c:\esp and copied the "hello_world" example into esp folder. Unfortunately i have the same problem.
Python 3.8.7
idf.py build
C:\Espressif\frameworks\esp-idf-v4.4>cd..
C:\Espressif\frameworks>cd..
C:\Espressif>cd..
C:\>cd esp
C:\esp>cd hello_world
C:\esp\hello_world>idf.py build
Build directory 'c:\esp\hello_world\build' configured for project 'c:\users\michael kremer\desktop\hello_world' not 'c:\esp\hello_world'. Run 'idf.py fullclean' to start again.
C:\esp\hello_world>idf.py fullclean
Done
Running cmake in directory c:\esp\hello_world\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=1 c:\esp\hello_world"...
-- Project sdkconfig file C:/esp/hello_world/sdkconfig
-- Adding linker script C:/esp/hello_world/build/esp-idf/esp_system/ld/memory.ld
-- Component paths: C:/Espressif/frameworks/esp-idf-v4.4/components/app_trace C:/Espressif/frameworks/esp-idf-v4.4/components/app_update C:/Espressif/frameworks/esp-idf-v4.4/components/asio C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader C:/Espressif/frameworks/esp-idf-v4.4/components/bootloader_support C:/Espressif/frameworks/esp-idf-v4.4/components/bt C:/Espressif/frameworks/esp-idf-v4.4/components/cbor C:/Espressif/frameworks/esp-idf-v4.4/components/cmock C:/Espressif/frameworks/esp-idf-v4.4/components/coap C:/Espressif/frameworks/esp-idf-v4.4/components/console C:/Espressif/frameworks/esp-idf-v4.4/components/cxx C:/Espressif/frameworks/esp-idf-v4.4/components/driver C:/Espressif/frameworks/esp-idf-v4.4/components/efuse C:/Espressif/frameworks/esp-idf-v4.4/components/esp-tls C:/Espressif/frameworks/esp-idf-v4.4/components/esp32 C:/Espressif/frameworks/esp-idf-v4.4/components/esp_adc_cal C:/Espressif/frameworks/esp-idf-v4.4/components/esp_common C:/Espressif/frameworks/esp-idf-v4.4/components/esp_eth C:/Espressif/frameworks/esp-idf-v4.4/components/esp_event C:/Espressif/frameworks/esp-idf-v4.4/components/esp_gdbstub C:/Espressif/frameworks/esp-idf-v4.4/components/esp_hid C:/Espressif/frameworks/esp-idf-v4.4/components/esp_http_client C:/Espressif/frameworks/esp-idf-v4.4/components/esp_http_server C:/Espressif/frameworks/esp-idf-v4.4/components/esp_https_ota C:/Espressif/frameworks/esp-idf-v4.4/components/esp_https_server C:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support C:/Espressif/frameworks/esp-idf-v4.4/components/esp_ipc C:/Espressif/frameworks/esp-idf-v4.4/components/esp_lcd C:/Espressif/frameworks/esp-idf-v4.4/components/esp_local_ctrl C:/Espressif/frameworks/esp-idf-v4.4/components/esp_netif C:/Espressif/frameworks/esp-idf-v4.4/components/esp_phy C:/Espressif/frameworks/esp-idf-v4.4/components/esp_pm C:/Espressif/frameworks/esp-idf-v4.4/components/esp_ringbuf C:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom C:/Espressif/frameworks/esp-idf-v4.4/components/esp_serial_slave_link C:/Espressif/frameworks/esp-idf-v4.4/components/esp_system C:/Espressif/frameworks/esp-idf-v4.4/components/esp_timer C:/Espressif/frameworks/esp-idf-v4.4/components/esp_websocket_client C:/Espressif/frameworks/esp-idf-v4.4/components/esp_wifi C:/Espressif/frameworks/esp-idf-v4.4/components/espcoredump C:/Espressif/frameworks/esp-idf-v4.4/components/esptool_py C:/Espressif/frameworks/esp-idf-v4.4/components/expat C:/Espressif/frameworks/esp-idf-v4.4/components/fatfs C:/Espressif/frameworks/esp-idf-v4.4/components/freemodbus C:/Espressif/frameworks/esp-idf-v4.4/components/freertos C:/Espressif/frameworks/esp-idf-v4.4/components/hal C:/Espressif/frameworks/esp-idf-v4.4/components/heap C:/Espressif/frameworks/esp-idf-v4.4/components/idf_test C:/Espressif/frameworks/esp-idf-v4.4/components/ieee802154 C:/Espressif/frameworks/esp-idf-v4.4/components/jsmn C:/Espressif/frameworks/esp-idf-v4.4/components/json C:/Espressif/frameworks/esp-idf-v4.4/components/libsodium C:/Espressif/frameworks/esp-idf-v4.4/components/log C:/Espressif/frameworks/esp-idf-v4.4/components/lwip C:/esp/hello_world/main C:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls C:/Espressif/frameworks/esp-idf-v4.4/components/mdns C:/Espressif/frameworks/esp-idf-v4.4/components/mqtt C:/Espressif/frameworks/esp-idf-v4.4/components/newlib C:/Espressif/frameworks/esp-idf-v4.4/components/nghttp C:/Espressif/frameworks/esp-idf-v4.4/components/nvs_flash C:/Espressif/frameworks/esp-idf-v4.4/components/openssl C:/Espressif/frameworks/esp-idf-v4.4/components/openthread C:/Espressif/frameworks/esp-idf-v4.4/components/partition_table C:/Espressif/frameworks/esp-idf-v4.4/components/perfmon C:/Espressif/frameworks/esp-idf-v4.4/components/protobuf-c C:/Espressif/frameworks/esp-idf-v4.4/components/protocomm C:/Espressif/frameworks/esp-idf-v4.4/components/pthread C:/Espressif/frameworks/esp-idf-v4.4/components/sdmmc C:/Espressif/frameworks/esp-idf-v4.4/components/soc C:/Espressif/frameworks/esp-idf-v4.4/components/spi_flash C:/Espressif/frameworks/esp-idf-v4.4/components/spiffs C:/Espressif/frameworks/esp-idf-v4.4/components/tcp_transport C:/Espressif/frameworks/esp-idf-v4.4/components/tcpip_adapter C:/Espressif/frameworks/esp-idf-v4.4/components/tinyusb C:/Espressif/frameworks/esp-idf-v4.4/components/ulp C:/Espressif/frameworks/esp-idf-v4.4/components/unity C:/Espressif/frameworks/esp-idf-v4.4/components/usb C:/Espressif/frameworks/esp-idf-v4.4/components/vfs C:/Espressif/frameworks/esp-idf-v4.4/components/wear_levelling C:/Espressif/frameworks/esp-idf-v4.4/components/wifi_provisioning C:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant C:/Espressif/frameworks/esp-idf-v4.4/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/esp/hello_world/build
Running ninja in directory c:\esp\hello_world\build
[331/1011] Performing configure step for 'bootloader'
-- Configuring done
-- Generating done
-- Build files have been written to: C:/esp/hello_world/build/bootloader
[398/1011] Performing build step for 'bootloader'
[2/97] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/wdt_hal_iram.c.obj
[3/97] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mpu_hal.c.obj
[4/97] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/cpu_hal.c.obj
[5/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/dac_periph.c.obj
[6/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/soc_include_legacy_warn.c.obj
[7/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/lldesc.c.obj
[8/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/adc_periph.c.obj
[9/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/lcd_periph.c.obj
[10/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/interrupts.c.obj
[11/97] Building C object CMakeFiles/bootloader.elf.dir/project_elf_src_esp32.c.obj
[12/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/gpio_periph.c.obj
[13/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2c_periph.c.obj
[14/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/pcnt_periph.c.obj
[15/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2s_periph.c.obj
[16/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/ledc_periph.c.obj
[17/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdmmc_periph.c.obj
[18/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/mcpwm_periph.c.obj
[19/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_io_periph.c.obj
[20/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdio_slave_periph.c.obj
[21/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rmt_periph.c.obj
[22/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sigmadelta_periph.c.obj
[23/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/spi_periph.c.obj
[24/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/touch_sensor_periph.c.obj
[26/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/timer_periph.c.obj
[27/97] Building C object esp-idf/spi_flash/CMakeFiles/__idf_spi_flash.dir/esp32/spi_flash_rom_patch.c.obj
[28/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_mem.c.obj
[29/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console_loader.c.obj
[30/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random_esp32.c.obj
[31/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[32/97] Building C object esp-idf/micro-ecc/CMakeFiles/__idf_micro-ecc.dir/uECC_verify_antifault.c.obj
[33/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash.c.obj
[35/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common_loader.c.obj
[36/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_init.c.obj
[37/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_efuse_esp32.c.obj
[38/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common.c.obj
[39/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_loader.c.obj
[40/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[41/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console.c.obj
[42/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[43/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj
[44/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/secure_boot.c.obj
[45/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_qio_mode.c.obj
[46/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_soc.c.obj
[47/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash_config_esp32.c.obj
[48/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_table.c.obj
[50/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj
[52/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[55/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_fields.c.obj
[56/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_panic.c.obj
[57/97] Building C object esp-idf/esp_system/CMakeFiles/__idf_esp_system.dir/esp_err.c.obj
[58/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/compare_set.c.obj
[59/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api_key_esp32.c.obj
[60/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_utility.c.obj
