I've been trying to use the RMT peripheral to measure the duty cycle of a continuous PWM square wave. The signal is 2kHz with Duty Cycles between 10% and 90%. Trying to be as specific as possible, the signal is continuous with no breaks between any "symbols".
I've successfully set up an RX Channel:
Initialize(uint8_t rmt_channel, uint8_t gpio)
esp_err_t res;
RMT_Channel = (rmt_channel_t)rmt_channel;
RMT_GPIO = (gpio_num_t)gpio;
rmt_config_t rmt_rx_config = RMT_DEFAULT_CONFIG_RX( RMT_GPIO, RMT_Channel );
res = rmt_config(&rmt_rx_config);
res = rmt_driver_install(RMT_Channel, 0, 0);
rmt_get_counter_clock(RMT_Channel, &rmt_clock_hz_);
res = rmt_rx_start(RMT_Channel, true);
E (3369290) rmt: ---RX buffer too small: 4
E (3369300) rmt: ---RX buffer too small: 4
E (3369310) rmt: ---RX buffer too small: 4
E (3369320) rmt: ---RX buffer too small: 4
E (3369340) rmt: ---RX buffer too small: 4
E (3369350) rmt: ---RX buffer too small: 4
E (3369360) rmt: ---RX buffer too small: 4
Read(void)
esp_err_t res;
volatile rmt_item32_t* item;
item = RMTMEM.chan[RMT_Channel].data32;
std::cout << "item d0: " << item->duration0 << " l0: " << item->level0 << " d1: " << item->duration1 << " l1: " << item->level1 << std::endl;
Regarding the Ring Buffer - it does not really make sense to keep many many readings, I just need one "symbol" (or a small handful at a maximum) to measure the duty cycle, and it does not seem to make much sense to worry about the buffer (especially since the RMTMEM direct read is just as good. If you notice, I actually have the Ring Buffer disabled in the line
Could anyone suggest any options for sampling the duty cycle of this signal? I only expect to measure the duty cycle of the PWM signal every 20ms or so at most (which is how I have the above code set up - the Read() function gets called by another task).
Thanks in advance.
