Attached is a minimal version of the ESP-IDF v4.4 example "deep_sleep" to only wake on RTC timer.
The code should go to deep sleep for 20s and then wake and print the total number of running seconds.
We have found that this code works if CONFIG_ESP32_RTC_CLK_SRC_INT_RC=y.
BUT fails if CONFIG_ESP32_RTC_CLK_SRC_EXT_CRYS=y - the crystal oscillator does not appear to start and the CPU never wakes from deep sleep
We have tested using a ESP32-WROOM-32 module with an external 32768Hz watch crystal with 15pF loading capacitors and 4M7 parallel resistor.
The supplied code is configured for the fail case with CONFIG_ESP32_RTC_CLK_SRC_INT_RC=y.
Has anyone managed to get the RTC with external crystal working? If so, how?
Wake from deep sleep with external RTC crystal
- Wattwatchers_deep_sleep_20220406.zip
- (14.71 KiB) Downloaded 321 times
Re: Wake from deep sleep with external RTC crystal
There are some open issues https://github.com/espressif/esp-idf/se ... ype=issues
Users browsing this forum: No registered users and 183 guests