[61/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_init.c.obj
[62/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_pm.c.obj
[63/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_clk.c.obj
[64/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/cpu_util.c.obj
[65/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_wdt.c.obj
[66/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_clk_init.c.obj
[67/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/chip_info.c.obj
[68/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_time.c.obj
[69/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_sleep.c.obj
[70/97] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/eri.c.obj
[71/97] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/xt_trax.c.obj
[72/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_sys.c.obj
[73/97] Building C object esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj
[74/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_crc.c.obj
[75/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_uart.c.obj
[76/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_tjpgd.c.obj
[77/97] Building ASM object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_longjmp.S.obj
[78/97] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_buffers.c.obj
[79/97] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
[80/97] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[81/97] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_noos.c.obj
esptool.py v3.2-dev
Generated C:/esp/hello_world/build/bootloader/bootloader.bin
[97/97] cmd.exe /C "cd /D C:\esp\hello_world\build\bootloader\esp-idf\esptool_py && C:\Espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe C:/Espressif/frameworks/esp-idf-v4.4/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 C:/esp/hello_world/build/bootloader/bootloader.bin"
[998/1011] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj
ccache C:\Espressif\tools\xtensa-esp32-elf\esp-2021r2-patch2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -Iconfig -IC:/Espressif/frameworks/esp-idf-v4.4/components/newlib/platform_include -IC:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include/esp_additions/freertos -IC:/Espressif/frameworks/esp-idf-v4.4/components/freertos/port/xtensa/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include/esp_additions -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/include/soc -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/include/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hw_support/port/esp32/. -IC:/Espressif/frameworks/esp-idf-v4.4/components/heap/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/log/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/include/apps -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/include/apps/sntp -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/lwip/src/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/port/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/lwip/port/esp32/include/arch -IC:/Espressif/frameworks/esp-idf-v4.4/components/soc/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/soc/esp32/. -IC:/Espressif/frameworks/esp-idf-v4.4/components/soc/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/hal/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/hal/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/hal/platform_port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/include/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_rom/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_common/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/soc -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/public_compat -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/xtensa/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/xtensa/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/driver/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/driver/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_pm/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_ringbuf/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/efuse/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/efuse/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/vfs/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_wifi/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_event/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_netif/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_eth/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/tcpip_adapter/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_phy/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_phy/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_ipc/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/app_trace/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_timer/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls/mbedtls/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/mbedtls/esp_crt_bundle/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/app_update/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/spi_flash/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/bootloader_support/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/nvs_flash/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/pthread/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_gdbstub/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_gdbstub/xtensa -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_gdbstub/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/espcoredump/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/espcoredump/include/port/xtensa -IC:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/wpa_supplicant/esp_supplicant/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/ieee802154/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/console -IC:/Espressif/frameworks/esp-idf-v4.4/components/asio/asio/asio/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/asio/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/cbor/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/unity/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/unity/unity/src -IC:/Espressif/frameworks/esp-idf-v4.4/components/cmock/CMock/src -IC:/Espressif/frameworks/esp-idf-v4.4/components/coap/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/coap/libcoap/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/nghttp/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/nghttp/nghttp2/lib/includes -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp-tls -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp-tls/esp-tls-crypto -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_adc_cal/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_hid/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/tcp_transport/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_http_client/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_http_server/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_https_ota/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_lcd/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_lcd/interface -IC:/Espressif/frameworks/esp-idf-v4.4/components/protobuf-c/protobuf-c -IC:/Espressif/frameworks/esp-idf-v4.4/components/protocomm/include/common -IC:/Espressif/frameworks/esp-idf-v4.4/components/protocomm/include/security -IC:/Espressif/frameworks/esp-idf-v4.4/components/protocomm/include/transports -IC:/Espressif/frameworks/esp-idf-v4.4/components/mdns/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_local_ctrl/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/sdmmc/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_serial_slave_link/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/esp_websocket_client/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/expat/expat/expat/lib -IC:/Espressif/frameworks/esp-idf-v4.4/components/expat/port/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/wear_levelling/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/fatfs/diskio -IC:/Espressif/frameworks/esp-idf-v4.4/components/fatfs/vfs -IC:/Espressif/frameworks/esp-idf-v4.4/components/fatfs/src -IC:/Espressif/frameworks/esp-idf-v4.4/components/freemodbus/common/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/idf_test/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/idf_test/include/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4/components/jsmn/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/json/cJSON -IC:/Espressif/frameworks/esp-idf-v4.4/components/libsodium/libsodium/src/libsodium/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/libsodium/port_include -IC:/Espressif/frameworks/esp-idf-v4.4/components/mqtt/esp-mqtt/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/openssl/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/perfmon/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/spiffs/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/ulp/include -IC:/Espressif/frameworks/esp-idf-v4.4/components/wifi_provisioning/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fmacro-prefix-map=C:/esp/hello_world=. -fmacro-prefix-map=C:/Espressif/frameworks/esp-idf-v4.4=IDF -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.4\" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -MD -MT esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj -MF esp-idf\main\CMakeFiles\__idf_main.dir\hello_world_main.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj -c ../main/hello_world_main.c
xtensa-esp32-elf-gcc.exe: error: Kremer\AppData\Roaming/ccache/tmp/cmd_args.93WE52: No such file or directory
[1004/1011] Building C object esp-idf/wifi_provisioning/CMakeFiles/__idf_wifi_provisioning.dir/src/scheme_softap.c.obj
C:\esp\hello_world>
Python 3.8.7
idf.py build
C:\Espressif>cd..
C:\>cd esp
Done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
esptool.py v3.2-dev
C:\esp\hello_world>
- ESP_Roland
Please try to clean the cache by running "ccache -C".
Sadly it still does not work.
I noticed that ".espressif" is installed under user\Michael Kremer. Is that normal?
But I can't change the selection. I only have two options for installation.
There I choose the default settings, like
1. "Version of ESP-IDF" to C:\Espressif\frameworks\esp-idf-v4.4
2. "Selection Destination Location" to C:\Espressif
But there is nothing like ".espressif".
If it matters, how can i save ".espressif" somewhere else?
Python 3.8.7
Setting IDF_PATH: C:\Espressif\frameworks\esp-idf-v4.4-2
C:\Espressif\frameworks\esp-idf-v4.4-2\tools
Python requirements from C:\Espressif\frameworks\esp-idf-v4.4-2\requirements.txt are satisfied.
idf.py build
C:\Espressif\frameworks\esp-idf-v4.4-2>ccache -C
Clearing... 100.0% [==================================================================================================]
C:\Espressif\frameworks\esp-idf-v4.4-2>cd..
C:\Espressif>cd..
C:\>cd esp
C:\esp>cd hellow_world
C:\esp\hello_world>idf set-target esp32
Der Befehl "idf" ist entweder falsch geschrieben oder
C:\esp\hello_world>idf.py set-target esp32
Build directory 'c:\esp\hello_world\build' not found. Nothing to clean.
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_system/ld/esp32/sections.ld.in
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/esp32/ld/esp32.rom.api.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/esp32/ld/esp32.rom.newlib-time.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/soc/esp32/ld/esp32.peripherals.ld
-- Component paths: C:/Espressif/frameworks/esp-idf-v4.4-2/components/app_trace C:/Espressif/frameworks/esp-idf-v4.4-2/components/app_update C:/Espressif/frameworks/esp-idf-v4.4-2/components/asio C:/Espressif/frameworks/esp-idf-v4.4-2/components/bootloader C:/Espressif/frameworks/esp-idf-v4.4-2/components/bootloader_support C:/Espressif/frameworks/esp-idf-v4.4-2/components/bt C:/Espressif/frameworks/esp-idf-v4.4-2/components/cbor C:/Espressif/frameworks/esp-idf-v4.4-2/components/cmock C:/Espressif/frameworks/esp-idf-v4.4-2/components/coap C:/Espressif/frameworks/esp-idf-v4.4-2/components/console C:/Espressif/frameworks/esp-idf-v4.4-2/components/cxx C:/Espressif/frameworks/esp-idf-v4.4-2/components/driver C:/Espressif/frameworks/esp-idf-v4.4-2/components/efuse C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp-tls C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp32 C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_adc_cal C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_common C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_eth C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_event C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_gdbstub C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_hid C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_http_client C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_http_server C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_https_ota C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_https_server C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_hw_support C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_ipc C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_lcd C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_local_ctrl C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_netif C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_phy C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_pm C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_ringbuf C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_serial_slave_link C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_system C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_timer C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_websocket_client C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_wifi C:/Espressif/frameworks/esp-idf-v4.4-2/components/espcoredump C:/Espressif/frameworks/esp-idf-v4.4-2/components/esptool_py C:/Espressif/frameworks/esp-idf-v4.4-2/components/expat C:/Espressif/frameworks/esp-idf-v4.4-2/components/fatfs C:/Espressif/frameworks/esp-idf-v4.4-2/components/freemodbus C:/Espressif/frameworks/esp-idf-v4.4-2/components/freertos C:/Espressif/frameworks/esp-idf-v4.4-2/components/hal C:/Espressif/frameworks/esp-idf-v4.4-2/components/heap C:/Espressif/frameworks/esp-idf-v4.4-2/components/idf_test C:/Espressif/frameworks/esp-idf-v4.4-2/components/ieee802154 C:/Espressif/frameworks/esp-idf-v4.4-2/components/jsmn C:/Espressif/frameworks/esp-idf-v4.4-2/components/json C:/Espressif/frameworks/esp-idf-v4.4-2/components/libsodium C:/Espressif/frameworks/esp-idf-v4.4-2/components/log C:/Espressif/frameworks/esp-idf-v4.4-2/components/lwip C:/esp/hello_world/main C:/Espressif/frameworks/esp-idf-v4.4-2/components/mbedtls C:/Espressif/frameworks/esp-idf-v4.4-2/components/mdns C:/Espressif/frameworks/esp-idf-v4.4-2/components/mqtt C:/Espressif/frameworks/esp-idf-v4.4-2/components/newlib C:/Espressif/frameworks/esp-idf-v4.4-2/components/nghttp C:/Espressif/frameworks/esp-idf-v4.4-2/components/nvs_flash C:/Espressif/frameworks/esp-idf-v4.4-2/components/openssl C:/Espressif/frameworks/esp-idf-v4.4-2/components/openthread C:/Espressif/frameworks/esp-idf-v4.4-2/components/partition_table C:/Espressif/frameworks/esp-idf-v4.4-2/components/perfmon C:/Espressif/frameworks/esp-idf-v4.4-2/components/protobuf-c C:/Espressif/frameworks/esp-idf-v4.4-2/components/protocomm C:/Espressif/frameworks/esp-idf-v4.4-2/components/pthread C:/Espressif/frameworks/esp-idf-v4.4-2/components/sdmmc C:/Espressif/frameworks/esp-idf-v4.4-2/components/soc C:/Espressif/frameworks/esp-idf-v4.4-2/components/spi_flash C:/Espressif/frameworks/esp-idf-v4.4-2/components/spiffs C:/Espressif/frameworks/esp-idf-v4.4-2/components/tcp_transport C:/Espressif/frameworks/esp-idf-v4.4-2/components/tcpip_adapter C:/Espressif/frameworks/esp-idf-v4.4-2/components/tinyusb C:/Espressif/frameworks/esp-idf-v4.4-2/components/ulp C:/Espressif/frameworks/esp-idf-v4.4-2/components/unity C:/Espressif/frameworks/esp-idf-v4.4-2/components/usb C:/Espressif/frameworks/esp-idf-v4.4-2/components/vfs C:/Espressif/frameworks/esp-idf-v4.4-2/components/wear_levelling C:/Espressif/frameworks/esp-idf-v4.4-2/components/wifi_provisioning C:/Espressif/frameworks/esp-idf-v4.4-2/components/wpa_supplicant C:/Espressif/frameworks/esp-idf-v4.4-2/components/xtensa
-- Configuring done
-- Generating done
[323/1011] Performing configure step for 'bootloader'
-- Found Git: C:/Espressif/tools/idf-git/2.34.2/cmd/git.exe (found version "2.34.1.windows.1")
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- Found assembler: C:/Espressif/tools/xtensa-esp32-elf/esp-2021r2-patch2-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Espressif/tools/xtensa-esp32-elf/esp-2021r2-patch2-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe - skipped
-- Check for working CXX compiler: C:/Espressif/tools/xtensa-esp32-elf/esp-2021r2-patch2-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe - skipped
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/bootloader/subproject/main/ld/esp32/bootloader.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.4-2/components/bootloader/subproject/main/ld/esp32/bootloader.rom.ld
-- Component paths: C:/Espressif/frameworks/esp-idf-v4.4-2/components/bootloader C:/Espressif/frameworks/esp-idf-v4.4-2/components/bootloader_support C:/Espressif/frameworks/esp-idf-v4.4-2/components/efuse C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp32 C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_common C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_hw_support C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom C:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_system C:/Espressif/frameworks/esp-idf-v4.4-2/components/esptool_py C:/Espressif/frameworks/esp-idf-v4.4-2/components/freertos C:/Espressif/frameworks/esp-idf-v4.4-2/components/hal C:/Espressif/frameworks/esp-idf-v4.4-2/components/log C:/Espressif/frameworks/esp-idf-v4.4-2/components/bootloader/subproject/main C:/Espressif/frameworks/esp-idf-v4.4-2/components/bootloader/subproject/components/micro-ecc C:/Espressif/frameworks/esp-idf-v4.4-2/components/newlib C:/Espressif/frameworks/esp-idf-v4.4-2/components/partition_table C:/Espressif/frameworks/esp-idf-v4.4-2/components/soc C:/Espressif/frameworks/esp-idf-v4.4-2/components/spi_flash C:/Espressif/frameworks/esp-idf-v4.4-2/components/xtensa
-- Configuring done
-- Generating done
[389/1011] Performing build step for 'bootloader'
[2/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/dac_periph.c.obj
[3/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/lldesc.c.obj
[4/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/soc_include_legacy_warn.c.obj
[5/97] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/cpu_hal.c.obj
[6/97] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/wdt_hal_iram.c.obj
[7/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/adc_periph.c.obj
[8/97] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mpu_hal.c.obj
[9/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2c_periph.c.obj
[10/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2s_periph.c.obj
[13/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/lcd_periph.c.obj
[14/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_io_periph.c.obj
[15/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/ledc_periph.c.obj
[16/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/interrupts.c.obj
[17/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rmt_periph.c.obj
[19/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdio_slave_periph.c.obj
[20/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdmmc_periph.c.obj
[21/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/pcnt_periph.c.obj
[24/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/timer_periph.c.obj
[25/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/touch_sensor_periph.c.obj
[26/97] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/uart_periph.c.obj
[27/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console_loader.c.obj
[28/97] Building C object esp-idf/spi_flash/CMakeFiles/__idf_spi_flash.dir/esp32/spi_flash_rom_patch.c.obj
[29/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common.c.obj
[30/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common_loader.c.obj
[31/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_mem.c.obj
[33/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_init.c.obj
[34/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash.c.obj
[35/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random.c.obj
[36/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random_esp32.c.obj
[38/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console.c.obj
[39/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[41/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[42/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/secure_boot.c.obj
[43/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[44/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj
[46/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj
[48/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_panic.c.obj
[49/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_sha.c.obj
[51/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_fields.c.obj
[52/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_esp32.c.obj
[53/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_fields.c.obj
[54/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_table.c.obj
[55/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_utility.c.obj
[56/97] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[61/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_time.c.obj
[62/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/chip_info.c.obj
[63/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_wdt.c.obj
[64/97] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/eri.c.obj
[65/97] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/xt_trax.c.obj
[66/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_pm.c.obj
[67/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_init.c.obj
[68/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/cpu_util.c.obj
[69/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_clk_init.c.obj
[70/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_clk.c.obj
[71/97] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_sleep.c.obj
[72/97] Building C object esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj
[73/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_crc.c.obj
[74/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_sys.c.obj
[75/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_tjpgd.c.obj
[76/97] Building ASM object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_longjmp.S.obj
[77/97] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_uart.c.obj
[78/97] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
[79/97] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_buffers.c.obj
[80/97] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_noos.c.obj
esptool.py v3.2-dev
[97/97] cmd.exe /C "cd /D C:\esp\hello_world\build\bootloader\esp-idf\esptool_py && C:\Espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe C:/Espressif/frameworks/esp-idf-v4.4-2/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 C:/esp/hello_world/build/bootloader/bootloader.bin"
[999/1011] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj
ccache C:\Espressif\tools\xtensa-esp32-elf\esp-2021r2-patch2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -Iconfig -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/newlib/platform_include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/freertos/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/freertos/include/esp_additions/freertos -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/freertos/port/xtensa/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/freertos/include/esp_additions -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_hw_support/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_hw_support/include/soc -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_hw_support/include/soc/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_hw_support/port/esp32/. -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/heap/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/log/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/lwip/include/apps -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/lwip/include/apps/sntp -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/lwip/lwip/src/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/lwip/port/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/lwip/port/esp32/include/arch -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/soc/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/soc/esp32/. -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/soc/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/hal/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/hal/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/hal/platform_port/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/include/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_rom/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_common/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_system/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_system/port/soc -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_system/port/public_compat -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/xtensa/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/xtensa/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/driver/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/driver/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_pm/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_ringbuf/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/efuse/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/efuse/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/vfs/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_wifi/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_event/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_netif/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_eth/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/tcpip_adapter/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_phy/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_phy/esp32/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_ipc/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/app_trace/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_timer/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/mbedtls/port/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/mbedtls/mbedtls/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/mbedtls/esp_crt_bundle/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/app_update/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/spi_flash/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/bootloader_support/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/nvs_flash/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/pthread/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_gdbstub/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_gdbstub/xtensa -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_gdbstub/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/espcoredump/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/espcoredump/include/port/xtensa -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/wpa_supplicant/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/wpa_supplicant/port/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/wpa_supplicant/esp_supplicant/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/ieee802154/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/console -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/asio/asio/asio/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/asio/port/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/cbor/port/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/unity/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/unity/unity/src -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/cmock/CMock/src -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/coap/port/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/coap/libcoap/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/nghttp/port/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/nghttp/nghttp2/lib/includes -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp-tls -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp-tls/esp-tls-crypto -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_adc_cal/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_hid/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/tcp_transport/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_http_client/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_http_server/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_https_ota/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_lcd/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_lcd/interface -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/protobuf-c/protobuf-c -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/protocomm/include/common -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/protocomm/include/security -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/protocomm/include/transports -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/mdns/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_local_ctrl/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/sdmmc/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_serial_slave_link/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/esp_websocket_client/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/expat/expat/expat/lib -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/expat/port/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/wear_levelling/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/fatfs/diskio -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/fatfs/vfs -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/fatfs/src -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/freemodbus/common/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/idf_test/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/idf_test/include/esp32 -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/jsmn/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/json/cJSON -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/libsodium/libsodium/src/libsodium/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/libsodium/port_include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/mqtt/esp-mqtt/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/openssl/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/perfmon/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/spiffs/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/ulp/include -IC:/Espressif/frameworks/esp-idf-v4.4-2/components/wifi_provisioning/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fmacro-prefix-map=C:/esp/hello_world=. -fmacro-prefix-map=C:/Espressif/frameworks/esp-idf-v4.4-2=IDF -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.4\" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -MD -MT esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj -MF esp-idf\main\CMakeFiles\__idf_main.dir\hello_world_main.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj -c ../main/hello_world_main.c
xtensa-esp32-elf-gcc.exe: error: Kremer\AppData\Roaming/ccache/tmp/cmd_args.LFiSHa: No such file or directory
C:\esp\hello_world>
Using Python in C:\Espressif\python_env\idf4.4_py3.8_env\Scripts\
Python 3.8.7
Using Git in C:\Espressif\tools\idf-git\2.34.2\cmd\
git version 2.34.1.windows.1
Adding ESP-IDF tools to PATH...
C:\Espressif\tools\xtensa-esp32s2-elf\esp-2021r2-patch2-8.4.0\xtensa-esp32s2-elf\bin
C:\Espressif\tools\xtensa-esp32s3-elf\esp-2021r2-patch2-8.4.0\xtensa-esp32s3-elf\bin
C:\Espressif\tools\riscv32-esp-elf\esp-2021r2-patch2-8.4.0\riscv32-esp-elf\bin
C:\Espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin
C:\Espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin
C:\Espressif\tools\cmake\3.20.3\bin
C:\Espressif\tools\openocd-esp32\v0.11.0-esp32-20211220\openocd-esp32\bin
C:\Espressif\tools\ninja\1.10.2\
C:\Espressif\tools\idf-exe\1.0.3\
C:\Espressif\tools\ccache\4.3\ccache-4.3-windows-64
C:\Espressif\tools\dfu-util\0.9\dfu-util-0.9-win64
Checking if Python packages are up to date...
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
C:\Espressif>cd..
C:\>cd esp
Das System kann den angegebenen Pfad nicht finden.
konnte nicht gefunden werden.
Adding "set-target"'s dependency "fullclean" to list of commands with default set of options.
Executing action: fullclean
Executing action: set-target
Set Target to: esp32, new sdkconfig created. Existing sdkconfig renamed to sdkconfig.old.
-- ccache will be used for faster recompilation
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Found PythonInterp: C:/Espressif/python_env/idf4.4_py3.8_env/Scripts/python.exe (found version "3.8.7")
-- Could NOT find Perl (missing: PERL_EXECUTABLE)
-- App "hello_world" version: 1
-- Components: app_trace app_update asio bootloader bootloader_support bt cbor cmock coap console cxx driver efuse esp-tls esp32 esp_adc_cal esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_ipc esp_lcd esp_local_ctrl esp_netif esp_phy esp_pm esp_ringbuf esp_rom esp_serial_slave_link esp_system esp_timer esp_websocket_client esp_wifi espcoredump esptool_py expat fatfs freemodbus freertos hal heap idf_test ieee802154 jsmn json libsodium log lwip main mbedtls mdns mqtt newlib nghttp nvs_flash openssl openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport tcpip_adapter tinyusb ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Configuring done
-- Generating done
Executing action: all (aliases: build)
Executing "ninja all"...
[3/1011] Generating ../../partition_table/partition-table.bin
Partition table binary generated. Contents:
# ESP-IDF Partition Table
nvs,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,1M,
-- Components: bootloader bootloader_support efuse esp32 esp_common esp_hw_support esp_rom esp_system esptool_py freertos hal log main micro-ecc newlib partition_table soc spi_flash xtensa
-- Configuring done
-- Generating done
[1/97] Generating project_elf_src_esp32.c
[40/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_loader.c.obj
[50/97] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_soc.c.obj
[81/97] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[82/97] Linking C static library esp-idf\log\liblog.a
[83/97] Linking C static library esp-idf\esp_rom\libesp_rom.a
[84/97] Linking C static library esp-idf\esp_common\libesp_common.a
[85/97] Linking C static library esp-idf\xtensa\libxtensa.a
[86/97] Linking C static library esp-idf\esp_hw_support\libesp_hw_support.a
[87/97] Linking C static library esp-idf\esp_system\libesp_system.a
[88/97] Linking C static library esp-idf\efuse\libefuse.a
[89/97] Linking C static library esp-idf\bootloader_support\libbootloader_support.a
[90/97] Linking C static library esp-idf\spi_flash\libspi_flash.a
[91/97] Linking C static library esp-idf\micro-ecc\libmicro-ecc.a
[92/97] Linking C static library esp-idf\soc\libsoc.a
[93/97] Linking C static library esp-idf\hal\libhal.a
[94/97] Linking C static library esp-idf\main\libmain.a
[95/97] Linking C executable bootloader.elf
[96/97] Generating binary image from built executable
esptool.py v3.2-dev
Merged 1 ELF section
Bootloader binary size 0x62b0 bytes. 0xd50 bytes (12%) free.
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/hello_world_main.c.obj
C:\esp\hello_world>
I run the offline Version 4.1.2 and it seem to work now . But the Version 4.4 does not work.
Are there big differences to 4.4?
Using Python in C:\Espressif\python_env\idf4.1_py3.8_env\Scripts\
Python 3.8.7
Setting IDF_PATH: C:\Espressif\frameworks\esp-idf-v4.1.2
C:\Espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin
C:\Espressif\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin
C:\Espressif\tools\cmake\3.13.4\bin
C:\Espressif\tools\openocd-esp32\v0.10.0-esp32-20210401\openocd-esp32\bin
C:\Espressif\tools\ninja\1.9.0\
C:\Espressif\tools\idf-exe\1.0.1\
C:\Espressif\tools\ccache\3.7\
C:\Espressif\frameworks\esp-idf-v4.1.2\tools
Python requirements from C:\Espressif\frameworks\esp-idf-v4.1.2\requirements.txt are satisfied.
idf.py build
C:\Espressif\frameworks\esp-idf-v4.1.2>cd..
C:\Espressif>cd..
C:\>cd esp
-- Initialising new submodule components/asio/asio...
Submodule path 'components/asio/asio': checked out '3b66e5b051381fb70de9c2791df70a06181c64e3'
-- Initialising new submodule components/bootloader/subproject/components/micro-ecc/micro-ecc...
Submodule path 'components/bootloader/subproject/components/micro-ecc/micro-ecc': checked out 'd037ec89546fad14b5c4d5456c2e23a71e554966'
-- Initialising new submodule components/bt/controller/lib...
Submodule path 'components/bt/controller/lib': checked out '41866ca55b805f947fc9b6fe565ca2b6eff3709a'
-- Initialising new submodule components/bt/host/nimble/nimble...
Submodule path 'components/bt/host/nimble/nimble': checked out '57d751b93a5532e650ec3787d376876ab0ce367e'
-- Initialising new submodule components/cbor/tinycbor...
Submodule path 'components/cbor/tinycbor': checked out 'd2dd95cb8841d88d5a801e3ef9c328fd6200e7bd'
-- Initialising new submodule components/coap/libcoap...
Submodule path 'components/coap/libcoap': checked out '98954eb30a2e728e172a6cd29430ae5bc999b585'
Submodule path 'components/coap/libcoap/ext/tinydtls': checked out '7f8c86e501e690301630029fa9bae22424adf618'
-- Initialising new submodule components/esp_wifi/lib...
Submodule path 'components/esp_wifi/lib': checked out '22a78a650790b5cba91753181be351deb6cc5285'
-- Initialising new submodule components/esptool_py/esptool...
Submodule path 'components/esptool_py/esptool': checked out '5b8c2f1b02d0e4b9bac0756b3ead66e8beea428a'
-- Initialising new submodule components/expat/expat...
Submodule path 'components/expat/expat': checked out '968b8cc46dbee47b83318d5f31a8e7907199614b'
-- Initialising new submodule components/json/cJSON...
Submodule path 'components/json/cJSON': checked out '3c8935676a97c7c97bf006db8312875b4f292f6c'
-- Initialising new submodule components/libsodium/libsodium...
Submodule path 'components/libsodium/libsodium': checked out '70170c28c844a4786e75efc626e1aeebc93caebc'
-- Initialising new submodule components/lwip/lwip...
Submodule path 'components/lwip/lwip': checked out '2c9c531f0a7e0ee536db9de4f9dc54e453712087'
-- Initialising new submodule components/mbedtls/mbedtls...
Submodule path 'components/mbedtls/mbedtls': checked out '99c88bb7bd7c2d91c6873abd6e6d5ee04f4f164c'
-- Initialising new submodule components/mqtt/esp-mqtt...
Submodule path 'components/mqtt/esp-mqtt': checked out '9ea804e0ab5368d5ab53ae2301a5fec9d1f12f1a'
-- Initialising new submodule components/nghttp/nghttp2...
Submodule path 'components/nghttp/nghttp2': checked out '3bcc416e13cc790e2fb45fcfe9111d38609c5032'
Submodule path 'components/nghttp/nghttp2/third-party/mruby': checked out '22464fe5a0a10f2b077eaba109ce1e912e4a77de'
Submodule path 'components/nghttp/nghttp2/third-party/neverbleed': checked out 'da5c2ab419a3bb8a4cc6c37a6c7f3e4bd4b41134'
-- Initialising new submodule components/protobuf-c/protobuf-c...
Submodule path 'components/protobuf-c/protobuf-c': checked out 'dac1a65feac4ad72f612aab99f487056fbcf5c1a'
-- Initialising new submodule components/spiffs/spiffs...
Submodule path 'components/spiffs/spiffs': checked out 'f5e26c4e933189593a71c6b82cda381a7b21e41c'
-- Initialising new submodule components/unity/unity...
Submodule path 'components/unity/unity': checked out '7d2bf62b7e6afaf38153041a9d53c21aeeca9a25'
-- Initialising new submodule examples/build_system/cmake/import_lib/main/lib/tinyxml2...
Submodule path 'examples/build_system/cmake/import_lib/main/lib/tinyxml2': checked out '7e8e249990ec491ec15990cf95b6d871a66cf64a'
-- Found assembler: C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- works
-- Check for working CXX compiler: C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe
-- Check for working CXX compiler: C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe -- works
-- Project version: 1
-- Found PythonInterp: C:/Espressif/python_env/idf4.1_py3.8_env/Scripts/python.exe (found version "3.8.7")
-- Adding linker script C:/esp/hello_world/build/esp-idf/esp32/esp32_out.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp32/ld/esp32.project.ld.in
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp32/ld/esp32.peripherals.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_rom/esp32/ld/esp32.rom.newlib-time.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Components: app_trace app_update asio bootloader bootloader_support bt cbor coap console cxx driver efuse esp-tls esp32 esp_adc_cal esp_common esp_eth esp_event esp_gdbstub esp_http_client esp_http_server esp_https_ota esp_https_server esp_local_ctrl esp_netif esp_ringbuf esp_rom esp_serial_slave_link esp_websocket_client esp_wifi espcoredump esptool_py expat fatfs freemodbus freertos heap idf_test jsmn json libsodium log lwip main mbedtls mdns mqtt newlib nghttp nvs_flash openssl partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport tcpip_adapter ulp unity vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: C:/Espressif/frameworks/esp-idf-v4.1.2/components/app_trace C:/Espressif/frameworks/esp-idf-v4.1.2/components/app_update C:/Espressif/frameworks/esp-idf-v4.1.2/components/asio C:/Espressif/frameworks/esp-idf-v4.1.2/components/bootloader C:/Espressif/frameworks/esp-idf-v4.1.2/components/bootloader_support C:/Espressif/frameworks/esp-idf-v4.1.2/components/bt C:/Espressif/frameworks/esp-idf-v4.1.2/components/cbor C:/Espressif/frameworks/esp-idf-v4.1.2/components/coap C:/Espressif/frameworks/esp-idf-v4.1.2/components/console C:/Espressif/frameworks/esp-idf-v4.1.2/components/cxx C:/Espressif/frameworks/esp-idf-v4.1.2/components/driver C:/Espressif/frameworks/esp-idf-v4.1.2/components/efuse C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp-tls C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp32 C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_adc_cal C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_common C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_eth C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_event C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_gdbstub C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_http_client C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_http_server C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_https_ota C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_https_server C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_local_ctrl C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_netif C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_ringbuf C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_rom C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_serial_slave_link C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_websocket_client C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_wifi C:/Espressif/frameworks/esp-idf-v4.1.2/components/espcoredump C:/Espressif/frameworks/esp-idf-v4.1.2/components/esptool_py C:/Espressif/frameworks/esp-idf-v4.1.2/components/expat C:/Espressif/frameworks/esp-idf-v4.1.2/components/fatfs C:/Espressif/frameworks/esp-idf-v4.1.2/components/freemodbus C:/Espressif/frameworks/esp-idf-v4.1.2/components/freertos C:/Espressif/frameworks/esp-idf-v4.1.2/components/heap C:/Espressif/frameworks/esp-idf-v4.1.2/components/idf_test C:/Espressif/frameworks/esp-idf-v4.1.2/components/jsmn C:/Espressif/frameworks/esp-idf-v4.1.2/components/json C:/Espressif/frameworks/esp-idf-v4.1.2/components/libsodium C:/Espressif/frameworks/esp-idf-v4.1.2/components/log C:/Espressif/frameworks/esp-idf-v4.1.2/components/lwip C:/esp/hello_world/main C:/Espressif/frameworks/esp-idf-v4.1.2/components/mbedtls C:/Espressif/frameworks/esp-idf-v4.1.2/components/mdns C:/Espressif/frameworks/esp-idf-v4.1.2/components/mqtt C:/Espressif/frameworks/esp-idf-v4.1.2/components/newlib C:/Espressif/frameworks/esp-idf-v4.1.2/components/nghttp C:/Espressif/frameworks/esp-idf-v4.1.2/components/nvs_flash C:/Espressif/frameworks/esp-idf-v4.1.2/components/openssl C:/Espressif/frameworks/esp-idf-v4.1.2/components/partition_table C:/Espressif/frameworks/esp-idf-v4.1.2/components/perfmon C:/Espressif/frameworks/esp-idf-v4.1.2/components/protobuf-c C:/Espressif/frameworks/esp-idf-v4.1.2/components/protocomm C:/Espressif/frameworks/esp-idf-v4.1.2/components/pthread C:/Espressif/frameworks/esp-idf-v4.1.2/components/sdmmc C:/Espressif/frameworks/esp-idf-v4.1.2/components/soc C:/Espressif/frameworks/esp-idf-v4.1.2/components/spi_flash C:/Espressif/frameworks/esp-idf-v4.1.2/components/spiffs C:/Espressif/frameworks/esp-idf-v4.1.2/components/tcp_transport C:/Espressif/frameworks/esp-idf-v4.1.2/components/tcpip_adapter C:/Espressif/frameworks/esp-idf-v4.1.2/components/ulp C:/Espressif/frameworks/esp-idf-v4.1.2/components/unity C:/Espressif/frameworks/esp-idf-v4.1.2/components/vfs C:/Espressif/frameworks/esp-idf-v4.1.2/components/wear_levelling C:/Espressif/frameworks/esp-idf-v4.1.2/components/wifi_provisioning C:/Espressif/frameworks/esp-idf-v4.1.2/components/wpa_supplicant C:/Espressif/frameworks/esp-idf-v4.1.2/components/xtensa
-- Configuring done
-- Generating done
C:\esp\hello_world>idf.py build
[7/897] cmd.exe /C "cd /D C:\esp\hello_world\build\esp-idf...*********************************************************"
# Espressif ESP32 Partition Table
[415/897] Performing configure step for 'bootloader'
-- Project version: v4.1.2
-- Project sdkconfig file C:/esp/hello_world/sdkconfig
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/bootloader/subproject/main/ld/esp32/bootloader.ld
-- Adding linker script C:/Espressif/frameworks/esp-idf-v4.1.2/components/bootloader/subproject/main/ld/esp32/bootloader.rom.ld
-- Components: bootloader bootloader_support efuse esp32 esp_common esp_rom esptool_py log main micro-ecc partition_table soc spi_flash xtensa
-- Component paths: C:/Espressif/frameworks/esp-idf-v4.1.2/components/bootloader C:/Espressif/frameworks/esp-idf-v4.1.2/components/bootloader_support C:/Espressif/frameworks/esp-idf-v4.1.2/components/efuse C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp32 C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_common C:/Espressif/frameworks/esp-idf-v4.1.2/components/esp_rom C:/Espressif/frameworks/esp-idf-v4.1.2/components/esptool_py C:/Espressif/frameworks/esp-idf-v4.1.2/components/log C:/Espressif/frameworks/esp-idf-v4.1.2/components/bootloader/subproject/main C:/Espressif/frameworks/esp-idf-v4.1.2/components/bootloader/subproject/components/micro-ecc C:/Espressif/frameworks/esp-idf-v4.1.2/components/partition_table C:/Espressif/frameworks/esp-idf-v4.1.2/components/soc C:/Espressif/frameworks/esp-idf-v4.1.2/components/spi_flash C:/Espressif/frameworks/esp-idf-v4.1.2/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/esp/hello_world/build/bootloader
[479/897] Performing build step for 'bootloader'
[1/92] Generating project_elf_src.c
[2/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/adc_periph.c.obj
[3/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/dac_periph.c.obj
[4/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/cpu_util.c.obj
[5/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/gpio_periph.c.obj
[6/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_clk_init.c.obj
[7/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_io_periph.c.obj
[8/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_init.c.obj
[9/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_periph.c.obj
[10/92] Building C object CMakeFiles/bootloader.elf.dir/project_elf_src.c.obj
[11/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_clk.c.obj
[12/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdio_slave_periph.c.obj
[13/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_pm.c.obj
[14/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdmmc_periph.c.obj
[15/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_time.c.obj
[16/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/interrupts.c.obj
[17/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/ledc_periph.c.obj
[18/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/soc_memory_layout.c.obj
[19/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_sleep.c.obj
[20/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_wdt.c.obj
[21/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/spi_periph.c.obj
[22/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2c_periph.c.obj
[23/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2s_periph.c.obj
[24/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/lldesc.c.obj
[25/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/memory_layout_utils.c.obj
[26/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/uart_periph.c.obj
[27/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/touch_sensor_periph.c.obj
[28/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/rtc_io_hal.c.obj
[29/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/touch_sensor_hal.c.obj
[30/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/rmt_hal.c.obj
[31/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/dac_hal.c.obj
[32/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_hal.c.obj
[33/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_slave_hal_iram.c.obj
[34/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_slave_hal.c.obj
[35/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/adc_hal.c.obj
[36/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/touch_sensor_hal.c.obj
[37/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/ledc_hal.c.obj
[38/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_hal_iram.c.obj
[39/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/sigmadelta_hal.c.obj
[40/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/timer_hal.c.obj
[41/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/soc_include_legacy_warn.c.obj
[42/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/i2c_hal_iram.c.obj
[43/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/pcnt_hal.c.obj
[44/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/i2s_hal.c.obj
[45/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/i2c_hal.c.obj
[46/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/ledc_hal_iram.c.obj
[47/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/uart_hal.c.obj
[48/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/gpio_hal.c.obj
[49/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_flash_hal.c.obj
[50/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/can_hal_iram.c.obj
[51/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/uart_hal_iram.c.obj
[52/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_flash_hal_iram.c.obj
[53/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/can_hal.c.obj
[54/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/mcpwm_hal.c.obj
[55/92] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_buffers.c.obj
[56/92] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_noos.c.obj
[57/92] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/sdio_slave_hal.c.obj
[58/92] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
[59/92] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[60/92] Building C object esp-idf/spi_flash/CMakeFiles/__idf_spi_flash.dir/esp32/spi_flash_rom_patch.c.obj
[61/92] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp32/esp_efuse_utility.c.obj
[62/92] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_fields.c.obj
[63/92] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_utility.c.obj
[64/92] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_table.c.obj
[65/92] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp32/esp_efuse_api.c.obj
[66/92] Building C object esp-idf/micro-ecc/CMakeFiles/__idf_micro-ecc.dir/uECC_verify_antifault.c.obj
[67/92] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp32/esp_efuse_fields.c.obj
[68/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash_config_esp32.c.obj
[69/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj
[70/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_qio_mode.c.obj
[71/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock.c.obj
[72/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj
[73/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_efuse_esp32.c.obj
[74/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash.c.obj
[75/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random.c.obj[76/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common.c.obj[77/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[78/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[79/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_sha.c.obj
[80/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[81/92] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[82/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/flash_encrypt.c.obj
[83/92] Linking C static library esp-idf\log\liblog.a
[84/92] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_esp32.c.obj
[85/92] Linking C static library esp-idf\soc\libsoc.a
[86/92] Linking C static library esp-idf\micro-ecc\libmicro-ecc.a
[87/92] Linking C static library esp-idf\bootloader_support\libbootloader_support.a
[88/92] Linking C static library esp-idf\efuse\libefuse.a
[89/92] Linking C static library esp-idf\spi_flash\libspi_flash.a
[90/92] Linking C static library esp-idf\main\libmain.a
[91/92] Linking C executable bootloader.elf
[92/92] Generating binary image from built executable
esptool.py v2.9-dev
Generated C:/esp/hello_world/build/bootloader/bootloader.bin
[897/897] Generating binary image from built executable
esptool.py v2.9-dev
Generated C:/esp/hello_world/build/hello-world.bin
Project build complete. To flash, run this command:
C:\Espressif\python_env\idf4.1_py3.8_env\Scripts\python.exe ..\..\Espressif\frameworks\esp-idf-v4.1.2\components\esptool_py\esptool\esptool.py -p (PORT) -b 460800 --before default_reset --after hard_reset --chip esp32 write_flash --flash_mode dio --flash_size detect --flash_freq 40m 0x1000 build\bootloader\bootloader.bin 0x8000 build\partition_table\partition-table.bin 0x10000 build\hello-world.bin
or run 'idf.py -p (PORT) flash'
C:\esp\hello_world>
Python 3.8.7
idf.py build
C:\Espressif\frameworks>cd
C:\Espressif\frameworks>cd..
C:\Espressif>cd..
C:\>cd esp
C:\esp>cd hello_world
Running cmake in directory c:\esp\hello_world\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=1 c:\esp\hello_world"...
-- Configuring done
-- Generating done
Running ninja in directory c:\esp\hello_world\build
-- Configuring done
-- Generating done
esptool.py v2.9-dev
esptool.py v2.9-dev
C:\esp\hello_world>
- ESP_Roland
Re: Build stopped, ninja failed, win10, universal online installer 2.13
You can try to entirely disable ccache by using the "--no-ccache" argument, i.e. " idf.py --no-ccache build". If this work then it is possible to disable it by setting IDF_CCACHE_ENABLE environment variable to zero.
See https://docs.espressif.com/projects/esp ... py-options for more information.
Hi ESP_Roland,
many thanks for the great help!
I think it works now with 4.1.2. Now I've included it in eclipse and it's running great.
Thank you and best regards.
Michael
Michael
Hi Roland,
I've now installed the new Version of ESP-IDF 4.4.1. It works with
" idf.py --no-ccache build" and "idf.py --no-ccache -p COM3 flash"
But i don't know how i can change the settings of IDF_CCACHE_ENABLE environment variable to zero.
I tried it but with the settings it does not work.
Best regards
Michael
Best regards
Michael
Michael, I hit a similar issue and it's likely because your windows username has a space in it. (mine did too, exactly same error)
Apparently this is being fixed in esp-idf 5.0
See how it's splitting the username?xtensa-esp32-elf-gcc.exe: error: C:\Users\Michael: No such file or directory
xtensa-esp32-elf-gcc.exe: error: Kremer\AppData\Roaming/ccache/tmp/cmd_args.bB9taw: No such file or directory
xtensa-esp32-elf-gcc.exe: fatal error: no input files
Users browsing this forum: No registered users and 230 guests
